Where can i order paper & ribbon for p-440? - Office Equipment & Supplies
Can i use Zebra i-series YMCKO ribbon in Javelin i-series printer
hi, not sure, but they have diferent ribbons, 800000-440 or -415 ....
try difirent ones
May 13, 2014 | Zebra P330i Thermal Card Printer
I have a smith corona sd680 work processor typewriter. When I type the letter don't come out clear and I have to type over and over in order to read the letters. This is an old typewriter in the office...
This problem is usually caused by an old ribbon theey do dry out when left in tthe typewriter a long time, also if the paper is really hard or has a slick surface the ink from the ribbon will not stick to the paper.
Dec 14, 2010 | Smith Corona Office Equipment & Supplies
My zebra card printer p330 i donbt recognized the colour ribbo YCMK, only detect the mono ribbon
The P330i is not supposed to work with the YMCK color ribbon, you should use the YMCKO 800015-440 color ribbon.
-- The Pros at
Sep 25, 2010 | Zebra P330i Thermal Card Printer
How do one resolve and out of ribbon error, when there is a a ribbon present. I'm getting this error on a P430i zebra printer.
The P430 and the P330 are similar, P430 print both sides from the card, and the P330 just print one site, but the commands to send are the sane. Please try !SA command from the driver.
Sep 22, 2010 | Zebra P330i Thermal Card Printer
Keep getting Out of Ribbon message even i changed ribbon..printer zebra p330i card printer. how can i fix it?
I assume you are using YMCKO ribbon rather that K monochrome. If using YMCKO (or a few other specialist ribbons) the spool has a large blue collar at the back with a paper covered chip. The chip has to be for the P330i rather that the Javelin or Polaroid version of the printer. The code on the YMCKO ribbon should be 800015-440. There are a number of companies selling cheap knocked off ribbons that claim to be compatible. That could be part of the problem. The printer has to communicate back to the windows driver when a ribbon is changed, maybe there is a comms problem, try another USB port or reload the driver.
Sep 18, 2010 | Office Equipment & Supplies
My zebra card p330 dont recognize the colour ribbon, only detect the mono riboon
Try to send the command !SA from the driver. And run the Ribbon calibration
Sep 04, 2010 | Zebra P330i Thermal Card Printer
No text show up when typing
Do you hear the type hitting the paper? Is the ribbon installed properly and in good working order (a carbon film ribbon is all black, or a cloth one has ink in it)?
Jul 10, 2010 | Brother ML-100 Typewriter
Correction Tape
The correction tape which should be a yellow spool and the correction ribbon cartridge should be a yellow also, sometimes orange, first. The correction tape has to in front of the black correction ribbon. in othe words this is the order. Platen, paper, correction tape, correctable film ribbon, printwheel. Also make sure correction tape is dull side toward paper. Shinny side should face operator...
Aug 12, 2008 | Brother ML-100 Typewriter
20 people viewed this question
