PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Hi, i have an acer aspire 1640z i upg...
By roald on Jul 20, 2009
hi, i have an acer aspire 1640z i upgrade my bios from 3a18 to 3a24. after installing my notebook restart and i hear 3 beeps ( 1 long, 2 short) and my lcd doesn't turn on the motherbord work fine. Please help me???
Solution #1
posted on Jul 20, 2009
Not Rated)
SmartAviator
Rank: Wiz
Rating: 77%, 187 votes
Are your sure that you have upgraded your BIOS with correct update ? Is there any Virus in your PC ? There are a lot of questions after having correct answers, the problm could be pinpointed. (ehteshamhusain@gmail.com)
Was this helpful?
Yes
No
Solution #2
Not Rated)
leecom72
Rank: Guru  Computer Hardware  Expert
Rating: 89%, 2529 votes
1 long, 2 short beeps indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
This issue can be caused by any of the below situations.
  1. New hardware conflicting with old hardware.
  2. Bad or failing hardware device.
  3. Connections not connected or connected properly.
  4. Recent electrical storm that caused a surge that damaged computer.
  5. Other hardware issue.
Disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue.
Re-insert the memory into the same slot.
  1. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick.
  2. Try one stick of memory in each slot.
If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify which stick of memory is bad and replace it.
If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard.
The RAM is located under the laptop behind a hidden panel.
Good luck and let me know how you get on and if you need any more help or advice.
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
thinkpad t60 battery, any recommandation?
Answer
I am in college, this would be my second computer (my current laptop is too cumbersome to carry), so... (More)
Answer
The windows is not proceeding. there's a beep then windows will restart again and again. please... (More)
Answer
my toshiba sattelite wont start has blank screen plz help wont let me do anything at all
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
