Question about The Toys
How do you take off the seat fabric on the evenflo exersaucer first steps?
SOURCE: evenflo exersaucer
I just bought replacement springs on evenflo's website for 45 cents each. Now I just have to figure out how to get them in.
Posted on Aug 17, 2008
SOURCE: I need assembly directions for evenflo exersaucer triple fun.
1. Remove toys and seat from the exersaucer.
2. Fold exersaucer, but do not let the tray lock to the base. With exersaucer flat on the floor, twist each leg assembly (B) fully clockwise until it stops. Fully depress one of the pedestal locking tabs (C) then push on the leg assembly (B); leg will partially fold. Repeat this for all four legs. After pressing the fourth pedestal locking tab (C), the Exersaucer will fold with the tray (D) rotating toward the base (E). Make sure all four tray locks. (F) are locked onto the base before trying to carry exersaucer.
3. Place your fingers beneath the legs (A) push upward to disconnect the leg assemblies from the pedestals (B). Repeat for all 4 leg assemblies.
4. After all four legs have been disconnected from the pedestals, remove tray assembly (C) from the base (D).
5. Turn tray (C) upside down and remove both end caps (E) from beneath.
6. Squeeze both locking tabs (F) on each side of the tray to disconnect and seperate the tray halves (C). 7. Connect tray halves (C) to form activity table.
8. Rotate leg assemblies (A) fully clockwise until they lock into postition. Make sure all four legs lock (G) are locked properly into the uper leg pedestal (H). Also make sure all four leg locks (I) are sticking out past the edge of the tray.
9. Turn table over and install two end caps (E). Make sure both end caps lock into place. NOTE: one end cap installs from above and the other installs from below.
10. Install toys on activity table. If desired, adjust table to the appropriate height for your child. IMPORTANT: NEVER use stage 3 without end caps!
Posted on Apr 19, 2009
  • 53 Answers
SOURCE: Disassembly of Evenflo Ultra 2-in-1 Exersaucer
Click on this link
https://plweb.evenflo.com/product_search.aspx?txSearchModelNo=6201650&txSearchDOM=1/1/2008
On line 16 there are downloadable instructions.
I tried to paste it in this window, but it's too large and in several different languages.
Posted on May 05, 2009
SOURCE: need to put seat back on old evenflo exersaucer-no instructions
there should be small plastic clips on the material for the seat and then you just clip them to the plastic..... it sounds much easier then it is
Posted on Jun 06, 2009
MazzyA
SOURCE: how to remove the seat cover on exersaucer
Hi, all the way around it are plastic bits sticking out and the seat cover is clipped onto the plastic bits, just lift them off one by one, all the way around. then when your done clip them back in again. hope this helps.
Posted on Jun 16, 2009
How to convert evenflo exersaucer
Here's a step-by-step article for converting the Evenflo Exersaucer. It has photos and videos. How to Convert the Evenflo Exersaucer into Stage 3
Mar 01, 2015 | Evenflo Exersaucer Triple Fun Active...
How do i convert it into the s shape activity center
hi here are the instructions
https://plweb.evenflo.com/product_search.aspx?txSearchModelNo=6231883&txSearchDOM=1/1/2010
Oct 28, 2010 | Evenflo Exersaucer Triple Fun Active...
How do i put the seat back on my evenflo exersaucer
There are several models of exersaucers, but hopefully the seat attachments are similar. Here is a video from Evenflo showing how to assemble the product. This might help you.
http://www.evenflo.com/resource.aspx?id=467&rcid=19
Sep 29, 2010 | Evenflo Exersaucer Triple Fun Active...
I'm looking for an online assembly manual for my evenflo exersaucer
You can try this link. It will be helpful if you know the model number to the exersaucer you have. https://plweb.evenflo.com/replacement_parts.aspx
www.evenflo.com is a good website check it out it has a lot of helpful information. Please tell me if this works for you ok.
Thank you
May 04, 2010 | Evenflo Exersaucer Smart Steps 6161812 1...
Reattach seat to Evenflo Exersaucer
Match the red arrow on the fabric seat to the middle of the seat back. Use a crochet hook to fish the elastic straps through the slots. Pull the elastic straps to hook on to the tabs on the lower rotator fastener. The key is to pop the fabric seat up into a cone, so that you can see what you're doing.
Feb 07, 2010 | Evenflo Baby Gear
I need to know how to put the seat in an Evenflo Exersaucer Deluxe because we received it that someone didn't need it anymore. Its an older on from 95. Please can someone help me because my granddaughter...
https://plweb.evenflo.com/faq_detail.aspx?faqid=3934
Question: How do I put the seat pad on the Exersaucer? spacer.gif Answer: 1.Line up the red diamond on the seat pad warning label with the triangle on the back of the seat ring. 2.Fit the elastic loops through the quarter inch gap between the seat ring and rotating rings and hook the elastic loops over the prongs on the bottom of the rotating ring. 3.The plastic tabs on the seat pad are only for reinforcement and don't hook to anything, but should be threaded between the 2 plastic rings. If you still need further assistance please refer to the instruction sheet or call the Evenflo ParentLink Consumer Resource Center at (800) 233-5921 or (937)773-3971 for further information.
Mar 25, 2009 | Evenflo ExerSaucer SmartSteps ABC Stroller
I have a older exersaucer made by evenflo and i dont know how to put the seat back on
original instructions for any exersaucer
https://plweb.evenflo.com/ShowDocument.aspx?ManualID=234
25702569.pdf
Sep 10, 2008 | Evenflo ExerSaucer SmartSteps ABC Stroller
Spare part for exersaucer
Let me know the part number and date of manufacture.
Exersaucers   On the inside of one of the legs when you adjust it to the highest level or on the underside of the plastic seat ring.
Jul 31, 2008 | Evenflo Embrace
Old evenflo exersaucer
25702569.pdf
Jun 03, 2008 | Evenflo ExerSaucer SmartSteps ABC Stroller
Exersaucer seat
Evenflo - Exersaucer Instructions
25702569.pdf
Dec 30, 2007 | Evenflo Baby Gear
Toys Logo
24 people viewed this question
Top The Toys Experts
Paul Carew
Lawrence Oravetz
Are you a The Toy Expert? Answer questions, earn points and help others
