I heve a koma 400 hours or days matel clock a it does not goes, ? hoe tostart the thing ?
Koma w5 400 days clock, any ideas ? how get it going ??
2 Suggested Answers
SOURCE: kitchenaid range
could i get a more complete mod num on this range my tech data shows no f1 e2 code f1 is usually the eoc there should be more numbers after 307 theses are the engineering codes and are model specif
Posted on Dec 28, 2007
How to start a 400day koma clock
Anniversary (400 day) clocks can be monsters This link should help you out:
How to set up an Anniversary clock
Dec 07, 2016 | Home
How torepaire a 400 days clock
A 400 day or anniversary clock is not a good clock to work on especially for a beginner. I have quite a bit of experience with clocks and I do not mess with them. If you are looking to get into clock repair I would suggest starting with a good old American 8 day.
Main Page
Oct 10, 2016 | Home
How to start clock going
Setting up anniversary clock can be a monster, this link should help you out.
Oct 09, 2016 | Home
I can't even set the time! When I push the clock button I can advance the minutes, but then when I push the hour button the display goes off. Same thing happens if I start with changing the day of the...
If timer is not functioning... the battery needs to be changed or installed (if timer has battery, such as ST01, Ei500, EJ500 timers)
Or timer such as Aube or Honeywell or battery-operated timer mentioned above, or other possible timers not mentioned, has been exposed to freezing temperatures, and is not rated for low temperatures.
Or timer is defective.
http://waterheatertimer.org/Programmable.html#st01
http://waterheatertimer.org/How-to-troubleshoot-timers.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 01, 2015 | Hardware & Accessories
I set the clock for a morining time, but it goes off in the evening.
There should be some kind of indication whether you are setting time in AM or PM. You may have missed this as you rotated through the time setting
Dec 17, 2012 | MZB Imagination SpongeBob SquarePants...
No batteries that I put in it will keep it on and the lens goes in and out and then won't go all the way back in when it goes off.
this is due to dust or moisture if you take this type of cameras near seashore this happens. keep it near 60 w bulb for 1 hour and then blow the dust particals with help of blower
May 21, 2010 | Sony Cyber-Shot DSC-W5 Digital Camera
Lack of power
Try replacing the fuel filter. Get the pressure checked. Check the vacumn hoe going to the MAP sensor.
Jun 19, 2009 | 2003 GMC Sierra
Kitchenaid range
Dec 28, 2007 | KitchenAid KESC307 Electric Kitchen Range
When I go to messages, it says the time and then says "POWER FAILURE."
Set the Clock
You must set the clock once so that the
system announces the correct day and time
with your messages. After this, if you
subscribe to Caller ID, the system will
automatically reset the clock each time new
call information is received.
Press Pto exit at any time while
setting the clock.
1 Press and hold Cuntil the Message
Window displays C, and the default day
is announced.
2 To change the day setting, press and
release ror auntil
the correct day is announced.
3 Press and release C. The current
hour setting is announced.
4 To change the hour setting, press and
release ror auntil
the correct hour is announced.
5 Press and release C. The current
minutes setting is announced.
6 To change the minutes setting, press and
release ror auntil
the correct minutes setting is announced.
7 Press and release C. The current
year is announced.
8 To change the year setting, press and
release ror auntil
the correct year is announced.
9 Press and release C. The new day,
time, and year are announced.
To check the clock, press and release
C.
Nov 14, 2007 | AT&T 1738 Digital Answering Machine
CLOCK & OVEN PROBLEM
How Ironic, we have a Moffat Discovery and exactly the same thing has happend, so we are waiting for a new Zanussi to be delivered.
As the clock timer is linked to the oven it will not light when the clock has broken.
Temporary solutions: So I turned all the electricity to the cooker off and left it a while, when I turned it on still the same problem, but after about 2 hours it comes back on, works for a couple of days then goes off again, (always seems to go out when my missus is planning to cook, so wondering if she' got something to do with it, don't tell her I said that though)
Now trying to switch the clock setting to stop or manual, and when it goes off i'll try and see if the oven lights,
HPC
Mar 03, 2007 | Zanussi ZCG7680 Gas Kitchen Range
48 people viewed this question
 Grubhead
Grubhead
