Question about John Deere Garden
What size bar and chain should go on a John Deere CS56 pro saw?
  • John Deere Master
  • 14,405 Answers
Here's a link on your chain Brad. Chain Size of the John Deere CS56
Posted on Dec 10, 2016
  • 211 Answers
SOURCE: interchange smaller bar & chain for existing chain saw
Yes you can(better for the engine).For14" the part number is 52 and for 16" is 60.
Posted on Nov 29, 2008
SOURCE: poulan pro series chain saw 20" bearings seizing up on bar
There's a tiny hole on the front of the bar near the bar sprocket. This is used to grease the sprocket. If you go somewhere like Lowe's look in the chainsaw section and you'll find a grease tube that is specially designed to lube the front sprocket. Before lubing use a small wire to clean out any debris from the whole. Press the lube tube against the hole and push repeatedly until grease comes out from the outside of the bar. This should greatly extend the life of the bar.
Posted on Jan 09, 2009
SOURCE: need true chain/bar size for my husqvarna Model 254 chainsaw
Maximum bar size of 20" but would recommend 18", if it is running sluggish, check compression, if low replace the piston, if it is 135psi or more then make sure the airfilter is clean and then tune the carb and make sure you get good revs and throttle response throughout the rev range, use the typical carb adjustments from the owners manual from the Husky web site. This is a 5hp saw and is capable of cutting some big lumps of hardwood so no excuses on the power front
Posted on Mar 16, 2009
  • 82 Answers
SOURCE: What size chain does the Poulan Pro 4218 use?
It is an 18" chain .The user manual is at
On page 6 the part numbers for the bar and the chain are shown
Hope this helps .. if so, pls leave feedback, if not - let me know!
Posted on Jan 25, 2010
  • 4088 Answers
SOURCE: chain won't stay tight on my poulan 222 pro. I
No, the bar fasteners are not tight enough. If the saw is under warranty, take it to a servicing dealer for repair or instructions to correct what you are doing wrong. Good luck!
Posted on Jul 17, 2010
Why does my john deere chain saw leak a lot of bar oil after i get done running it?
There bar oil seal is not that great it wears out right away and leaks instead of squirting oil when you pump it.
Don't worry 80 % of all chain saw leak sooner or later. Just put oil when you use it then drain it when you store it.
Oct 19, 2014 | Garden
Need gas cap for john deere 40v chainsaw
Take your saw to a lawn and garden shop that repairs chain saws. They should be able to help.
Aug 07, 2013 | John Deere 28 30 40v 50v 55v 60v 70v 80ev...
I am trying to find out the bar and chain part number I was given a John Deere J3816 chain saw with no bar and chain. do you know what the part number is?
Organ makes a replacement combo bar/chain for the j3816. Part # is 105700. You should be able to find it in most stores like Lowes or Home Depot. You could also go on line to Hope this helps.
Nov 07, 2010 | Homelite ZR10926 16 Chain Saw
What part number oregon chain do i need for a cs-52 john deere saw. They keep sending me the wrong john deere chain witch is three links short. thanks Vern.
Hello Sam;
I cannot find anything by Deere (probably an efco 152) about your saw. Oregon does list some particulars here:
Oregon Bar & Chain Selector
I input:
John Deere; CS52; *see below; All (0.325"); All (0.050"); All (yours is likely green - low kickback).
*16" - 66 drive links (the part that fits in the bar).
*18" - 72 drive links.
If your saw does not use either 66 or 72 drive links I suspect the bar, drive sprocket, or drive sprocket and bar nose in use are not what the the saw was originally supplied with. Any local chainsaw seller/mechanic given your chain as a pattern can fabricate one in about 5 minutes. Often a local chain is less expensive (no shipping).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Thank You for using FixYa.
Sep 07, 2010 | John Deere 16" Chain Saw Chain (Oregon ...
Chain won't stay tight on my poulan 222 pro. I have the correct chain size. Does the bar need to be replaced?
Jul 16, 2010 | Poulan Pro Chain Saw 46cc 20"
My saw say on the side pouland 305 pro so how many cc is it
a pouland pro is a (low h.p. saw) and at 46cc i wouldn't run bigger than an 18 inch bar , its asking to much from the clutch and motor
May 03, 2009 | Poulan Pro Chain Saw 46cc 20"
McCulloch Pro Mac 610 replacement chain
The McCulloch ProMac 600 series (610/650) doesn't recommend a saw chain replacement part because you can get differently-sized bars for it. This one came with a 20" bar.
According to an search tonight, the Oregon company makes a replacement part stock number D70. I have got an Oregon H78 replacement chain at my hardware store and it's a hair too small. Not all 20" saw chains are created equal!!
Dec 07, 2008 | Oregon Scientific Oregon S54 Replacement...
Garden Logo
89 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
