Question about Inverter Heating & Cooling
How to clean gree inverter aircon - Inverter Heating & Cooling
Kolin inverter window type aircon shut down with FO code
when you post the same question more than once in a few hours most here tend to ignore them. once is enough. when someone who knows the answer comes on maybe youll get lucky.
Jan 28, 2018 | Inverter Heating & Cooling
How to fix H5 error
Ipm is inverter protect. Replace PCB (printed circut board)
Oct 12, 2016 | Gree 18000 Btu 20 Seer Ductless Mini Split...
Gree air conditioner error codes HC
I have also use GRE ac inverter but today my ac on running sundunly show (HC )Main screen
Plz information this system
HC maens what's problem
Aug 19, 2013 | Heating & Cooling
My aircon is not blowing
Most liekly needs to have freeon added to the system, if that doesn't help its propely a problem with the electric motor on the blower.
Nov 07, 2012 | Gree 9000 Btu 23 Seer Ductless Mini Split...
Unit will heat only will not cool and how to repair
we have a split type gree aircon, with one (1) horsepower. it was just newly installed, around 6 months ago. we are just surprised that one when my wife turned it on, thru the use of its remote control, the indicator box on the aircon reads or flashes "F2". I detached the batteries of the remote control for severa hours and I also detached the power cord from the wall socket, but it was to no avail. it did not work. with "F2" on the indicator box, the aircon won't give cool air, it is just working like an ordinary fan. please help us.
May 17, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
When should the rear swing arm and driveshaft be serviced?
if there is any play in the swing arm its time to service it and fit new bearings but any time is a good time to grees it up as for the drive shaft this needs looking at every year or so again its a grees up pull off the shaft and clean off all the old grees first the shaft must slid freely on the splines
Apr 14, 2010 | 2004 kawasaki VN 1500 Vulcan Classic
My carrier split type non-inverter aircon always blinking
It indicates afault within the unit. Give Carrier a call and get it serviced.
Mat
Jul 01, 2009 | Carrier 36KCARMS Air Conditioner
Green light on but no ac power out
Probably has an internal fuse that is blown. You will have to disconnect it from dc power and take the cover off and look for a fuse that is blown, should be near the AC outlet or on the circuit board. Could be a glass tube or newer style automotive plug in type. Good luck.
May 18, 2009 | Vector ® Maxx SST 1200 - watt Power...
Panasonic Inverter aircon E24DKR icing up inside unit
Yes, if the filters are clean, the coils are clean, and it is still freezing up in cooling mode, then it is low on refridgerant.
Jan 14, 2009 | Carrier 52PQ307 Wall/Window Air...
Heating & Cooling Logo
Top Inverter Heating & Cooling Experts
MightyMikeJr
jeff5may32
Are you an Inverter Heating and Cooling Expert? Answer questions, earn points and help others
