Question about Hardware & Accessories
I have a Tdx timer on my feeder I set it up them I push the test button it works fine but when it is time for the feeder to go off it does not work
  • 7 Answers
SOURCE: GE LR44 model JGBP34 doesn't sense Bake/Broil/Clean buttons
Circuit board repair is your only alternative to shelling out $200 for a replacement. Take the control box out of the stove and remove the top board, which is just relays and interface connectors to the AC power and bake/broil burners. Under this is a complex circuit board, also to be removed. You have to unbend tabs to do these removals, and make sure that all the inter-board connector pins are properly mated when reassembling and rebending tabs. On the underside of the circuit board I found corroded spots under each of the 3 electrolytic capacitors on the board. Very suspicious. I replaced the caps and had to patch two traces on the board with jumpers, and this fixed the problem! You may as well try this (or have a nerdly pal try it) since you have nothing to lose and possibly $200 to save.
Posted on Nov 20, 2008
docjohn174
  • 943 Answers
SOURCE: won't start
Hi check the thermal fuse at the rear of the dryer It looks like this 00208689.jpg
Posted on Dec 16, 2008
mastatech
  • 478 Answers
SOURCE: The dryer will not start.
Check the door switch.
Posted on Mar 14, 2009
SOURCE: dryer wont start after setting the timer
keti
Posted on Mar 31, 2009
  • 659 Answers
SOURCE: drier button does not work when push it to start machine
You need to check the dryer door switch. I may be bad. If the timer is clicking it is probably working fine. Also you need to check that the dryer is getting power to the unit. Check your breakers and also pull the unit out and look at the dryer cord. Check the terminals for a short or burnt looking one. Once you have established you have power going to the unit, you can find where the comunication stops within it.
Posted on Apr 09, 2009
Do I set the GE timer # 15089 to Auto on or Auto off for it to be activated. I had it on Auto on however the light stayed on all the time.
I don't have repair for defective timer.
Open following link to identify timer and download manual:
http://waterheatertimer.org/GE-timers-and-manuals.html#15089
Timer should be set to Auto ON for timer programs to run.
Auto OFF is temporary override, and timer resumes schedule at next set point.
ON is always ON
OFF is always OFF
If timer is not operating as expected:
Test outlet for correct polarity and electrical problems using cheap circuit analyzer from hardware store.
Timer programs can have conflicts. Make schedule before setting timer so there are no overlaps that cause timer not to function as expected.
Current time has not been set. Set current time including current day.
Set button has been accidentally pushed, and a number or CTD appear in display.
Timer needs to be reset to clear conflicting programming or error. Push reset button with paperclip and try programming again.
Timer is not able to handle intended load. All timers work for incandescent bulb. Connect timer to incandescent lamp and see if problem continues.
Timer is defective. Buy another timer from Home Depot and return defect in new package.
Aug 17, 2011 | Jasco Ge 7 Day Digital Timer 1 Outlet...
I set the time on and time off. has worked before . doesnt work now.
I do not have repair for defective timer.
Most timers have limited 1 year warranty, except some Intermatic timers that have limited lifetime warranty.
Last step troubleshoot for timer is to reset and reprogram.
Timex Easy set is reset by pushing down Hour and Minute button same time.
If functionality is not restored, then buy another timer.
If timers fail frequently, then test outlet with circuit analyzer. And read load rating, try timer on different load, for example high wattage loads will shorten life of timer, and not all timers are made to control every type of load. Buy appliance timer for air conditioner or toaster oven.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Timex
Aug 14, 2011 | Timex EASY TO SET TIMER BY TIMEX
The link on FixYa to the HB65R Intermatic timer Manual seems to be broken. Do you still have it?
Fixya does not have HB65 manual posted.
Open following link to identify timer and download manual in English.
If this is not your timer, add a comment with clear description of timer, or in-focus photo of timer posted on flicker, so I can locate possible manual.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#HB65R
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
Jul 19, 2011 | Garden
Just installed the programmable timer and had programmed the clock and on off times. Then realized that it was set for AM instead of PM. Hit reset and now can't set the clock or program. Just blinks...
I test timers.
Some arrive defective, and some go bad quickly.
Industry standard is 1 year limited warranty.
All these timers have reset button that should restore functionality.
You posted under Woods digital programmable.
Open link to download on-line manual and read ez wiring steps.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
This timer is reset by pushing reset button, without pushing any other button.
Some timers require on-off button to be pushed while pushing reset button.
I suggest turning off power to timer and see if that 'resets' timer.
Otherwise open link below and run through troubleshoot checklist, and also double check wiring.
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
If timer will not function correctly, then exchange for new timer.
Resourceful do-it-yourselfer can buy similar timer at Home Depot located near light fixtures and doorbells.
GE15086 -or- GE15071 with daylight savings time.
Advantage is ez exchange if problem occurs, and you give yourself extended warranty.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 20, 2011 | Woods InWall 7 Day Digital Programmable...
I need to know more about "Countdown - Auto -
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
59377 manual
http://waterheatertimer.org/pdf/Woods-59377.pdf
Auto: timer must be set in AUTO for programming to work
The word AUTO is printed on timer face.
Small black triangle will display above the word AUTO when timer is in AUTO
Countdown is feature that lets you set timer ON for set amount of time, and when time expires, timer turns OFF.
Manual button.
I have not tested this specific timer.
Simply plug lamp into timer, and then push manual button to explore feature.
Watch what symbols display, and watch what lamp does.
Mar 08, 2011 | Woods Industries 59377 Indoor Digital...
I need instruction manual for TD126 timer
TD126 timer
I'm going to guess at these instructions since they're not posted anywhere yet.
It's a chance I will be wrong, and others can add a comment and refine the answer.
The other option is: you can buy timer and scan your manual into pdf format and post it on your website for free.
Then add a comment with manual web location so we fixyans can sell your manual and manual information to other folks who are wanting a manual to sell to other folks.
Another option: You can pay a fixyan to buy the timer and do the work for you.
My guess is that free is better:
Plug timer into outlet for 1 hour to charge battery.
Remove timer from outlet to program.
Timer appears to be a 24-hour repeat timer with 12 hour am-pm format
There are 5 buttons on face of timer: Reset SET + - Finger
-Press reset button to clear programming.
-Set current time: Push and hold finger button while pressing + and - until current time and am pm display. Or push and hold SET button while pressing + and -.
Program timer:
-Press finger until PROG 1 ON displays
-Press press + and - to set program1 ON Hour.
-Press SET to confirm hour
-Press press + and - to set program1 ON minute.
-Press SET to confirm ON minute
-Press finger until PROG 1 OFF displays
-Press press + and - to set program1 OFF Hour.
-Press press + and - to set program1 OFF minute.
-Press SET to confirm OFF minute
-Press finger until PROG 2 ON displays
-Repeat steps above.
-When programming is finished, push set button.
And you might have to push finger button, or push and hole finger button, and then set button.
-Timer appears to be in AUTO as default mode.
Timer may also have a switch located on side of timer. Move switch to timer if there is a switch.
Some timers also require you push two buttons at same time to enter different modes, or hold one button while pushing other button.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 10, 2011 | Hardware & Accessories
Drier button does not work when push it to start machine
Apr 09, 2009 | Kenmore Dryers
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Intermatic hb65r residual outdoor timer
Here is the instruction manual for your model:
HB65R Timer
Hope this helps!
Also consult this website for sunrise, sunset information for your area:
Sunrise sunset calendar
Dec 05, 2008 | Hardware & Accessories
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
