Washing machine started and water filled, then alarm came and showing " de". Then not working
  • 4 Answers
De code usually means "door error" might have a bad door switch. loose or not closed propery
Posted on Dec 07, 2016
the carbon brush may be worn out and need replacement(these are a pair of componet that makes contact to the motor. Francis
Posted on Jul 16, 2007
SOURCE: washing machine fills continuously
I had the same problem as above. I cleaned the chamber attached to the bottom part of the bucket and used a syringe to push hot water down the this plastic hose that runs to that unit. I also made sure that the clip holding the plastic hose at both ends are fited properly. (similar to what mike has in solution 4). All sorted.
Posted on Oct 09, 2007
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Posted on Feb 27, 2008
  • 65 Answers
Either call the store where you purchased the machine or refer to your users manual, should have a trouble shooting guide in the back of the manual.
Posted on Jan 05, 2009
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting
Posted on Sep 30, 2009
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
The door was opened while the washer was running
The washer failed to lock the door
Washer temperature control problem
Heater Relay Failure (on main PCB)
The door will not unlock
Washing machine has failed to drain the water
Water fill time out
Water Does Not Drain From Washer
Water fill time out = No Fill
Washing machine door detected as being open
Washing machine has detected an imbalanced load
Washing machine has imbalanced load and will not spin
Motor fault detected
Motor short error
Washing machine has detected an overfill situation
Water leak - Excessive SUDS - Bad water level switch
Water heating error detected
Water heating sensor (thermistor) error detected
Water level sensor fault
Abnormal water temperature detected
Not filling in allocated time
Pump won't empty - not draining
Overflow - overfilling with water
Out Of Balance (OOB) detected
Water temp rising or falling too quickly
Pressure switch
Temp too high on low temp washes
Water leak, Water level has reduced
Motor generator error
Motor error
Sep 30, 2016 | Samsung Washing Machines
Hi, my Electrolux EWX12550w washing machine and dryer, working fine on was but when I'm drying it it starts at 13 minutes then keeps working but sticks on 10min also I get an err sign it's E10
Family error code E10 is visible to customers and (could be E11,E12 and E13 only visible in service mode) means problem
with filling water.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
Press and hold down START/PAUSE and the nearest option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the last alarm.
The alarm sequence continues as long as the two buttons are held down.
E11 - Problems with water fill for washing
E12 - Problems with water fill for drying
E13 - Water leakage
I believe there are difficulties in water fill for drying.
Water is necessary in the drying phase in order to cool down the steam entering in the drying condenser.
Possible causes: Tap closed or water pressure too low; Drain tube improperly positioned; Water fill solenoid valve is faulty; Leaks from water circuit on pressure switch; Pressure switch faulty; Wiring faulty; PCB faulty
Sep 07, 2015 | Electrolux Washing Machines
Lg wf 8071ttp
de is for door error not fit properly or door switch totally defective
call the technician for your safety and not to waste money.
Nov 01, 2013 | Washing Machines
Mi lavadora no para de llenar el agua
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
May 26, 2011 | Kenmore 24032\24036 Top Load Washer
LG Turbo drum washing machine is showing dE and stop after filled with water - no washing done and beep all the time.
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 29, 2011 | Washing Machines
Error pada mesin cuci lg 6.5 g kode dE disebaban oleh apa?
m.cuci lg toplouding error DE. pada dasarnya pintu atas dilengkapi swich tapi kenapa model ini kok gak.terus gimana cara ngatasi door swich ini. mohon pencerahan
Jan 17, 2011 | LG Washing Machines
LG WF T6517TC Washing Machine does not fill water
my washing machine WF-T6517TC
when it start to wash get Alarm "dE" beep and stop machine.
what need to do.
call me 91080843
Apr 10, 2010 | LG Washing Machines
Errorcode de
Feb 16, 2010 | LG WM-2277HW Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
