Question about Garden
Need to know the position of the fuel fuse in the fuse box of a ford 2001 f150,and also the fuel relay in the distribution box.
The engine turns but fuel does not get to the carburetor.
    Top Expert:
  • Garden Master
  • 80,444 Answers
Go to the ink and there you can download the owner's manual and look that info up. The fuse and fuel pump relay will be in the under hood power distribution box. Also remember you have a fuel pump cutoff switch in the circuit as well. http://www.fleet.ford.com/partsandservice/owner-manuals
Posted on Dec 07, 2016
Cant fine the fuse for my windows and sunroof 2001 f150 supercrew 4door lariat
moonroof relay and 30 amp fuse should be under the hood in the power distribution box.owners manual also can help you locate all fuses and relays location.
Aug 31, 2012 | 2001 Ford F150 Styleside SuperCrew
Where is the fuse for a 2001 ford 4.6litre mustang(fuel fuse)
The fuse for the fuel pump is located in the power distribution box/fuse box located in the engine compartment. It is in the number 14 position and should be a 20 amp fuse (see picture below of the fuse layout). Also, I don't know if you have checked this or not but there is a fuel pump cut off switch located in the trunk of the vehicle. I gave you a picture of its location in the second picture below. This should all be in your owners manual if you have one. If you do not and would like a copy, you can email me at csautomotivecars@att.net with your make, model and year and I will be happy to email you a copy. I hope this helps you and good luck.
Apr 24, 2011 | 2001 Ford Mustang
Ned the fuse box description . fuel pump dont
The fuse for the fuel pump relay is in the number 19 position in the power distribution box located in the engine compartment (not the small one next to the battery). Diagram below of the layout of your pwer distribution box. Also did you check the fuel pump cutoff switch located inside the vehicle on the passenger side (see picture below). I hope this helps and good luck.
Mar 03, 2011 | 1998 Ford Expedition
Looks for the Fuel fuse for a 2003 f150 ford truck xlt
Gonna do my best to try to explain what I think you are looking for. I am going to assume that you are having fuel problems so I will give you 4 places to look for power supply problems to your fuel pump. 1. Your fuel pump cut off switch is located in the front passenger footwell by the kick panel access cover. 2. The fuel pump fuse is in your power distribution box located in the engine compartment. That fuse is in the # 10 position. If you are looking in the box towards the bottom there are 2 rows off fuses and in between those rows are 2 relays. I hope you understand. The # 10 position is in the 2nd row, you have 2 fuses then 2 relays and from the relays going left to right it will be the 5th one over from the relays. It's a 20 amp fuse. 3. The fuses for the fuel pump relay is in the # 18 position. That fuse is in the same row as the last one but is the first one after the realys going left to right. It is a 15 amp fuse. and finally number 4. The fuel pump relay itself will be the second relay going from the left in that same "row" that I have been telling you about. That's the # 301 position. I hope this helped and good luck.
Feb 13, 2011 | 2003 Ford F150 Regular Cab
2004 f150 will not start need to find where the fuel pump fuse is
FUEL PUMP FUSE IS A 20 AMP FUSE LOCATED POWER DISTRIBUTION BOX INNER FENDERWELL IN THE ENGINE COMPARTMENT.ALSO CHECK THE INERTIA SWITCH LOCATED BEHIND PASSENGER SIDE KICK PANELTHIS WILL SHUT OFF FUEL PUMP.IF YOU RUN OVER A POT HOLE OR SOMETHING.CHECK TO SEE IF SWITCH BEEN KICKED OFF.AND RESET IT.
Mar 28, 2010 | 2004 Ford F150
Fuel pump relay location 01 F-150
Engine Compartment Fuse Panel, relay 301
Fuse for the fuel pump relay is also in the same fuse panel in the engine compartment, Fuse #18.
If you did not get an owners manual with your truck ( purchased used ), you can download one from Ford :
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
Jan 10, 2010 | 2001 Ford F150 Styleside SuperCrew
Intermittent fuel pump engagement when turning key - 2001 Taurus
try cleaning the connector that goes to the fuel pump, sometimes they corrode on inside. If that does not fix, test the wires feeding fuel pump with a multi meter until the condition shows itself again, if voltage drops to zero or very low then wiring problem, if voltage is unchanged with problem and fuel pump is not working and connectors are all clean, try replacement of fuel pump.
Oct 09, 2009 | 2001 Ford Taurus
Fuel pump is not pumping on my ford ltd crown victoria. i need a fuse diagram so i can see if it is just the fuse or if i need to replace the pump.
There is both a fuse and a relay for the fuel pumps electrical system. The image below of the Power Distribution Box is located in the engine compartment.
Fuse/Relay Location: 5
Fuse Amp Rating: 20 Amp Mini Fuse
Power Distribution Box Description: Fuel pump
Fuse/Relay Location: 203
Fuse Amp Rating: 1/2 ISO
Power Distribution Box Description: Fuel pump relay
Apr 14, 2009 | 2003 Ford Crown Victoria
FUEL RELAY
Power distribution box, under hood, unclip two catches of cover, remove the cover and you'll see several relays, some hi amp fuses, etc.
Mar 25, 2009 | 1994 Ford F150 Styleside Supercab
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
