My inverter has a high pitch sound alarm and the digital screen shows a flashing OLP what does that mean
  • 2,760 Answers
OLP= overload protection , that also explains the alarm as well
Posted on Dec 07, 2016
2 Suggested Answers
muthur85
  • 117 Answers
SOURCE: Whining noise
your mic is on remove your mic friend
best of luck
Posted on Oct 26, 2007
My 1500 watt cobra power inverter shows "olp" wuth nothing connected. bought a new one also 1500 watt and as soon as i turn it on shows "olp" also.
Pop is over load protection. You may have gotten a bad inverter. When you do connect something to it does it go away? If so what size wires are you using? To small a gauge wires cause all kinds of problems.
Feb 27, 2017 | Cobra Electronics - Others
3000 watt eliminator with OLP and LUP CODES any Ideas
Assuming you have a 12VDC In 120V AC out 3000W inverter.
LUP indicates battery voltage is low, so firstly make sure:
1. You 12V battery is good, it's large enough a minimum of 75AH and probably much larger is recommended and it's fully charged.
2. Verify you are using the correct size copper wires from battery to the Inverter DC INPUT(s). If you keep wire short the wire size can be smaller, but if the DC input wires are longer then you will need to use thicker copper wires.
At MAx load you would be taking 250 AMP from battery, so for a 5% Volatge drop of .6 V for a 10 ft length of cables from battery to Inverter you would need to use a 1AWG copper cable.
http://www.calculator.net/voltage-drop-calculator.html?material=copper&wiresize=0.4066&voltage=12&phase=dc&noofconductor=1&distance=10&distanceunit=feet&eres=125&x=37&y=8
OLP is a overload condition, which means you may have to many high powered AC powered things connected to the Inverters AC outlets or maybe something that has large start up surge, ie devices large electric motors.
Or it could be all due to a faulty Inverter.
Oct 22, 2016 | Eliminator Electronics - Others
There is a high pitch noise coming from the computer
The high pitch sound could be a faulty inverter that supplies high voltage to the CCFL lamp that provides the back light. The inverter is located at the bottom edge of the LCD screen.
Replace inverter for your model notebook are available from one of these WEB sites.
LCD screens and Inverters www.lcdparts.net http://www.yallstore.com http://www.shope2.com/ http://www.invertercentral.com/qrySearch.asp?Adword=1500&search=1500&Campaign=Google-Models-NA&gclid=CO3lg7HJlKMCFQcbewodZB2qoQ http://www.nylaptopparts.com/ http://www.ccflwarehouse.com/
Apr 17, 2011 | Toshiba NB205-N210 Netbook
My screen is making a high pitch whistle. it is a sony vaio pcg-z1xsp.
If the high pitch sound comes from the bottom of the screen, then most likely the inverter is faulty.
you can get inverters from this WEB site.
www.lcdparts.net
Nov 14, 2010 | Sony VAIO PCG-Z1WAMP1 Notebook
When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
Aug 05, 2010 | Samsung HLN467W 46" Rear Projection HDTV
Led light flashes on and off
The high pitch sound can be from the inverter transformers or from the lamps assemblies. You need to open it up and inspect the inside, look at the caps. See my pictures here so you will know what to look for inside.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Service manuals: http://elektrotanya.com/?q=showresult&megnev=hp&megnev2=F1523&kategoria=&kat2=all
Post back what you find so it will help other people also.
Apr 09, 2010 | HP Pavilion F1523 15" LCD Monitor
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
When my acer ferrari is loading the operating system it emitts a high pitched tone which i cannot get rid of. is it by chance a battery alarm?
If it is a very high pitch tone and it appears to come from the bottom edge of the LCD screen, it could be a faulty inverter. The inverter supplies high voltage to the CCFL lamp which provides backlight to the LCD display.
Aug 13, 2009 | Acer Computers & Internet
2000 watt cobra inverter keeps saing olp, overload
2000w means is out off rang load 2000w plus then alarm beep have running.
Mar 24, 2009 | Cobra CPI 1000 DC to AC Power Inverter
Screaming acer!
sometimes if the inverter board (the part that drives the backlight) has a cold solder joint on it, it can actually generate a high pitched resonating sound (aka a screaming squeal sound)
if it's under warranty, have the manufacturer correct the problem.
if not under warranty, retouch the solder points on the inverter board, or have a repair tech fix it for you.
Jun 03, 2008 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
163 people viewed this question
David Payne
David Payne
