I have an All Pro torpedo heater. I changed out the thermal coupler. I held in the igniter button for 60 secs the unit would fire up. After I release the button the unit would turn off. Please help
  • Heating & Co... Master
  • 2,458 Answers
Check the flame sensor is clean and in the right position and that the pressure switch is not blocked
Posted on Dec 07, 2016
  • 2,760 Answers
Does the airflow switch work . ???
Buffalo12980
  • 625 Answers
SOURCE: forced air propane heater won't stay lit
two items come into play here - 1) the hot surface cutout and 2) the flame detect Cd cell. Check alignment of the Cd cell or just replace it. The hot surface cutout has two terminals that plug into the two tabs on the millivolt generator.
Posted on Aug 22, 2007
  • 3 Answers
SOURCE: Dyna Glo Pro RMC-KFA70TDGP 70,000 BTU Torpedo heater not igniting
The main circuit board supplies ac power to the ignitor ( black transformer looking device) and the transformer increases the voltage that is supplied to the sparking device. Make sure the wires are connected to the sparking device and the ends of this device are approximately 3mm apart and that it is in the general position near the end of the nozzle. If you do not hear a "clicking" sound it could be the main board, wires or sparking device.
Posted on Dec 17, 2008
SOURCE: Thermal coupler
I switched the two lead wires of the thermal coupler around, the ******* who installed it had them backwards, afterwords i held the button down and it stayed lite with a normal sized flame>..... Good Luck
Anthony
Posted on Dec 19, 2008
SOURCE: remington 60 portable forced air heater 60,000 btu
I had the same problem. I took the nozzle head off and blew through it with air. I also blew through the air line, this is the one that goes to motor. It has worked fine ever since.
Posted on Jan 16, 2009
zonaluver
  • 7 Answers
SOURCE: Torpedo heater wont stay lit.
Do you have the serial number or the manufacture date? There are some design changes and I would need to know the year of manufacture to assist accurately. Usually it is a relay or the thermocouple connection that will affect the unit staying lit.
Posted on Mar 29, 2009
Cant getpilot light on in gas fire
does the pilot light stay on if you hold down the pilot light button and it goes out when you let go after 20 sec? if so change your thermal coupler.
Feb 13, 2015 | Heating & Cooling
When you release start button it quits
this unit like most has a heat switch and a thermal coupler they work to gather jump the switch if it runs then its the switch if it doesn't then its the thermal coupler flame should hit the coupler and turn red loose wire on switch has happened before to
Dec 04, 2013 | All-Pro SPC-85 Utility Heater
Igniter doesn't fire or spark. What do you suggest?
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 06, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
I 50,000-85,000 All Pro Propane heater release red button fireout
If the red button has to be held down for a period of time to get the heater going it overrides the shutoff mechanism. If you are holding it the prescibed amount of time then either the hydraulic system which keeps your unit running is bad or out of place or the metering valve is bad. Check for a copper line with a bulb on the end. It should probably be in the fire created by the heater, if not bend it to be in the heat or very close. If this is ok then you may need to get a new burner for the unit which would probably mean buying an entire new unit as the cost would probably exceed the cost of a new unit. Let me know how you make out.
hardrocko
Feb 07, 2010 | All-Pro Propane Garage Shop Heaters - All...
How do i install a thermal coupler for forced air heater gas
Thermo coupler is held in place with a clamp bracket at the pilot end and a small brass line nut on the other end going into the gas valve.The pilot flame must surround the sensing bu or wrap itself around it Press the pilot button for a few seconds and fire up the pilot flame. Wait a few more minutes and turn the gas vale on for the main burners. If it fires, your set.Good Luck,Ned
Jan 15, 2009 | Reddy Heater RLP100 Portable Forced Air...
Unit fires for 30 to 45 sec then cuts off
heatman101
Jan 13, 2009 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
