At a time 2 page continously pickup - Office Equipment & Supplies
    Top Expert:
  • Office Equip... Master
  • 8,204 Answers
Try to separate the paper before putting it in the printer if paper is left sitting for too long they tend to stick together...
not saying this is what is happening to your printer but try it out.
Posted on Dec 07, 2016
Are paging services expensive to use?
Paging plans are pretty expensive at around $40 a month and have a limit on how many pages you can send.
Nov 04, 2013 | Radio Communications
Chevy pickup 1500 1994 heater control insturment pannel blinking
think it means the heater control is bad.. most likely no fix. replace
Mar 24, 2013 | 1994 Chevrolet K1500
I have a HP Scanjert N6010 that will not scan more than one page at time. If you even put in two pages it will pull both through at the same time.
The Main Problem I have found when it pulls through more than one page at a time is if the pages were stapled then the staple holes will pull all the pages together.
There is one big pickup roller in the middle of the scanner if you open the front flap, remove theat pickup roller and clean with some computer foam cleaner and a lint free cloth or a screen wipe and reboot the scanner.
Kind Regards
Aug 22, 2010 | HP Scanjet N6010 Photo Scanner
I have a continous smudge on the right side of the page when printing on a 2420dn. I have replaced the cartridge with no success.
Your Fuser Film is the most likely cause. These do more often than not, fail prior to the fusing unit needing to be replaced. The test for this is to print a page then shut the printer off when the page is about 1/2 way thru the printer. Just kind of time it from the time it feeds the paper to when the paper exits the printer. Cut this time in half and use that as a guide to when to shut the printer off. Once you do this open up the printer where the toner cartridge is and remove the cartridge. If the page is about 1/2 printed then look at the edge where the smudge usually is. If it is not there then you know it is the fuser. You can either order in a new fuser unit or see if a local repair company will do just a fuser film for you. This is what I do. The fuser film plus labor is about $100.00
The fuser unit plus labor is around $250
Also if the fuser is at fault you will sometimes see part of the image from the top part of the page will get reprinted farther down the page in the area where the smudge is.
Good Luck and Thank You for using Fixya.
May 20, 2010 | HP LaserJet 2420 Printer
Microline 391 okidata continous feed leaves a page of space
We have downloaded the manual and will see if we can figure it out.
Apr 05, 2009 | OKI MICROLINE 390 Turbo Matrix Printer
Pulls 2 sheets every time
Drive clutch of the paper pickup roller. It sticks.
Dec 05, 2017 | Samsung ML-1450 (Open Box) Printer
Printing problem with HP Laserjet P2015 printer
This can be an issue with one of the faulty sensor across the printer.
Please check if you are able to print from tray 1, e.g. a configuration page.
A config page can be printed by holding the Green Button and releasing it as soon as the Triangle light comes on. This would take approx 5 secs.
If the printer is able to print from tray 1, then it could be an issue with the tray 2 pickup sensor.
Check if the tray 2 pickup sensor ( a black plastic piece to the right of the tray 2 pickup roller) is moving freely (front and back), also check if tray 2 pickup roller is not able to rotate completely.
If the tray 2 sensor is not moving freely and of the pickup roller is rotating completely, then reseat the pickup roller.
Normal use with good media causes wear resulting in the need to periodically clean or replace the pickup roller. Additionally, the use of poor media might require more frequent replacement of the pickup roller. Replacing the pickup roller Complete the following to replace the pickup roller:
CAUTION: Failure to complete this procedure might damage the printer. Unplug the power cord from the printer, and allow the printer to cool.
Figure 1: Unplugging the power cord
2. Open the print cartridge door, and remove the print cartridge.
Figure 2: Removing the print cartridge
3. Remove the main input tray (Tray 2).
Figure 3: Removing the main input tray (tray 2)
4. Open the front automatic two-sided path door (HP LaserJet 1320 series printer only).
Figure 4: Opening automatic two-sided path door
5.Place the printer on the work surface with the front of the printer facing up.
Figure 5: Placement of printer
6. Pull the white tabs outward, and rotate the tabs up.
Figure 6: White tabs
7. Slide the right tab to the right, and leave the tab in this position throughout the procedure.
Figure 7: Right tab movement
8. Slide the pickup roller assembly to the right, and remove the left end cap.
Figure 8: Pickup roller assembly movement
9. Remove the pickup roller.
Figure 9: Pickup roller
10. Insert the left side of the new pickup roller into the left slot (1), and insert the right side (with notches in the shaft) into the right slot (2).
11. Rotate the shaft until the notches engage and the shaft clicks into place. 12.Place the end cap over the shaft on the left side, push the end cap to the right, and rotate the tab downward into position.
Figure 11: Pickup roller end cap
13.Push the right tab to the left, and rotate the tab downward into position. 14.Place the printer on the work surface with the top of the printer facing up. 15.Close the front automatic two-sided path door.
Figure 12: Closed automatic two-sided path door
16.Reinstall the print cartridge, and close the print cartridge door.
Figure 13: Print cartridge
17.Plug the printer in to turn it back on.
Figure 14: Power cord in
Cleaning the pickup roller
Perform the following to clean the pickup roller.
1.Remove the pickup roller as described in steps 1 through 9 of Replacing the pickup roller above.
2. Dab a lint-free cloth in water, and scrub the roller.
Figure 15: Scrubbing the roller
3. Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt. Figure 16: Wiping the pickup roller
4. Allow the pickup roller to dry completely before you reinstall it in the printer (see steps 10 through 17 of Section with a task ).
Figure 17: Reinstalling the pickup roller
Oct 27, 2008 | HP LaserJet P2015dn Printer
Paper is 8x7
The User guide is available on the Epson web site.
Essentially, this suggests (page 2-9) that you turn off, leave for 5 seconds min, and turn on holding the Tear off(Font) button. Press this button once and select the language, then press it again to print the settings and instructions for changing them. Set the printer to tractor-feed and your required length and you're away (turn off after).
Sep 12, 2008 | Epson LX-300+ II Matrix Printer
Message Light flashing continously
Resetting the New Message LED
If the LED remains on after you’ve retrieved your messages, you may need to reset
the indicators. With the phone is in standby mode, press and hold find handset on
the base until the paging sound stops (about 5 seconds).
Dec 12, 2006 | Uniden TRU8865-2 Expandable System...
Continous shooting with D100 - it doesn't work...
Mine too. It's a worn-out selector switch. Jiggle it and it'll work again. Time delay same. Our college has four Nikon D100s with this problem. Poor switch contacts.
Dec 03, 2006 | Nikon D100 Digital Camera
27 people viewed this question
