Remote not working need to get tv from hdmi to tv in source by using buttons on side of tv
    Top Expert:
  • Televison & ... Master
  • 79,865 Answers
I would try replacing the remote with a factory new one. If it still doesn't work the infrared sensor in the TV is defective.
Posted on Dec 07, 2016
Source button does not work The hisense Tv cannot respond to change to hdmi and is stuck on monotv
new batteries. But that won't solve the problem if the universal remote apply other code. when the original remote is applied, you touch the tv icon to be sure you are using the correct parameters. When it still won't solve the problem you go to the ir circuit on the set. the reason may be because of the accumulation of the dust and dirt on the buttons.
Apr 30, 2016 | Hisense Televison & Video
On HDMI settings,how to use cc
Unfortunately, the HDMI standard does not carry the CC digital information, for any TV to decode and display it on its own. Therefore, when watching HDMI source the CC button on the TV's own remote, cannot work.
However, each Cable, Satellite or Internet streaming device can decode the CC information from the source (when available). Then the CC text is inserted into the picture and sent to the TV via HDMI or any other video connection.
Look for CC option on your Cable's or Satellite's remote control, or on the source device's menus.
Feb 17, 2016 | Panasonic VIERA TC-P55ST50 55 in. 3D...
How do I get to my HDMI channel?
It isn't a 'channel' it is a connection port. Once a cable box or DVD / blue Ray player is plugged into it, you choose the port using the Input button on your remote and scroll through them.
That set has 2 HDMI connectors on the back panel, right side, more or less by themselves, to the lower left of the antenna jack.
See the link. In the cluster of 3 photos, click the center one, then zoom it. Source(s): http://www.crutchfield.com/S-QWOJIeQP36Y... kg7or · 4 years ago
All the info on the television including manuals and inputs can be found here,
ftp://ftp.panasonic.com/television/howto/combo_connections_howto.html
58 Class 58 0 Diagonal 1080p Plasma HDTV with Anti Reflection
Jan 01, 2016 | Panasonic Televison & Video
How to switch from tv to dvd
Your DVD will be (or should be) connected to your TV using either HDMI cable, Component Cables + Audio, Composite Video + Audio or other A/V connection. Your TV remote will have an input selector that switched the source signal within your TV. This can also be called source selector. In any case, you need to push this button on the remote to rotate through sources (if only one button) or push the button labeled DVD, for instance to select the DVD inputs. Please note that only one type of connection should be used such as HDMI or Component, but not both.
Apr 03, 2015 | Samsung Televison & Video
PC HDMI W4201C 42 CONNECTION
Hi Caleb,
To resolve this, please perform the following steps:
  • Turn off the TV and unplug the power cord
  • Connect the HDMI cable to the HDMI port of your laptop.
  • Connect the other end of the HDMI cable to the HDMI input on your HDTV
  • Connect your device using the HDMI connector (Refer to image below)
  • Plug in the power cords for the TV and Xbox
  • Turn on your TV and Xbox
  • Enter the TV Menu and select Setup (Refer to the image and steps mentioned below)
  • To enter the TV Menu, press the Menu button on Remote control
  • Use the left and right buttons (volume buttons) to move between the icons
Select correct input source
  • Input allows you to select the proper source based on how you have your TV and video equipment connected.
  • Press Input on the remote to go directly to the Input Select menu
  • Select HDMI 1 or HDMI 2 (Refer to image below)
If the TV does not work, please follow these steps:
Verify the PIP/POP/PBP function is disabled ( PIP/POP/PBP Compatibility - The only input sources that cannot work together are HDMI with HDMI)
  • Press the Menu button on the remote control or TV
  • Use the Left and Right arrow buttons (Vol +/-) to select PIP/POP/PBP, and then press <Enter>
  • Use the Up and Down arrow buttons (Ch Up/Ch Down) to select PIP/POP/PBP/OFF
  • Use the Left and Right arrow buttons to select Off
If issue is still persists, please move to the next step
Reset the TV current input to its default configuration
  • Use the left and right arrow buttons to select Setup, and then press Enter/OK
  • Use the Up and Down arrow buttons to select Factory Reset, and then press Enter/OK
  • Select Current Input Setting and press Enter/OK
  • Re-check the TV functionality
Feb 19, 2014 | Dell W4201C 42 in. Plasma HDTV
How to find source for model WS-28W63N without the remote control
Sometimes you can unplug the hdmi cable and power off the tv and unplug power to tv wait 10 sec plug tv back in and then insert hdmi cable. Some of the newer tvs will auto tune to the input if that dont work, try getting a universal remote program the remote to control tv if you can control tv volume, power , menu then you should be able to navigate to the input menu and select hdmi that way
Jan 13, 2013 | Samsung TV Remote Control
PS3 Connection problem with this particular tv model.
connect PS3 to Tv with RCA cables (white,red,yellow) go to display settings change to HDMI, Tv should go black remove RCA cables and connect with HDMI.
Jan 10, 2018 | Samsung LE22B450 22 in. HD-Ready LCD TV
Can i hookup theis computer to my tv using a hdmi cable?
Yes, your notebook comes with an HDMI port. You will need an HDMI cable to connect to the TV (usually LCD TVs come with an HDMI port). After the connection has been made, change the source in the TV by clicking the "Source" button on the remote. It usually changes in the following sequence - AV1, AV2, HDMI.
Jun 25, 2011 | HP Compaq Presario CQ50-103NR Notebook PC
I need to change the source on my tv to HDMI without my remote
Not sure if yours is the same but Philips codes work with Skyworth and if you hit the TV/AV button on the side of the TV and the table of options should come up. And then with the channel +or- go up and down till you are on HDM1 or where ever you want and then touch the TV/AV again when you are there.
Mar 27, 2010 | Philips 32PF5531D 32 in. LCD Television
HDTV
You don't mention using your SOURCE button to select HDMI.You have to put your akai in the right source selection by using the source button on the remote or the source button on the right side of the TV. I hope this helps. SW
Sep 06, 2007 | Akai LCT3201AD 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
