Which key is Scroll Lock key on keyboard? - Computers & Internet
  • kakima Dec 07, 2016
    Hi Robin Heintz, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Which keyboard?
SOURCE: Scroll Keys
Hi, I believe you need to press the fn+pause/break key to switch scroll lock on and off.
Hope this helps
Posted on May 30, 2008
SOURCE: Scroll lock on Logitech LX 710
1. Click on Start and click on "Run"
2. Type osk and click OK.
3. You will see the On Screen Keyboard (OSK)
4. If the "nlk" button is white, it will be a visible key on your keyboard. Blue is when the key is not visible and the dark blue with the red border when the NumLock is ON.
5. Please make sure the "nlk" button is blue.
6. You will also the display on your monitor when the slk button is clicked or changed on the OSK.
Posted on Jul 15, 2008
SOURCE: KVM switch
It might have something to do with the KVM Switch. Check that your switch will handle Keyboard shortcuts. If you are using the same KVM switch then you should be able to use the same short-cuts regardless of the keyboard you use.
Posted on Oct 27, 2008
SOURCE: Scroll Lock on -- mystery
On the Logitech LX710 Lazer the Scroll Lock option is toggled by holding down the "Function" key and pressing the "Pause/Break" key. If you look at the P/B key you will see a little orange symbol of an arrow pointing down to remind you of this feature. This can be disabled in the Setpoint panel by selecting Keyboard and Keyboard Inactive Keys then place a check in Disable Scroll Lock so you may have to remove a check mark first.
Posted on Dec 10, 2008
SOURCE: Cannot unlock Keyboard Scroll lock - EX110
Found this little bomb shell after about 30mins of looking for an answer.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9220
To toggle your scroll lock key:
  1. Click on the Windows Start button.
  2. Select Run.
  3. Type 'OSK' in the dialog box.
  4. Click on OK.
  5. The Microsoft on-screen keyboard will open. Notice that the slk, or scroll lock, key (located in the top row of the on-screen keyboard as shown below) is turned on.
  6. Click on slk (in the top row of the on-screen keyboard). This will toggle the state of the scroll lock key. Notice that the scroll lock key is no longer outlined in red. Scroll lock is now off.
NOTE: If you have installed SetPoint (Logitech’s Mouse and Keyboard software) the confirmation message Scroll Lock Off will also be displayed for about 2 seconds on your monitor.
Yipee!!!
Posted on Jan 25, 2009
Microsoft excel 7 disable scrool lock fuction
First locate SCROLL LOCK key in keyboard (Normally it in function keys in laptop, and separate on desktop keyboard).
Now press:-
1. SCROLL LOCK Key
or
2. Fn + SCROLL Lock key (if it is colored as the color of Fn key in laptop)
Sep 30, 2014 | Microsoft Excel Computers & Internet
Where is the Scroll lock on the keyboard of lenovo laptop?
To Turn on/off Scroll Lock do one of the following: Press the Scroll Lock (sometimes appears as ScrLk) key on your keyboard. If your keyboard does not have a Scroll Lock key, on your computer, go to Start, All Programs, Accessories, Ease of Access, and then click On-Screen Keyboard.
Jul 14, 2014 | Compaq Keyboard
Scroll lock on mousepad get locked
Try: To toggle your scroll lock key:
  2. Select Run.
  4. Click on OK.
Aug 29, 2012 | Lenovo INC 102495U Z570 Ip Ci321 156...
How to unlock the scroll lock key
Hi!
To unlock the scroll lock key on your zippy keyboard, please press the scroll lock key again.
Every time you press this key it switches between lock/unlock.
Regards,
Aug 20, 2011 | Zippy EL-610 (840556027058) Keyboard
There 3 lights on the right top side of keyboard - one is capital lock -one is number lock- what is the third one? the light is on and I don't know what to hit ti turn it off.. thanks
The third one is probably Scroll lock. On your keyboard you should see a key labels Scroll Lock or it may be abbreviated. The key may also have the same symbol as the light. You turn Scroll lock on and off the same way as turning Num Lock on and off. Usually involves using the FN key + Scroll Lock.
Mar 12, 2011 | Compaq Keyboard
There are three lights on the upper right hand side of the keyboard. I know number lock and caps lock, what is the third light and what keys did i hit that made it go on? How do I turn it off?
The third light on your keyboard is normally the scroll lock, the key to enable/disable this function is the Scroll Lock key which is located above the Home key.
Mar 03, 2011 | GE Power Keyboard (97798)
IOGEAR KVM gcs632U. Set up notes that to "toggle" between PCs you press SCROLL LOCK twice. My keyboard has no SCROLL LOCK so to change you are supposed to press NUM LOCK + "-"...release "-" after 1...
OK well usually in the "Setup" you can "Assign" whatever keys you need, so can't you change the keys used to what you have? ALL Keyboards have scroll lock, it is probably just "Hidden" for instance I found one accessed via pressing a Blue Fn Key and then F12. Look carefully for "Other: small writing on keys.
Feb 15, 2010 | IOGear GCS632U 2-port KVM Switch
  2. Select Run.
  4. Click on OK.
Yipee!!!
Aug 21, 2008 | Logitech Cordless Desktop EX110
Jun 25, 2008 | Logitech LX 710 Keyboard/Mouse
Scroll Keys
Hope this helps
May 30, 2008 | Logitech Cordless Desktop MX3200 Laser...
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
