Question about Vacuums
Vacuum brush stays on when attachment is connected
4 Suggested Answers
Kazong
  • 152 Answers
SOURCE: roller brush of vacuum not rotating
u might need 2 change the belt on the attachement there r 2 screws on top take em out after u take off cover there is a plastic cover over the belt take off c if the belt broke the rest is easy
Posted on Mar 02, 2008
  • 50 Answers
SOURCE: the carpet brush attachement loses power while vacuuming
I have seen this many times. It is either a bad connection or a break in the wire. Turn it on and flex the wire and connection until you can reproduce it dependably. Then you will know what it is and where.
It is very aggravating. You need to fix it soon, before you take to jumping up and down on it and bust the wand and the power head also.
Posted on May 28, 2009
  • 1768 Answers
SOURCE: I have the bissell powerglide
1. this could be (2) things that are happening or 3
2. there is hair surround the spindle (rotation) brush tool blocking rotation or you have a motor that has failed and it is not turning the rotation brush.
3. the switch (on /off) has failed.
Posted on Apr 17, 2011
Vacuum brush stays on when dyson 44 attachment is attached but not turned on
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller is not working properly. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dec 07, 2016 | Dyson DC44 Animal Cordless Vacuum
Brush stays on when upright
You are correct, the brush will continue to rotate when using the upholstery hose as stated in the user guide.
The burning smell may be contributed to a couple of different reasons. Make sure the front of the vacuum is not being tipped or tilted forward when using the upholstery hose.
If you continue to have difficulty, you may want to have a one of BISSELL's Authorized Service Centers inspect your vacuum.
Here's a quick link to locating one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Mar 12, 2013 | Bissell 3522 PowerForce Bagged Upright...
Can I turn off the brushes when using the hose attachement?
Nope, unless you see a big button on top of the hood that says brush. (which I doubt it does) That brush will stay running. It doesn't hurt anything really. When you lean the machine to upright it lifts the brush up off the floor.
Feb 02, 2013 | Hoover UH70120 WindTunnel TSeries Rewind...
Belt will not stay on
Those machines have the belts on them at production.
You can read about this
www.vacuummedic.com/blog/2012/10/09/my-brand-new-vacuum-doesnt-work/
Change the belt! Good as New!
Good Luck
The Vac Dr.
Dec 21, 2012 | Hoover Elite Rewind Bagless Upright Vacuum...
Brushes won't turn
Look at the ends of your brushes were the brush piece attaches to the vacuum. Sometimes they are broken or just stuck. good luck
Dec 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brush assembly won't spin
you must replace the pump thats what the belt is attached to
Dec 01, 2009 | Bissell 8910 ProHeat Clear View Upright...
The brush attachment will not stay in place on my Hoover steam vac F5858-910
Check the bottom of your brushes. It should have a long shaft sticking out of of the middle of it which locks on the base. If you don't see the shaft, the brushes are broken
Jun 11, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
The carpet brush attachement loses power while vacuuming
May 27, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Middle brush problem
If this is new, get it replaced under warranty. Take your model number, serial number, proof of purchase and the brush block with you, or you may be able to do it at hoover.com.
May 25, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
ASSEMBLING BRUSH HOLDER TO STAY IN PLACE
try thehooverstore this online site has your machine with exploded diagrams. you should be able to figure out how it goes together
Apr 29, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Vacuums Logo
24 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
