Question about OneTouch One Touch Ultra 2 Blood Glucose Meter
My one touch ultra meter shows error1 meter problem when I turn it on does that mean that the meter is bad?
2012 yamaha grizzly 700 new battery in just clicking noise showing error1
Just a couple wild guesses from 40+ years of experience...
1. the solenoid is bad.
2. the connections are not clean.
Make sure the ground wire from the battery is clean and tight to the frame.
Try jumping the two major solenoid connections with a HEAVY wire or (what most people use ( a screwdriver) and see if it starts...
If the engine turns over when you jump the connections, it means the solenoid is bad. If it does not you probably have bad connections at the battery + or - side.
May 30, 2017 | ATVs
Locating the starter relay on a 95 Ultra Classic(carbureted)
Hi Anonymous, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12 volts or better after charging.
3. Make sure all connections are clean and tight especially the negative cable at both ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor. Good luck
Jan 14, 2014 | Harley Davidson Motorcycles
How do i find the manufacture date of my one touch ultra mini bg meter
Look on outside of box, or look on label on back of machine, thses are the most likely places to find manufacture date. It may be in part of the machines ref number, but I am not sure. Hope this helps
Jan 09, 2014 | OneTouch One Touch Ultra Mini Blood...
Does one touch ultra 2 glucose monitor have a battery
They run on a watch battery found in your pharmacy area. It's a battery for medical equipment...take your meter in and t they will help you
Oct 02, 2013 | OneTouch One Touch Ultra 2 Blood Glucose...
2002 Harley ultra high voltage
Sep 23, 2013 | 2000 Harley Davidson FLHTCUI Electra Glide...
LOST MANUAL. HAVE ERROR 2 ON METER. HOW DO I FIX IT? ONE TOUCH ULTRA SMART METER ANN
I first tried changing the strip. Didnt'help. Then I changed the battery (eeve though the meter didn't complain about the battery) and it worked properly after inserting the test strip again. :-) Note that this was my "backup" meter,since my main meter had gone missing ealier in the day.
Sep 22, 2010 | One Touch A & D One-touch Blood Pressure...
WANT TO REGISTER MY ONE TOUCH DIABETES ONE TOUCH WHEN i GOT MY ONE TOUCH DIABETES TESTER IT HAD A CARD TO THIS ADDRESS WWW.oNE tOUCH DIABETES.COM/SUPPORT AND THIS IS WHAT i GET IS THAT SO HARD this is...
I just got a BD Glucose-only, OneTouch Ultra 2 metering device, and was directed to this website to register for a 3-year warranty...how do I do so? Mitchell Rosenberg, P.O. Box 13294, Scottsdale, AZ 85267 and phone number (602) 402-0765.
Aug 11, 2010 | One Touch A & D One-touch Blood Pressure...
When I plug in my jet 3 ultra the ammeter reads 0. If I turn on the vsi controller the top led display( 3 red, 4 yellow, 3 green) are all lit. I see where that means high battery voltage. The lower led...
Its showing you the voltage out put for the charger if all power lights are lit and the chager is pluged in if batteries show only 2vlts then they are no good and the will not charge up thats why amp meter is on 0
Mar 03, 2010 | Jet 3 Ultra Power Chair
My glucometer one touch ultra was not turning on, please help
Hi
The most common cause of this is battery failure. First thing you need to do is replace the battery. Its a 3.0V Lithium Battery (#2032 or equivalent).
If the meter does not work after this it will require service repair.
Hope this helps. Please do rate my answer. Thanks.
Sep 02, 2009 | Solis Ultra One Touch Cappuccino &...
Frigidaire GLEQ2152ES0 not heating -- How do I check and change the fuse?
use a ohm meter, remove 1 of the wires from fuse, take your both leads from your meter and touch each one on the fuse, If you are showing OL, means its bad, If its giving you a reading then its something else.
Jul 27, 2009 | Frigidaire GLEQ2152ES Electric Dryer
OneTouch One Touch Ultra 2 Blood Glucose Meter Logo
23 people viewed this question
Top OneTouch Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an OneTouch Health and Beauty Expert? Answer questions, earn points and help others
