Question about Teac AG-V8060 Receiver
Take protect off a TEAC AG-V860 stereo receiver
I plugged da receiver an started to plug in two aiwa speakers an a aux wire into vedio 1 an then i tried to fix the wiers to here music an nothing happen den i checked wit da fm tune to c if i can here anything an i started to here da fm after i try to move to receiver to see wat els was wrong dat i was doing an den thats wen da receiver went to protect an it keeps blinking
5 Suggested Answers
SOURCE: lost manuel for teac ag d9100 reciever
you can download a manual for $9.99 from User-Manuals.com....I did this today and the manual is identical to the original it seems
Posted on Sep 19, 2008
  • 4234 Answers
SOURCE: Receiver keeps flashing "PROTECT"
The protect message indicates that a problem was detected in the last stage of the amplifier and that it has shutdown to prevent further damage. Usually this indicates that the output transistors have failed. Any shop that works on audio should be able to repair this. Expect a part cost in the $20-$40 range. Add in the local labor rate for the total repair cost.
Dan
Posted on Dec 17, 2008
SOURCE: TEAC AG-D9100 freeze
Always be that legend when the audio amplifier IC damaged
Posted on May 08, 2009
SOURCE: Teac AG-V8525 Stopped producing sound. Has legend says "protect"
hit reset button back of receiver
Posted on Dec 02, 2009
Why does my Teac ag h500 keep saying protect?
Hi. Unfortunately the protection circuit is saving your speakers from a fault, most likely one side of the amplifier in the unit is defective.
This needs an engineer.
Service manual is here if you need it. TEAC AG H500 Manual AM FM Stereo Receiver HiFi Engine
Oct 02, 2016 | Teac Audio Players & Recorders
I have this issue, my teac ag d7900 which itself off to standby and when I switch it "on" again, it says protect and shut itself down again
Right. This means that either you have a short in your speaker cable somewhere or the short-detector circuitry inside has problems. Disconnect all speaker cables and turn the receiver on. If the symptom goes away, turn the receiver off again and connect one of the speaker wires. Repeat until it starts to go into protect again. When it does, the last speaker you hooked up has a short somewhere in the wire.
If protect always comes on, you'll need to get the unit serviced.
Jun 28, 2015 | Teac Audio Players & Recorders
How can u tell if your internal speakers are blowed?
Hi Patricia,
You may need a professional cleaning of all the switches internally. If you are up to it. Compressed air with an electronic aerosol cleaning solution is the first approach. Over time these parts develop oxidation. The voltage levels are small and the signal cannot be generated.You need to know what too clean, most are visible. You can also look for internal fuse protection. Make sure when the cover is removed to pull the power first. Some higher end Amplifiers provide protection. You will need a digital multi-meter or equivalent to test the fuses.
http://www.teac-audio.eu/downloads/2/2/8/1/9/TEAC_AG-790E_datasheet_EN.pdf
So before doing all of that. There is a reset switch. It is located between the speaker switches on the face of the receiver. At the top and in the middle left center of the display. Not at the speaker buttons on the left.
That function may be tripped. Reset it twice and try testing with different speakers if it fails again. It may trip instantaneously if there are abnormal voltage levels present in the circuit that arouse protection.
I have located and offer you the Manual PDF. Go here first and try the following. On page 8 in the manual. Titled, " Name of each Control" (D). There is a location diagram for you to observe. Please take some time and look this over.
http://www.teac.com/content/downloads/products/746/ag-790_6l_manual.pdf
Finally, if you need someone to talk too. The You Tube Video has an outlet store tied to it that offers live help.
TEAC AG 790A AM FM Stereo Receiver
Good troubleshooters always take a problem apart one step at time. So go for it. I know you can do it. Fare. Well.
Jun 20, 2014 | Teac AG-790 Receiver
Connect phone to AG-550 Receiver
Android?...If so , buy a 1/8" stereo plug to twin RCA male cable assembly and use the AUX input on the reciever
Jan 30, 2014 | Teac AG-H550 Receiver
How do you reset the blinking protect banner on the ag-v8520?
Try disconnecting the power cord then disconnect the speakers. Plug the power cord back in then hold in the power button until the unit "clicks." Then disconnect the power cord and reconnect the speakers, then the power cord and turn it back on.
Jun 13, 2009 | Teac AG-V8060 Receiver
Receiver Blinks PROTECT
how many speakers have you got on to it
Dec 07, 2008 | Teac AG-V8060 Receiver
Teac AG- D8900
Stereo Tech: Check speaker switch(A or B) also be sure you have selected FM, AM, Video, CD ect., somtimes if you do not have a stereo signal the unit will mute best to fist try tape or CD input. Hope I helped good luck.
Nov 27, 2007 | Teac AG-D8900 Receiver
Power comes on but speakers do not make noise
Stereo Tech: yes their is a fuse inside that possibly opened, but does the unit show PROTECT across the display? if not you may have goten lucky and just did a fuse small PC board just behind the transformer. Good Luck
Jan 14, 2007 | Teac AG-D8900 Receiver
Teac AG-V8060 Receiver Logo
126 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
