Question about Sylvania Televison & Video
Popping sound around bulb sylvania tv sst4323
    Top Expert:
  • Sylvania Master
  • 75,417 Answers
EHT arcing. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result will display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Posted on Dec 07, 2016
2 Suggested Answers
  • 8909 Answers
SOURCE: can you go to Video
In a word, no.
Posted on Dec 17, 2010
How to get this remote control to turn the 2004 Sylvania TV on/off
There is a fault with the remote control and it is not worth trying to fix it and not worth replacing the stock remote control unit even if the manufacturer could still supply one for that TV.
The best option is to just buy a very basic generic remote control (quite inexpensive) from an electronics store which will work with many TVs and use that remote to turn the TV on and off. Use your stock remote for all other functions if it is still working well on those functions.
I had a friend with the exact same problem with her stock remote a while back. I purchased a simple generic remote control on special for around $20 which she now uses to turn the TV on and off. .
Nov 21, 2015 | Sylvania Televison & Video
Sony grand wega kf-50we610 red lamp light blinking
The red light means that the prjection bulb needs to be replaced. They ony last about two years depending on hours of use. The low popping sounds as well as fan noise is normal for the Sony projection TV. You can Google the owners manual by entering the brand,model etc. and ask for the owner's manual. I had to go to several sites but eventually found it.
Jun 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
TV made popping sound and then shut off
You need to look in your owners manual for the telephone number and order a new bulb. It should cost about $200, but they will ship it overnight and minimize your downtime.
I've replaced 2 in my WD-52525 in the last 3 years, the first one went like yours did, very suddenly, with an audible POP!! The second one was preceded by an orange warning light, which the book says is a warning that the bulb has about 20 hours left on it.
To replace the bulb, UNPLUG THE TV, remove the left speaker screen, with a philips screw driver unscrew the bulb, pull it out by the handle, then replace it with the same type, in reverse order. This is a very easy replacement that does NOT need to be done by a service technician to complete.
Dec 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I have a rca312w control and the codes to program my sylvania tv
Try these codes 0054 or 0030
How To Program Your Remote Control
  1. Turn device to be programed on.
  2. On the remote control, press a device key one (e.g., AUD, VCR, TV, or CBL). Press and hold SETUP until the selected mode key blinks twice, then release SETUP.
  3. Locate the four-digit code found in the list below that corrisponds with the device you are programming then enter that four-digit code. If performed correctly, the selected mode key will blink twice.
    (NOTE:If the selected mode key emits a long blink, the code is invalid. Repeat steps 2 and 3 and try entering the same code again.)
  4. Aim the remote control at the device ad press POWER once. The device should trun off. If it does not, repeat steps 2 and 3, tryin each code for you brand until you find one that works. If it still does not work, try searching for the code.
  5. Repeat steps 1 through 4 for each device you want the remote control to control.
Nov 11, 2008 | RCA 3-Device Universal Remote with...
Desconectar
Decime el modelo de tu televisor tiene que ser un numero como este
Sylvania SST4324S 32"
Sylvania SST4324A 32"
Sylvania SST4324 32"
Sylvania SST4323 32"
Sylvania SST4322 32"
Sylvania SRT2432S 32"
Sylvania SRT2432P 32"
Sylvania SRT2323 23"
Sylvania SRT2232X 32"
Sylvania SRT2232S 32"
Sylvania RSET432E 32"
Sylvania RSDCT3203 32"
Sylvania LD320SS8 32"
Sylvania LC320SS8 32"
Sylvania C6432TE 32"
Sylvania C6432TD 32"
Sylvania 6632LG 32"
Sylvania 6632LCT 32"
Sylvania 6432TFY 32"
Sylvania 6432TF 32"
Sylvania 6432TE 32"
Sylvania 6432TD 32"
Sylvania 6432GG 32"
Sylvania 6432FE 32"
Oct 19, 2008 | Air Tools & Compressors
Sparking, popping
power house is fried these at times tend to go out but this time it might have had a little help animal or bug crossing or chewing on wires
i know alone on cost for the bulbs is around 300 to 400 dollars gotta estemate right around these odds for the power house price is around 200 parts and labor high voltage conductors
May 10, 2008 | Philips 51PP9200D Television
Problem with sylvania 6413TC 13"tv
This is a runaway high- voltage condition. When the TV turns on, the high voltage goes out of sight, causing the snapping or popping sound. Then the high voltage shutdown circuit takes hold, and the set cycles on and off repeatedly.
Dec 20, 2007 | Sylvania 6413TC 13" TV
Televison & Video Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
