Question about Cameras
I am trying to start a 400 dayskoma w5 made in germany matel clock,it spins for 4-5 minuts athan stops. any ideas?
How to get started the koma 400 w5 clock made in germany
  • 1294 Answers
SOURCE: Error F11
Plug off the wall. Shaking & vibration of your washer causes circuit board connections to become loose; due to faulty manufacture. Remove the 3 or 4 screws from the back & take off the top cover to secure the connections, make sure they are tight. This applies for the F11 & F dl codes. Works for certain machines, dont see why it wont for yours.
Posted on Dec 25, 2007
  • 1796 Answers
SOURCE: '95 ES 300, runs engine stops, wait 20 minutes,
Hi!!
It seems that you fuel pump is giving up. Check fuel pump pressure (45psi cranking). Borrow a tester from AutoZone, Checkers or similar Auto Parts store.
Good luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Dec 03, 2010
rickead1
  • 1998 Answers
SOURCE: While doing a wash in the Cabrio, the countdown
Have you checked the drain line and the pump to assure there is nothing stuck or blocking that water from leaving the unit if the water is unable to totally drain it will go back into the cycle to try to remove all the water. Also do you have any error codes showing usually with something caught in one of the drain lines or in the pump you will not get an error code and it will do the things that yours is doing try removing the cabinet and checking the pump if you have any further questions message me back and please remember when our chat has concluded to rank how this opinion has helped Thanks again Rick
Posted on Jan 07, 2011
KevinWhite
  • 1902 Answers
SOURCE: Whirlpool 9KG HDWM1100 which will
Hello & Welcome to FixYa
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Sep 06, 2011
skychief2001
  • 21873 Answers
SOURCE: I have a 96 Honda Accord Ex automatic. The car always starts the first try everyday. It's when I stop and turn it off it sometimes won't restart. If I wait 2-4 minutes it will start. Any ideas???
Honda cars are known for problems with the fuel pump relay.
The relay fails after the car is run, and the interior is warmed up.
The relay is located under the speedo on most models.
Posted on Apr 09, 2015
How to start a 400day koma clock
Anniversary (400 day) clocks can be monsters This link should help you out:
How to set up an Anniversary clock
Dec 07, 2016 | Home
How to start clock going
Setting up anniversary clock can be a monster, this link should help you out.
Oct 09, 2016 | Home
Atv trouble shooting
poss overheating--carb needs rebuild--or need tune up
Jul 14, 2017 | ATVs
Broken clock
Sounds like it is trying to locate the satalite to recognize the time zone. Have you tried moving the clock to another location in your building?
Sep 13, 2013 | Bosch Ovens
I have a forestville wall clock with the pull down weights. when it chimes it is behind in time. example nine oclock chimes seven oclock, it is a made in germany clock but what year i do not know. there...
Stop the pendulum of the clock exactly at any even hour. Lets say at 6.00. While clock is steady and not working, pull off the minute and hour hands off the pinion, but do not brake them. You have to pull without any twisting action. This will leave pinions exactly in place they were when you stopped the clock. When it is done - push the hour hand back onto the pinion and make sure it is pointing at 4 (not 6, as it was when you stopped the clock). When hour hand is back in place and pointing at 4, push back minute hand as it was when you pulled it off - pointing at 12. Make sure hands will not catch when passing each other (you can bend them slightly if needed). Now swing pendulum to start the clock and adjust time (clockwise only). Never adjust time when clock is chiming. Rate me, plz.
Feb 02, 2010 | Watches
Don't know how to properly wind Elgin 400 day anniversary clock
Wind the clock until there is a sudden increase in resistance (it is then fully wound). So not apply a great force, as older clocks may be weaker and overloading the spring may break the termination and result in a new spring being required.
If you think it is becoming too stiff, just stop winding and see how long it runs for. I have often heard the term "over winding at clock" but have never quite understood the term. As a retired engineer I think that springs that break because of overenthusiastic winding are probably near the end of their life anyway.
Jan 13, 2010 | Watches
Hands started spinning and won't stop. I replaced battery - still spinning
Remove the battery and replace with a new one. Just because.
Depress the tab on the back of the clock mechanism firmly (it pushes in a button beneath it) 22 times. While you're pressing the tab, the hands will begin to rotate. They will stop at 12 , 4 or 8 o'clock.
Place the clock in a window where it will be able to receive the radio signal.
Next morning the clock should have re-set to U.S. Pacific time. Press the on the clock mechanism that corresponds to your time zone and you should now have the correct time again.
May 24, 2009 | La Crosse Radio Controlled Atomic Clock
Dryer won't start. Pressing "Start" button just emits 4 beeps.
does the drum turn? if it doesnt you can assist it and see it that is problem, have to remove top and push it. that would be capacitor on motor or jumper the door closed switch and try to spin.
Apr 21, 2009 | Dryers
M7VIG-400 NOT POWERING ON
possible cause: 1.low supply of voltage try checking your Power Supply Unit(PSU). try to swap with a different good PSU. 2.Defective/burned Motherboard, check for any bloated Capacitors or burned chips...
Sep 09, 2007 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
