Why the Device Cannot Register After the reboot member Command Is Executed for HGMP?
    Habit-Forming:
    Scholar:
  • 78 Answers
After the device executes the reboot member { member-number ' mac-address mac-address } eraseflash command, the specified member switch restarts. The configuration file specified for the current startup is deleted on the member switch; therefore, the configuration file is lost and the member switch cannot register. Exercise caution when you use the reboot member command.
The V100R006C05, V200R002, and later versions do not support the HGMP feature.
http://www.thunder-link.com/S5720-SWITCH_c156.html
Posted on Dec 07, 2016
How to register my amazon fire stick
Make amazon account on Your Account
To register fire TV
    -Select settings from fire TV menu
    -Go to my account (if your device isn't registered, register option will appear. Select register and enter amazon account information when prompted)
Jun 16, 2017 | Amazon Tablets & eReaders
Can Rate Limiting Be Configured for an Eth-Trunk on a Modular Switch and How Can the Configuration Take Effect?
The modular switches(such as S2309TP-EI-AC) support rate limiting for inbound traffic on an Eth-Trunk. This function can be configured using the qos car command. After this command is executed:
· If the member interfaces of the Eth-Trunk are located on different LPUs, the configured rate limit applies to each interface individually.
· If the member interfaces of the Eth-Trunk are located on the same LPU, the member interfaces share the bandwidth specified by the rate limit. The bandwidth is distributed on the member interfaces randomly.
Jul 25, 2016 | Office Equipment & Supplies
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
How do I get out of DOS mode on my Macbook Pro?
The Mac does not have a DOS mode to turn off.
It does have a command line mode called 'Single User Mode' where UNIX commands can be executed. Get into SUM by holding Command S at startup.
To go back to the Mac OS X interface, type 'reboot' and press the Return key.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 06, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
How do i turn off DOS mode??? on a mac...
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 02, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I can't clear cancel a document waiting to print
In Windows, if cancelling the print job does not work, the command prompt can be a very useful tool. Go Start button, All Programs, Accessories, Command Prompt (if standard user, right click and run as administrator) (These are for Vista and Win7, XP is similar and older were similar)
Type "net stop spooler" without the quotes and hit enter. When a new prompt appears, type "net start spooler" (again without the quotes and hit enter). You can also do these one line at a time: Start Run and the two phrases. Once the commands have executed restart the computer.
If you only type the first line and then reboot, plan on taking a coffee break before the command finishes processing on the restart.
I hope this helps.
Feb 27, 2010 | HP Office Equipment & Supplies
Error code when copying... C6103 on Bizhub C451
C6103 - Scanner overrun failure
The Scanner Home Sensor detects the Scanner at its home position during a period of time that begins with the time when a prescan command
and a scan preparation command are executed and ends when a home return command is executed.
Apr 14, 2009 | Konica Minolta bizhub C450P Laser Printer
What is the Command to check the connectivity of the router?
The command to ping the router is ping 192.168.2.1. Both are to be executed from a command prompt.
Feb 19, 2006 | SMC Barricade Turbo Router
Feb 19, 2006 | SMC Barricade 7004
Feb 19, 2006 | SMC Barricade 7004 Router
Computers & Internet Logo
134 people viewed this question
David Payne
David Payne
