Question about Blackberry Cell Phones
Blackberry Q 10 rooting how to - Blackberry Cell Phones
    Top Expert:
  • Blackberry Master
  • 77,514 Answers
Blackberry phones can't be rooted they are protected by a system to prevent rooting called PRIV
Posted on Dec 06, 2016
Simplify the square root of the fifth root of 64q^8v^6
Square root equivalent to power 1/2
Fifth root equivalent to power 1/5
square root of fifth root (if argument of square root is positive) is equivalent to power 1/10
64^(1/10)*q^(4/5)*v^(3/5)
using 64=2^6 you get 2^(3/5)*q^(4/5)*v^(3/5)
Jul 13, 2013 | SoftMath Algebrator - Algebra Homework...
Solve x^2-22x=10
Just complete the square
x^2-22x-10=x^2-2(x)*11+11^2-11^2-10=(x-11)^2-121-10=(x-11)^2- 131.
Use the identity a^2-b^2=(a-b)(a+b) with a=(x-11) and b= square root (131)
Solutions are x1= 11 + square root (131) and x2=11-square root (131).
By the way, the calculator you are refer to cannot perform symbolic algebra calculations.
Nov 30, 2011 | Casio FX-115ES Scientific Calculator
How can i install jar files in blackberry
Not all JAR applications are compatible with it.. but you can still try..
1. Download to .JAR to your PC
2. Link your Blackberry to your PC via the USB cable
3. Open "Computer" in the Start Menu
4. Go to the folder/location on your PC where you stored the .JAR file
5. Either copy or cut the file (In case there's any oopses, best to copy)
6. In the Drive/Device list under the "Computer" screen find your Blackberry
7. Paste the file either into the root of Blackberry or a subfolder, either will suffice.
8. Unhook Blackberry from USB cable
9. In the applications on your phone (or on home screen depending on Theme) scroll to the "Media" icon
10. Click the "Media" icon to launch it
11. Press the menu button and select "Explore"
12. Locate the .JAR file either on the device memory or memory card
13. Click the file, and it should prompt you to download (install)
14. Click "Download" and you should be good
Apr 06, 2011 | RIM BlackBerry Bold 9700 Smartphone
How do you calculate the cubed root of a number or 5th root of a number?
For cube roots, use the cube-root function in the MATH menu. For example, to calculate the cube root of 8, press MATH 4 8 =
For other roots (including cube root), use the xth-root function in the MATH menu. For example, to calculate the fifth root of 32, press 5 MATH 4 3 2 =
Mar 02, 2011 | Texas Instruments TI-83 Plus Calculator
I have accidentally hidden my SMS icon on my blackberry curve 8520, I can now only my text messages by going into messages / pressing the blackberry menu button / selecting view folder / then selecting the...
Try MENU button Go to APPLICATIONS Look for the SMS & MMS icon select it just moving the touchpad over the icon press MENU button again MOVE TO FOLDER ROOT
Hope it helps!
Feb 27, 2011 | RIM BlackBerry Curve 8520 Smartphone
My blackberry 7290 gives error 507 with a circle at the top
You will receive the following Java error 507 message on your BlackBerry smartphone while using the application loader tool to install or upgrade the BlackBerry Device Software.
Cause 1:
This might occurs while using the application loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
To resolve this error you need to complete the following steps:
  1. Verify that you have the BlackBerry Device Software installed on your computer.
  2. If your BlackBerry smartphone is connected to a laptop computer in a docking station, disconnect the laptop computer from the docking station and connect the BlackBerry smartphone directly to the laptop computer.
  3. If a third-party program, such as a virus scanner, is using the same communications port (COM port) as BlackBerry® Desktop Manager, close the third-party program to free the COM port for use.
  4. If you are using a USB adapter to connect your BlackBerry smartphone to a serial port on your computer, temporarily connect your BlackBerry smartphone to a computer with a USB port.
  5. Open BlackBerry Desktop Manager and double-click the Application Loader icon.
  6. Use the application loader tool to install the BlackBerry Device Software.
Cause 2
This might occurs while all data and applications are removed when an incorrect password is typed ten times into the BlackBerry smartphone.
  1. Open BlackBerry Desktop Manager and double-click the Application Loader icon.
  2. Use the application loader tool to install the BlackBerry Device Software.
Cause 3:
This might occurs while the Power Management feature on the computer turns off the USB ports.
  1. On your computer, click Start > Settings > Control Panel.
  2. In the Control Panel, double-click the System icon. The System Properties window opens.
  3. Click the Hardware tab of the System Properties, and click Device Manager.
  4. In the Device Manager, double-click Universal Serial Bus Controllers.
  5. Right-click the first USB root hub, and click Properties.
  6. In the Properties window, click the Power Management tab.
  7. Clear the Allow the computer to turn off this device to save power check box.
  8. Repeat steps 5 to 7 for all other USB root hubs.
  9. Restart your computer.
Cause 4:
This might occurs while the BlackBerry smartphone is connected to a laptop computer using a docking station.
  1. Disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer using a USB cable.
  2. Re-install the BlackBerry Device Software using the application loader tool.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Oct 21, 2009 | RIM BlackBerry 7290
Describe your what to do if my blackberry 8120 doesnt find signal Problem
A sufficient signal strength is required to send and receive wireless information:-
1) Turn on the BlackBerry smartphone.
2) On the BlackBerry smartphone Home screen, click the Options icon and then click Status.
3) In the Signal field, verify that the value is between -40 and -100 DBM.
To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
Still if it is not working Complete the following steps in sequence until the issue is resolved:-
1) Make sure that the operating system that is running on your computer supports the BlackBerry® Desktop Software.
2)Make sure that the BlackBerry smartphone is connected directly to the computer and not to a USB hub, a docking station, or a USB-to-serial converter.
3)Verify that the BlackBerry smartphone is detected by BlackBerry Desktop Manager by completing the following steps:
a) On the computer, open BlackBerry Desktop Manager
b) Click Options
c) Click Connection Settings
d) Click Detect
4) Perform a hard reset on the BlackBerry smartphone.
5) Use a different USB port and USB cable to connect the BlackBerry smartphone to the computer.
Make sure that your computer detects the BlackBerry smartphone, by completing the following steps:-
For Windows® 2000 or Windows XP
a) On the desktop, right click My Computer, and then click Properties.
b) Select the Hardware tab, and then click Device Manager.
c) Expand the Universal Serial Bus controllers. If the connection is successful, BlackBerry Smartphone should be listed.
For Windows Vista
You must be logged in as an administrator to perform these steps.
a) Click Start > Control Panel
b) Click System and Maintenance
c) Click Device Manager
d) Expand the Universal Serial Bus controllers
6) On your computer, turn off power management for all USB root hubs.
7) Restart your computer.
8) Uninstall and reinstall BlackBerry Desktop Manager.
Make sure that you install the most recent version and that the BlackBerry smartphone is disconnected from the computer throughout the installation process.
9) Use a different computer to establish a connection between the BlackBerry smartphone and BlackBerry Desktop Manager.
10) Log in to the computer with a new Windows user profile and attempt to establish a connection between the BlackBerry smartphone and BlackBerry Desktop Manager.
Oct 16, 2009 | RIM BlackBerry Pearl 8100
Cannot turn on my 8703 Blackberry. Keep getting
A post from the web:
Today I woke up to my Blackberry 8703 sitting with a white screen saying JVM 523 error reset. This was not a good start to the day. I fought with this error across my laptop and the internet for hours today and hope to save you hours trying to fix this.
One of the big problems with the newer Blackberry units is that there is no reset button. Everytime I tried to reset the damn thing I would watch as it would boot up and just as I was about to put in the password - flash - the JVM 523 error would come back.
So now that I have fixed it I will tell you how to get your blackberry up and running again. first of all know that you will lose all the data on the blackberry so if you have no backup, sorry, you will now have a clean slate to work with. Fortunatly I am on a BES server so this is not a big deal to me. OK, now that you know that your data is gone….letting it sink in there….you will be able to rescue your connectivity to the world in two steps with two pieces of data. OK here goes…
1. Download the latest Blackberry Handheld device software. I did a Google search for 8703e handheld device software bell (I use a Bell as my service provider) and then do the install. This will just install to your hard drive which is fine.
2. Download the javaloader.zip file. I decided to host it here in case I have this problem again. extract the javaloader.exe file to the root of your c: drive.
3. Now that you have this javaloader thingy it is time to run it and wipe your blackberry. Open a command prompt and go to the root of C: and run the javaloader with the following command javaloader -usb wipe and hit enter. You will be prompted by the javaloader for your password and then after the 10 second or so wipe you can reboot your Blackberry and it will come up with a blank screen.
4. Run your Blackberry Desktop software and do an application install selecting the core applications and now after a short time of loading you should get to reboot the Blackberry and you will be back in business.
Hope this helps but if not try going over to here. Where lots of poeple are fighting the same fight and may have more help that you may need.
Also, read this post:
http://lichao.net/eblog/fix-rim-blackberry-8703e-jvm-error-523-200805141.html
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 11, 2009 | RIM BlackBerry Pearl 8100
Reload software 507
Cause:
This error message can have the following causes:
While using the Application Loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
All data and applications are removed when an incorrect password is typed ten times into the BlackBerry smartphone.
The Power Management feature on the computer turns off the USB ports.
The BlackBerry smartphone is connected to a laptop computer using a docking station.
Resolution
The following are possible resolutions for this issue.
Cause 1
Resolution 1
Complete the following steps:
Verify that you have the BlackBerry Device Software installed on your computer. For instructions, see KB03295.
Use the Application Loader tool to install the BlackBerry Device Software.
Cause 2
Resolution 2
Open BlackBerry® Desktop Manager and double-click the Application Loader icon.
Cause 3
Note: This resolution is for Windows® XP users only.
Resolution 3
Cause 4
Resolution 4
Re-install the BlackBerry Device Software using the Application Loader tool.
Feb 18, 2009 | RIM BlackBerry Bold 9000 Smartphone
Cell Phones Logo
Top Blackberry Cell Phones Experts
raysaw
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Blackberry Cell Phone Expert? Answer questions, earn points and help others
