When my scansnap S1500 stopped working, I tried to reinstall the software getting "You do not have write authority for the installation folder. Make the selected folder writable" ?
  • 5 Answers
SOURCE: "Failed to initialize the sRGB engine" - ScanSnap won't work at all :(
not download just tell me serial number.
Posted on Sep 19, 2008
SOURCE: Won't install ScanSnap Manager
The CD is defective. Get another CD and try it. I was having the same problem. I browsed the CD because I wanted to install just the Scan Snap manger. I discovered that the CD ROM could not read that part of the disk, so I tried the installation from another CD disk, and it worked like a charm.
Posted on Oct 23, 2008
  • 4 Answers
SOURCE: PFUSSMON HAS STOPPED WORKING ON MY SCANSNAP S1500
Find your specific scansnap product and update it:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/downloads.html
A user had a similar issue and I found this update for the scansnap S1500 manager:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/s1500.html
This occurs with certain Intel dual core processors, so you might be effected accordingly.
--Rob
Posted on Aug 14, 2009
SOURCE: I installed ScanSnap on Windows 7 under the
OK; after giving up on lousy tech support I got it working after doing the following (not sure if all required, but this is what I did)
1. Gave admin rights to C:\Program Files (x86)\PFU
2. Updated to latest ScanSnap Manager V5.0 L21
3, Copied C:\Users\<admin acct>\AppData\Roaming\PFU directory to C:\Users\All Users
Good luck...
Posted on May 10, 2010
SOURCE: My Fujitsu scansnap s1500 just started to streak
Wipe the glass strips inside with a scratch free cloth (both pieces).
Posted on Jun 09, 2010
Drivers for s1500 not installed
http://www.fujitsu.com/global/support/computing/peripheral/scanners/software/s1500.html
Go here for the drivers, depending on your OS, select the proper install. make sure to check to see if you will need to also install the update found in the Update tab (windows 7 + usually)
Oct 21, 2013 | Fujitsu ScanSnap Manager
Scansnap error 0x80210026
Hi There
1.Have you logged in with an administrator account?
2.Was it working fine earlier?
3.Were there any recent changes made on the computer prior to the issue?
You may receive this error if you don't have the appropriate permissions to use the scanner.
Let's try these methods and check if it helps.
Method 1: Install ScanSnap Manager Update (S1500) and check.
Method 2: Disable security software and check.
http://windows.microsoft.com/en-IN/windows7/Disable-antivirus-software
Warning: Antivirus software can help protect your computer against viruses and other security threats. In most cases, you should not disable your antivirus software. If you do have to temporarily disable it to install other software, you should re-enable it as soon as you're done. If you are connected to the Internet or a network during the time your antivirus software is disabled, your computer is vulnerable to attacks.
Method 3: Uninstall and reinstall ScanSnap and check.
http://www.fujitsu.com/downloads/IMAGE/manual/trouble/p3pc-3792-03enz0.pdf
Aug 12, 2013 | Computers & Internet
When I try to scan, I get "Undefined error occurred (0x80004005). A probable cause is that the system is unstable. Reboot the system. If this does not resolve the problem, contact the store where you...
I just fixed it. Uninstall the application by choosing applications and finding scansnap. Drag the folder to the trash. power down your scanner and unplug the USB. Go to the Fujitsu website and download the software again and reinstall it. Plug in the power and USB into your scanner and everything should work fine.
Jul 03, 2011 | Fujitsu ScanSnap Manager
My scanner keeps flashing and not pulling the paper through, I cannot seem to figure out why it will not scan. It does this quite often, what is the problem that is causing this? Scansnap S1500
Go to msconfig or if you have a registry cleaner, go to the startup menu. Disable and ssmgr (scansnap manager in pfu). Reboot. Open the ScanSnap 1500 and then start the ScanSnap manager. The scanner is now ready to scan.
Jan 26, 2011 | Fujitsu ScanSnap Manager
Have just installed S1500 software and finished the installation but get an error message "Failed to initialize drinver module (0 X 80210019)". What does this mean and how do I proceed? ****
Try the following step :
Pre-Installation Steps
  • Log onto PC with an account that has Administrative Privileges.
  • Disconnect ScanSnap scanner, if connected.
  • Close any open applications.
  • Install ScanSnap Manager, ScanSnap & CardMinder software from the ScanSnap Setup CD-ROM.
    • Upon reboot of the installation you may receive an error message stating, “Failed to initialize driver module.” Please disregard and continue.
ScanSnap fi-5110EOX Vista Update Pack Installation Steps
  1. Download the fi-5110EOX Update Packs (Vista 32-bit Support)
    1. ScanSnap Manager V3.0 – ssv3020up.exe
    2. CardMinder V2.0L10-V2.0L11 – cm2012.exe
  2. Install all two update packs that were downloaded in Step #1.
    1. Reboot is NOT required after each update pack.
  3. Reboot the PC after all three update packs installed completely.
  4. Connect ScanSnap Scanner via USB, open lid, let Windows Vista install the new hardware.
Mar 07, 2010 | Fujitsu ScanSnap Manager
--Rob
Jul 08, 2009 | Fujitsu ScanSnap Manager
ScanSnap Manager - Error!! You do not have a write authority for the installation folder.\nMake the selected folder writable.
Normally this error will only come up when you have already tried installing the Scansnap Manager.
Go to C:\Windows\SSDriver. Right click the folder and select properties, select the security tab, then make sure "Users" has full control.
Repeat these steps on the PFU folder in Program Files.
Put in the Scansnap disk and navigate to the Tools folder. Run the SSCleaner tool and delete all of the Scansnap components.
If Scansnap Manager is not listed in the Cleaner tool, Delete the contents of the SSDriver and PFU folders manually.
Restart the computer and reinstall the components.
May 14, 2009 | Fujitsu ScanSnap Manager
Fujitsu ScanSnap S300 PfussMon has stopped working
--Rob
Apr 09, 2008 | Office Equipment & Supplies
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
