Question about Dryers
My meter shows error1 meter problem when I turn it on does that mean that the meter is bad?
Machine error1 broke needle then machine come error1 can i override
Look for Error 1 in the troubleshooting section of your owner's manual or search for:
Make Model Error 1
May 26, 2018 | Sewing Machines
My ricoh 171 photocopier showed error sc-901, what does that mean and do i do
It's looking for main meter. Couple of things either the main meter gone bad and replace or main board is bad. Open front cover were toner hopper and look to left of it. There is a 1 inch square and meter is there. if there is like a piece of plastic in its place then possibly no meter is installed or has it but plastic was not removed. At some point Ricoh make it in service mode to tell copier if there is a main meter installed or not. This might be some how got enable if there is no meter installed
Dec 11, 2017 | Ricoh Office Equipment & Supplies
2012 yamaha grizzly 700 new battery in just clicking noise showing error1
Just a couple wild guesses from 40+ years of experience...
1. the solenoid is bad.
2. the connections are not clean.
Make sure the ground wire from the battery is clean and tight to the frame.
Try jumping the two major solenoid connections with a HEAVY wire or (what most people use ( a screwdriver) and see if it starts...
If the engine turns over when you jump the connections, it means the solenoid is bad. If it does not you probably have bad connections at the battery + or - side.
May 30, 2017 | ATVs
Compool cp3400
online/Amazon - but the best thing is to use your local pool spa professional. Then you can always call them for help when you really need a pro.
May 22, 2014 | Pentair Pool & Spa
Speedometer going crazy
USA or non USA car. not knowing this makes answers , all wrong.
define crazy.?
if bouncing like mad"? is
1: the cable to it bad. if cable good ,speed is bad, (tests, ask)
2: if the cable gets bad enough the CEL comes on and shows bad VSS. (DTC) veh.speed sensor, dead.
oops 99 is a cust year,
every page in fsm (related) shows if equipped.
cable speed (old school)
electric gauge, no cable. new cars. cusp year.
that means , one looks for the cable to the
tranny or to the not stated 4wd transfer case.
if its a 100% electric gauge
and crazy means bouncing?
its:
A: bad meter.
B: bad power to meter (or loose fuse or speedo connector plug)
C: Bad ECU (hah)
D: vss input to ECU is crazy,
or go to alldata.com and read, its all there. RTM.
Nov 21, 2013 | 1999 Suzuki Grand Vitara
Went to sew on my elna 6005 machine made a growling noise and stated error1 do you know what this means? I have had the machine since it was new and never had this issue
I would suggest that you take off the needle plate and check if the bobbin holder, the black plastic bit you put the bobbin into, has become dislodged and moved out of alignment. This can happen if you have a jam up as the holder is held in place with a magnet.
Your manual should show how to remove and clean under it in the cleaning section and there is probably some thread in under it.
It should have a mark on it that needs to align with a mark on the stopper, on the right side I think, and you may find that yours have moved a little out of this alignment.
I'm hoping that this is the problem for you; as its easily solved. After you've put the holder back, just turn it off and wait a second, then switch on and hopefully it will reset. Also check the back of your manual, it should have troubleshooting at the rear which may give a diagnosis on the Error1 message.
Sep 25, 2011 | Elna Heirloom Edition 6005
How to solve error1 problem
Error 01 means that communication between camera and lens is faulty. Try to clean lens contacts.
May 25, 2010 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
The battery light came on and the battery was replaced. The alternator was also checked and determined to be ok. Now the battery light comes on and the slternator shows as charging at about 14-15 Volts any...
check the battery with a volt meter. Place the probes from the meter inverted which means positive from the meter to negative on the battery and negative from the meter to the positive one the battery. MAKE SURE YOU STE THE METER TO THE DC & NOT TO THE AC MODE BEFORE YOU TURN THE METER ON. Now start the engine and see if a reading shows of 14 - 15 volts. If so the diode is bad in the altenator. The diode suppose to keep the current running only one way. If the current is running both directions the altenator does not charge the battery completely and the battery light will come on this way also
Jan 31, 2010 | 1997 Jaguar XJ6
When putting in a cd screen shows error1
Is it with all cds? Also what is the make & model this would help in tracking down your error code
Aug 06, 2009 | Car Audio & Video
Dryers Logo
Top Dryers Experts
