Question about Craftsman Garden
My craftsman lawn mowers (model #917.274751) starts and run for about 45 second before it cut off.
I have change fuel, air filter, spark plugs and a new carburetors.
    Top Expert:
  • Craftsman Master
  • 77,932 Answers
Does it loose spark when it stalls out, that would b the most common issue.
Posted on Dec 07, 2016
Yard machine riding lawn mower
The dead-man switch on the lever (that you have to hold in to keep it running) has a loose connection or you have a loose spark plug wire.
Aug 18, 2014 | Yard Machines Garden
Craftsman riding lawn mower won t cut grass
Does it die when you attempt to engage the cutting deck? If so the you might have a clogged fuel filter, bad gas, dirty air filter, bad spark plug.
Or the mower engage switch may be faulty. They are located in different places on different mowers. But should be attached somewhere along the main pivot of the engage lever. Let me know if you need more assistance. Good Luck!!
Jun 05, 2012 | Craftsman Garden
My mower will run for about 30 minutes then die and then have to wait for awhile and process starts all over. i have changed oil, spark plug, plug wire and coil, fuel filter, air filter and screen,...
Try this.
When the mower is about to die, loosen the gas cap.
My mower gas cap vent holes plugged up and kept stalling the mower.
If it works, drill out the vent holes.
Jun 27, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17hp 42" cut riding
Sounds like its not getting enough fuel. clean the fuel system and the carby. The valve clearances also need to be checked.
Apr 07, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My Craftsman 15.5 hp 42 in deck lawn tractor starts up and will run for few minutes, then cuts out really bad and dies. I have installed a new spark plug, new fuel filter, cleaned the air filter, and...
Sounds like dirt or water in your fuel system. Have you drained the bowl on the bottom of the carburator? There is a small bolt on the bottom of the bowl; be careful not to over tighten it. If you find anything but fuel in the bowl you may need to drain your tank as well.
Apr 29, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have two craftsman lawn mowers that will no start. Both have new plugs and are sparking. Changed air filters and oil. One will start for a couple of seconds then stops. When I kept priming it, it stayed...
it sounds like you have compression but the fuel air mixture is out of setting. This could be due partialy to a stuck fuel needle or mixture needles that are worn or out of allignment. If you could give me the model # on the unit i could help with the type of carb and the inital settings on the mixture needles.
Dec 24, 2009 | Craftsman Garden
Motor runs for 5-10 min. then starts missing and quits.
Check your spark first,if you do not have spark your problem is the coils-if you do have spark the problem probaly lies withone of your valves getting stuck after getting hot and soonas it cools down a little it closes and then you can restart it till it gets hot again.Hope this helps
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
43 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
