Question about Drills
I have a cast aluminium Vintage drill, the wiring on the motor is shot, where can i get a spare or should i try repair myself. can send photos
  • 2,760 Answers
If your referring to the actual wires inside the motor , then a electric motor shop might b able to help u
Posted on Dec 07, 2016
Testimonial: "Cheers thank you kindly. I have stripped the motor and soldered new connectors onto the copper wiring. If that doesn't work then I shall take your advice and go to a specialist."
Exhaust making noise took it to mec.and he heli coiled it,lasted about a month..whats next a new ccast iron head or alunium again
If the motor comes with an aluminium head as standard going down the cast iron head route may require a custom cast head unless someone already has them in stock but without knowing the motor make and model and year your best bet is aluminium head again
Jan 02, 2017 | Cars & Trucks
VS V6 valve timing position
Here is Holden\'s Alloytec V6 in glorious technical detail.
The global V6 engine is the first V6 engine program to address what Thomas G. Stephens, group vice president, GM Powertrain, says is a vital initiative: to develop world-class engines with fully contemporary features - such as dual overhead cams and variable valve timing - but at a competitive cost structure that allows use of the engines in a global mix of vehicles.
Exhaust: 111 degrees BTDC initial timing
50 crankshaft degrees retard authority
Compression Ratio:10.2:1
Bore Centers:103 mm
Firing Order:1-2-3-4-5-6
Fuel Shutoff:6,700 rpm
Engine Idle Speed:600 rpm
Fuel System:Sequential port fuel injection (returnless)
Engine Management:Torque-based; Bosch Motronic ME 9 32-bit micro-hybrid controller
Intake Manifold:Dual-plenum, equal-length with 2-position variable volume control (resonance tuned)
Throttle:68-mm single bore; electronic control (ETC)
Ignition:Individual coil-on-plug; individual cylinder knock control
Fuel Requirement:Premium fuel recommended
Emissions Controls:Dual close-coupled catalytic converters (1.15L ultra-thinwall ceramic)
Positive crankcase ventilation (PCV)
Intake- and exhaust-cam phasers (EGR)
Evaporative emissions system
Assembly Sites:St. Catharines, Ontario, Canada
Port Melbourne, Victoria, Australia
Material Applications
Block Material:Aluminium, precision sand-cast 319 with cast-in-place iron liners
Cylinder Head Material:Aluminium, semi-permanent mould 319
Intake Manifold:Upper: Aluminium, sand-cast 319
Lower: Aluminium, 356-T6
Exhaust Manifold:High-silicon moly cast iron
Camshaft Covers:Injection compression thermoset composite; vibration isolated
Front Cover:Diecast 380 aluminium; internal multilayer damping panels
Crankshaft:Forged steel
Connecting Rods:Sinterforged steel
Pistons:Aluminium, polymer-coated skirts, full-floating wristpins
Main Bearing Caps:6 bolt caps, copper-infiltrated sintered steel
Oil Pan:Structural diecast aluminium, steel windage and baffle plates
Additional features:Pressure-actuated piston-cooling oil jets
Extended-life sparkplugs, coolant, accessory belts
Cartridge-style, top-access oil filter
Oil-level sensor
Wide-range oxygen sensors
Aug 16, 2014 | 1998 Holden VT Commodore
Batterys charged, drill wont work at all, tried switch positions no change still not working
Your brushes are bad. The more expensive drills have removable vent covers on the back of the drill, one each side. Under them you will find a plate about the size of a dime. carefully move the plate around pulling it up. There will be a spring with a copper wire connected to a graphite looking block. This is your brush, sends juice to your motor. If the spring looks burnt or the brush is broken you will need to order a new set. If they look good you can try blowing the motor out with air. If you have a black and decker or skill drill the motor is not repairable. New brushes cost less than $10.
Feb 24, 2011 | Garden
I am trying to find a stapling machine capable of stitching some heavy duty cloth into an aluminium channel section. The legs on the aluminium are 1.5mm thick. Can you help?
Its not going to work you can;t staple aluminum mabey try a strip that over the cloth drill and pop rivit but nothing that i know of will shout throgh aluminum the staples aren;t stroung enough and wouldn;t hold even if you could get them through
Nov 22, 2010 | Stanley Heavy Duty Stapler, Cast Aluminum...
Can brushes be got ican only find complete motor
Try at : Power Tool Parts and Tool Repair Diagrams or - Your Tool Repair Supply seems some parts are discontinued.
Also at Metabo site:
Repairs and Spare Parts There are different possibilities for having your Metabo power tool repaired:
Contact us at 800-638-2264 or send us a fax to 800-638-2261 and we'll respond quickly to meet your needs.
Our office hours are Monday to Friday 8:30am to 4:45pm eastern time.
Or alternatively, e-mail us at
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 18, 2010 | Metabo SBZ18 18 Volt Cordless Hammer...
Dead DW972 Cordless Drill?
Easiest and safest: take the tool and batteries to nearest shop where they sell Dewalt. Ask the guy to let you use their batteries in your tool and vice versa, your batteries in their tool. DYI procedure:To check batteries: - if you have some multimeter, try to measure voltage and if possible also amps (but only for a fraction of the second, if battery is good, amperes shoudl jump up very quickly) - if you have no multimeter, try to find 12V bulb (check spare bulbs for your car), use wire to connect and it should light up. To check tool: open it up, take some 12V DC source, put wires on contacts inside the handle where battery connects. Pull the trigger and it should work. you can try to put wires directly to contacts on the motor. Follow cables from the switch to motor.
May 31, 2010 | Dewalt 12V XRP Battery Pack
Front Loader Washer Door Hinge broken
There are a couple of sites you can try.
Please rate my solution.
Feb 06, 2010 | Bosch Washing Machines
The drill smokes from the body area when drilling, but does work. Should i take it in for repair or can i do something myself?
It sounds like the motor is burnt up, give me the model number and brand and I will try and find a schematic that will help you. They are not that bad to repair just watch how everything comes apart and pay close attention to the wiring of the switch, it is polarity sensitive.
Jun 12, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Photos come out orange-brown
please try resetting your camera to original factory settings..
May 24, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
New ram for quinny buzz
Be sure it is the gas ram and not the cast aluminium anvil which the gas ram pushes against. The symtoms are similar
This 'L' shaped casting snapped in half on our Quinny Buzz and I managed to repair it by taking the whole centre hinge apart, drilling out the pin which holds one half of the aluminium anvil in place and removing this striaght piece of the anvil.
To repair I first glued the two parts together with araldite then held them in the vice whilst drilling through both pieces to a depth of about an inch with a 4mm tapping size drill. Then seperate the two parts, tap the shank out 4mm and drill the right angled bit 4mm clearance. Reconnect the two parts using a 4mm steel screw and some 'locktight'. Replace the anvil in its slot and replace the holding pin securing with araldite.
Reassemble the whole shooting match and it works ( well ours did....and still does!)
This seems to be a common problem but I could not find any spares. Also the holding pin for the anvil is not made to come out hence having to drill it out. So I doubt if any spares are available anyway.
Not easy and you need a few engineering tools to do the job. But much cheaper than a new frame assembly.
Jan 08, 2009 | Quinny Buzz Jogger
Drills Logo
148 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
