Question about Aspire Computers & Internet
Aver aspire 5251-1513 won't turn on but charge light is on when plugged up
    New Friend:
  • 18 Answers
What does it do when you press the power button? If it whirrs and then shuts off, could be a bad cpu, a power supply that is on the verge of failure and can no longer power the machine, or bad ram.
If you press the power button and hear nothing and no lights flash, it's probably a bad motherboard.
Posted on Dec 07, 2016
    Top Expert:
  • Aspire Master
  • 8,376 Answers
Can you tell me if your laptop comes on with the battery taken out and just try and start it with the charger plugged into the laptop.
if it does this might sound silly but leave your battery out for about half hour then try again and let me know what happens.
Acer aspire 4830t-6841 power button blinks 5 times won’t turn on. Happened during latest windows 10 update.
Buy a new powerbrick, it is probably the battery not charging.
If i let my acer run without powerbrick and its battery is empty, i get 5 flashing lights.
Jan 25, 2018 | Acer Computers & Internet
Acer Aspire 5552 won't power up, charge light flashes on and off
Remove the battery and plug in the Cord/charger, will it boot? If no, try another Cord/Charger with the EXACT same power specs. Replace battery if necessary.
Mar 02, 2013 | Acer Aspire 5552-3691-24271 Laptop
Aspire ahows green light but won't start up, have turned off main but still just green shows
Pull the plug from the AC outlet, wait a 30 seconds, plug in, try to reboot. Does it try to start and in a few seconds shut down? Give as much detail as you can.
Dec 19, 2012 | Acer Aspire™ T135 PC Desktop
Acer aspire 5111 won't turn on
Common problem is HDD won't come up to speed and needs replacement. Can try unplugging and removing battery, then re-install and try to start. If that fails, need to install new HDD. Hope you have backed-up everything.
Feb 06, 2018 | Computers & Internet
My daughter's Acer Aspire 5732Z laptop will not
It sounds like the battery charging ac cable might be faulty.. You might want to go to a local shop and see if they could try another cable before you go out and spend money on a new one. They usually will try a cable to see if that's the problem.. Please let me know if this washelpful and if it solved the problem and good luck..
Sep 10, 2011 | Acer Aspire 5732Z-4855 Notebook
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have acer aspire 4741z, when I plug the battery charger, it says plugged in, not charging (6% available). how can I fix this problem? thanks a lot
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 07, 2011 | Acer Aspire 4730-4947 Notebook
Acer Aspire One Netbook ZG5 will not turn on
you should be able to press ESC to exit hibernation, or remove the battery, remove the plug, press and hold the power button for 60 sec, and reinsert battery and power and turn on. when restarted, right click on desktop, click properties, and click the screen aver tab, click the power button, click advanced, and remove the check box beside enable hibernation on the "Hibernation" tab. it shouldn't do it again
Apr 20, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computers & Internet Logo
53 people viewed this question
Top Aspire Computers & Internet Experts
pankaj rautela
pankaj rautela
Jax Planet
Jax Planet
EKASYS IT SERVICES
EKASYS IT SERVICES
Are you an Aspire Computer and Internet Expert? Answer questions, earn points and help others
