How to get my spin i,d, number, I entered allready
How to configure dhcp in belkin router
you need to log into router and enable printers Mac address to the list of allowable devices , router should be accessible directly using a web browser (explorer?) on any device on network already just enter router Ip address number into top destination line , (example of proper formatt is 192.168.100.001) this should bring you to log in page , enter password (yours) into avail spot and press enter , if successful then it will open to a new page that has all the items down left side of page , select dhcp tab and go to list of devices , click ip number of printer(its assigned allready) , select refresh on top tab your new printers ip number /model number/mac address should be there , select exit now your devices on network can "see" it you will need to enable/install this printer on those devices in order to use it , it does not have to be a defalt device on any item on network
Jan 07, 2016 | Belkin Computers & Internet
New e mailassword as well as email address with same phonenumber please please please!
Hi Leon
You need to use another computer to change all the passwords on all your regular sites. Hope you remember them all.
This is where software like this comes in handy.
Obviously you need to keep it on two devices (1 for backup)
SplashID Password Manager
1Password for iOS
Sep 20, 2015 | Cell Phones
I cant send text messages. Keeps asking for "center number"...even though its already added in my phone. Does this more and more as time goes on. How do i send a message??!!?! Samsung F266
this is not a cellphone problem. msg center number depend on service provider. you say it's allready aded but sometimes it changed without any notice so call to custmer care and ask for msg center number enter it again and swatch off and on your phone
May 06, 2011 | Samsung SGH-E900 Cellular Phone
I really don´t remember my
YOU will get security code with your imei.
go this site enter your imei number and he will give your security code
web site: http://nfader.su/
Dec 05, 2010 | Nokia 5130 Cellular Phone
AVAYA PARTNER ACS PHONE SYSTEM - Separate Greeting
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#206"
the display should say Group Call Distrib Group:
Press 7 It will then ask for a line number
enter in 05
the display will say 1 assigned
press 3 VMS Line Cover
Do the same procedure (from #206 on) for line 6
Then enter #208
The display will say Line Coverage Ext Line:
Enter 05 The display will then say Data --
Enter in the extension you want the voice mail to pick up the lines on
Lastly if its not done allready, enter #301
The display will say Automatic VMS Cover Extension:
Enter in the extension number of the phone thats getting the voice mails
The display should say 1 Assigned
press feature "00" to logout
Oct 06, 2009 | Lands Phones
My wfooo hotpoint washing machine doesnt spin, the belt came off i put it back on but then it snapped when i put the washer on spin, will the washer being empty when i did this affect the belt?
Think your belt was allready on the way out and you will need a new one. Just a coincedence that it broke when it did. It came off because it was worn and stretched.
Sep 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
PUK Code problem
i need a asda puk code please
Nov 01, 2008 | Nokia 1600 Cellular Phone
My hoover washing machine 1400 spin 8kg hd vision hd
Hi On my washer when I press the start button when allready in opperation all the lkights flash and it stops as this second press of the button pauses the machine and need the start button to be pressed again to restart the machine
Hope that is cleas and helps
Angela
Jun 22, 2008 | Hoover H130E Front Load Washer
My sims is blocked
First of all don't put some unknown pin numbers because it gives u three turns after that it will completely block ur sim.If u allready do that,get to ur service provider and get a new sim by paying some money,if u donot Get ur sim number which is printed on the sim.Call ur service provider,give them ur sim number and get PUK1 and PUK2 and enter them as they are requested by phone
Oct 23, 2007 | Motorola Mobility RAZR V3
Connected on Wireless but unable to connect on Internet
If not done allready, setup the lan IP address and default gateway in win98 Click MyComputer-ControlPanel-Network-Double Click TCP/IP Adapter for your 3com device-insert LAN info for IP Adress-subnet mask, Gateway and your Internet service providors DNS Addresses info Tab's (3x different Tabs "IP Adress" "Gateway" "DNS Configuration") IP Adress will be at least one number higher than your gateway address and not allready being used by other PC's on your network and gateway address will same as your router interface address subnet mask will be the same for all PC's on your network. For 3com and Netgear routers LAN setup is usually Gateway = 192.168.1.1 Subnet Mask = 255.255.255.0 IP Adress = 192.168.1.10(choose alternate number than 10 if allready used by another PC on your network, try to use round numbers, must be a number higher than 1) Once all info is entered click OK (this may trigger a database info update message and task)now your LAN is setup and ready to talk to your network Restart PC and try browsing again. May possibly require reinstallation of the TCP/IP client (you double clicked this to setup your LAN in Win98) or reinstallation of the IIS(Internet Information Services)component found in, Add/Remove Programs-Add/Remove windows components and then try LAN setup again if this does not work first time round
May 06, 2007 | 3Com OfficeConnect Wireless 11g 802.11g/b...
Washing Machines Logo
Top Washing Machines Experts
