Question about DeLonghi Heating & Cooling
Heater not turning on How do I reset it It is delonghi CH15
My Delonghi heater won't heat all the lights work modelEW7507EBL
Heating element might gone.check the volts on both ends of the element with the multimeter if you can be careful do not touch any part coz high volts could be dangerous, so don't do if you do not have enough knowledge.
Nov 04, 2015 | DeLonghi EW0507 Oil Filled Radiator Heater
My heater was on and fall down for 1 hour an d now its not working
Unplug, set upright, let oil go back down to base. Check owners manual for reset. Make sure to let unit set upright for a couple hours then plug in and try operation. If unit still does not work contact Delonghi and maybe they can help.
Apr 19, 2014 | DeLonghi KH190715 Oil Filled Radiator...
How do I use the Delonghi trv0715 1500w Vento High speed convection heater
The owner's manual is available as a PDF here: http://www.delonghiusa.com/index.php?product&nid=107 .
Many recommend you plug the heater in and turn it on in a well-ventilated room (like a garage) for the few hours of use. If you are using the heater to warm a room, plug it in with the thermostat set to maximum and set the power selector to 3 until the room reaches the desired temperature. Then rotate the thermostat clockwise until you hear a click. You can set the power level to 1 or 2 to conserve energy while maintaining the current temperature settings.
If you are trying to avoid frozen pipes in an area, plug in the heater and set the power selector to 3 and thermostat to *.
Always remember to keep anything flammable away from the heater (loose drapes etc.) There is an overheating protection circuit built into the unit. To reset it, you need to call the DeLonghi service center.
I hope this helps.
Mar 05, 2011 | DeLonghi Heating & Cooling
I have a Delonghi Dragon HM3 Oil Filled Radiator, its only a year and a few months old, I turned it off after using it for a few hours and now it won't turn back on. I have changed the fuse but still no...
does it have a reset button? Have you thrown a breaker to that plug in? Does that plug in work? Try plugging something else in and find out it could be as simple as a blown breaker. thats the only things I could think of
Mar 04, 2011 | DeLonghi 6707E Oil Filled Radiator Heater
My heater turns on but then turns itself off.
It is possibly a safety sensior that turns off unit when tipped over. Try turning unit over to c if it will reset, U may have to do this more then once.Usually this will do the trick,
Jan 01, 2011 | DeLonghi 6707E Oil Filled Radiator Heater
The coffee pot won't turn on anymore
burnt thermal fuse or heater does heater work under coffee pot? :)
Jul 03, 2009 | DeLonghi DCM485 Coffee Maker
DeLonghi oil filled heater typ.061563
Hello I have a Delonghi KR031225 found that after turning it on and it heated up it began leaking on the bottom corner on the same panel that holds the controls? What could be wrong? Is it beyond repair?
Thanks
Mel
Jan 29, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
Delonghi DR18T Timer Replacement
before you replace the timer, check and see if the timer has a battery in it. if it has, then change the battery. it will work fine.
Jan 25, 2008 | DeLonghi DR-18TG Oil Filled Radiator...
How do I reset ?
It should come on automatically, if it does not then the thermal switch is faulty, and has to be replaced.
Jan 22, 2008 | DeLonghi DUH300 Utility Heater
Heating & Cooling Logo
77 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
