Question about Exercise & Fitness
How can find the service manual of my powerfirst T960 treadmill? and plus the firmware of it's microcontrollers? tnks
    Top Expert:
  • 77,939 Answers
You would need to contact the maker of the treadmill for this information.
Posted on Dec 06, 2016
Treadmill screen won't stop counting/running unless i unplug it. This was after a firmware update.
If you wish to get some details about treadmill repair and service ; check the site linked here. Pull up older posts.
Sep 14, 2016 | Exercise & Fitness
Hi my power first t960 treadmill stops working. it turn's on. startup beeps are ok. display turn's on and showing regular digits. but non of keys working and consul dos not response to any key. thanks
Check the cable from console to motor control board. It would be a detachable connector on both ends. Try removing and reconnecting it. Sometime such problems can occur because of the bad contacts of connectors.Please remember to remove the power before attempting any service inside treadmill.
If you wish to get some details; check the site linked here. Pull up older posts.
Jun 10, 2016 | Exercise & Fitness
Tc/tm config rqd 1 on 425 hr clubtrack plus treadmill not stair climber
Perform the following steps to configure the treadmill.
  • Enter the service mode
  • For the HR ClubTrack Plus, enter the configuration by using the menu choices on the service mode screen, which should be CP3 for the HR Clubtrack Plus.
  • Press SELECT  to store the configuration. (For the HR ClubTrack Plus, select the Set Screen Contrast screen and use the contrast up and down buttons to select the optimum contrast. Select Enter to save the value.)
  • Exit the service mode and confirm proper function of the treadmill.
Jun 20, 2015 | Exercise & Fitness
Precor 9.23 Treadmill Inclines Randomly
most prob one of sensor / connection gone bad
Mar 30, 2014 | Precor 9.23 Treadmill
How to dismantle t960 power first treadmill for packing and moving
you must take out the power first 2) follow the steps in your owner manual, or download from +
God bless you
Jul 18, 2013 | Exercise & Fitness
Vision Fitness T960 treadmill error code E4 I was going to recalabrat hit start could hear machine turn off
please proceed according and fix it. See the diagram for troubleshooting and see my personal TIPS for motor help.
"E04": Incline motor wrong, check if the VR of the incline motor connects well or replug it. The
mark of the DC motor and control board should be matched connected. Sometimes you also test the wires from motor and restart the treadmill
Jan 08, 2013 | Exercise & Fitness
My Powerfirst T960 stopped twice while running. Display stays on (no error message) but backlight turns off. Also, was speeding up/slowing down while running
1)LUBE THE DECK BELT, this problem is by lack of maintenance schedule, maybe you have deck belt worn. This produce enough friction between deck vs deck belt and shut down the machine for protect the electonic system.
2) Lube the rollers bearing in according with the maintenance schedule.
3) Test the voltage input motor, if there are the motor need repair.
4) Test the output voltage board, for the input voltage motor, if there are NOT the board si faulty.
5) RUN the software calibration for diagnose, troubleshooting and fix it.
see my person TIPS for help.
sincerely. God bless you
Apr 18, 2012 | Exercise & Fitness
Treadmill (powerfirst treadmill) shorting out power . overload switch shorting out power.? how can we fix this problem?
Check here with powerfirst spare parts
and also here for treadmill help in general
Jun 14, 2011 | Sport & Outdoor - Others
Have a new balance 1400 treadmill. when i power it on the screen goes blue and it will not doing anything.
Does the screen turn on (blue) and then go black or does it stay blue? Mine has a similar problem where when the main power switch is flipped, it lights up, shows the initialization screen, then goes dark. Pressing any button on the console does nothing. I opened the console up and suspect one programmable microcontroller is bad. I'm going to see if I can get that part from FitnessQuest instead of replacing the whole board.
Aug 28, 2010 | New Balance 1400 Treadmill
Lites on control board read ( L 5 ) when machine is turned on.
the e1 symbol is an engineering error code for an electronics malfunction (actually is senses the motor not turning and giving an error. The most likely cause is the motor control board
Mar 02, 2009 | Landice L7 LTd Pro Sports Trainer...
Exercise & Fitness Logo
55 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
