Question about Tools & Hardware - Others
Craftman 4inch belt sander seized because of blower. This was diagnosed since it runs if the blower is removed. Once i secure the blower, it continually leads to a motor seizure
I have an old craftman 4inch belt sander. When using it, the cord got caught in the sander and it seized the motor. I took it appart and I have diagnozed the problem to the blower since the unit works fine without the blower in place. The surface of the blower as well as the surface of the sander the area where the blower spins against the sander appears to be worn and there is hard plastic material that may have melted although I am not sure what this area should look like. I am not sure if there should have been a wear plate between the blower and the sander. Have you had any problems like the one mentioned. My unit model is Craftman 315.242900
  • 126 Answers
SOURCE: kenmore 110.92195110
those parts come as a complete kit. order a brake assembly.
Posted on Jan 12, 2008
cloe2594
  • 29 Answers
SOURCE: Dremel belt/disc sander
see the manual
Posted on Nov 06, 2008
rowdy45176
  • 2176 Answers
SOURCE: slipping belt
OK the belt tensioning mechanism is spring loaded. First what is the quality of the belts are they real flimsy or stiff. You say the rollers spin but my question does the rear roller still spin and the belt remain stationary. If so the rubber belt on motor is bad. I would take a look for excessive wear on the rear roller. Does the yoke mechanism snap forward or move slowly, look for a build up of sawdust in this area that might be restricting movement on the yoke. The wear plate in still good condition. One other thing on the belts are they directional? Do they have an arrow on the inside if so that has to point toward front of tool. I looked at a breakdown and could not see anything else to suggest. I never had this problem except with belts when I was at Makita.
Posted on Jan 19, 2009
SOURCE: kenmore...no drain but clicks instead...agitates and drains fine 110.92195110
I'm having the same issue with my hoover family 1300. Any ideas on that? would it be the same? mine is a front loader.
Posted on Jan 23, 2009
Editor925
  • 285 Answers
SOURCE: belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Posted on Mar 18, 2009
3D sander backing pad
Hi, I just wanted to inform you that I have available for sale the Sanding Replacement Velcro Discs for the 3 D Craftman Sander Machine. If interested in buying, please email me at: jcarrion@ylcconsulting.com
Mar 11, 2014 | Craftsman 0.5 amp 3D Sander
Drive belt for a craftman snow blower and auger belt
www.sears.com/parts or www.mowparts.com
Jan 13, 2014 | Garden
Owner manaul for sears craftman model 31511721
a guy is selling the 31511721 belt sander manual online for 5 bucks
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250665595607
Buy a used 3x18 sander for $24
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270645575457
Sears has a phone number and e-mail
http://www.sears.com/shc/s/search_10153_12605?keyword=31511721&x=11&y=10&vName=Tools&viewType=gal&viewItems=24&layaway=&clearance=&cName=#
Sears has sanders but I don't see manuals
http://www.sears.com/shc/s/v_10153_12605_Tools?sbf=Brand&sbv=Craftsman&adCell=WF
Ryobi makes the sander you have: they have a contact e-mail ... and of course no manuals since they have service centers
https://register.ryobitools.com/contact_us/new
Oct 11, 2010 | Garden
Bosch 3 x 21 Belt Sander
Remove the dust bag and unplug sander for now. Everywhere you see an access hole (fan area, dust port, back of sander blow thru the tool to remove lodged dust that clogged the system, Also look for broken belt pieces in the back of sander. Then while running (remove belt) blow again thru all the ports to try and reomve as much contamination as possible. When finished you can feel to see if air coming from dust bag port, it not you still have a clog that might need more work. If I have clarified your request would you please rate this response accordingly and thank you.
Sep 10, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
Belt won't stay on belt sander
Mar 18, 2009 | Black & Decker Tools & Hardware - Others
My Bosch 1274DVS 3" x 21" belt sander will run only sporatically
Hi
Definately sounds like bad switch or contact to the switch
Feb 26, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
Motor runs but the drive drum that hold the sanding belt does not turn.
Instead of removing the drum, remove the belt and the cover over the gearbox. The gearbox cover is normaly fixed in place by screws around the drive pulley. There may be a couple of screws under the pulley, if so they can be accessed via holes in the pulley wheel itself. Check for worn or stripped gears. These gears can be replaced if need be, but if this is the case make sure you remove and clean out all the grease first and replace that aswell as it may contain bits of teeth that have come off the faulty gear. As far as I know belt sander drive rollers can not be removed without removing the drive inside the gearbox first.
Oct 27, 2008 | Dewalt Factory-Reconditioned DeWalt DW432R...
Belt sander adjustment
There should be a knob on the front of the sander which adjusts the front roller on the sander. If the belt runs off in the same direction each time try turning the knob as the sander is running and while watching the belt. If turning the knob one direction does not work try turning the other direction. If turning the knob does not have any affect on the way the belt tracks on the sander then you probably have a broken or missing part on the front of the sander. This may require taking the sander to a service center.
Sep 15, 2008 | Tools & Hardware - Others
How many Types of Sanders?
Belt sanders: Belt sanders are useful for removing large quantities of wood stock quickly. They are generally used for rough sanding before fine finishing with a smaller sander. Palm sanders: Palm sanders are ultra-portable and useful for finishing small projects. Orbit sanders: Orbit sanders are usually more heavy-duty than palm sanders and appropriate for larger projects.
Aug 27, 2008 | Bosch 3X18 Belt Sander
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
