Question about Craftsman 25cc Gas Line Trimmer
Pull String Ripped out, How to Replace?
The Pull String ripped out of the Craftsman 25cc 1.5 cu.in 2 Cycle Gasoline Weedwacker I have. I can't seem to figure out how to get in to the casing to re-attach the string. Is that possible?
  • 130 Answers
No its not imposssible.but its not easy unless u have done a few times.you have screws around the plasic casing get them out.and pull
shaft off engine.
Posted on Jul 21, 2009
I have a craftsman WeedWacker 25cc that's dumping to much gas. .. ex. After I choke it and pull the string to crank it, gas drips out of the breather. . Do you have any idea what's causing this?
Yes, the carburetor needs rebuilt. Here are directions on how to do this. This is Part 1 of 3 videos. Once the first video is done, look to the right and you will see Part 2 and so on:
https://www.youtube.com/watch?v=54RIMPW5YgI
Good Luck!
Jim
May 28, 2016 | Craftsman Garden
While trimming a type of brush wrapped around the cutting head and made the unit stall, upon clearing it the head now is weak and does not spin with enough power to cut; how can i fix this?
Remove string cap and tighten nut or you will have to hold shaft just above string head with pliers and turn head by hand till tight.
press the helpful button and check link below
Craftsman 17 25cc Weedwacker
Sep 15, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
How come weedwacker tries to crank while on choke but when you move lever to 2nd position it tries to crank? but wont
When mine does that I go back and reprime repeating the process. It seems the gas does not feed up fully with the initial priming effort. Once it starts I move the choke lever quickly on way or the other to see if I can keep it running until it gets warmed up. Sometimes I have to adjust the choke setting even after it has run for a while.
Sep 21, 2014 | Craftsman WeedWacker Gas Trimmer 25cc...
Sears & Craftsman 25cc Weedeater brand new starts but will not stay running?
Try leaving the chokey partially engaged. Operate it this way for a few minutes until the engine is thoroughly heated then move to the run position. If this does not work return it.
Aug 13, 2014 | Sears Craftsman Convertible 25cc 2 Cycle...
Edger blade quit turning on convertible weedwacker
One of 2 things...drive cable broken or clutch spring broken
Sep 10, 2012 | Sears Craftsman Convertible 25cc 2 Cycle...
Fuel Lines - 25cc Craftman weedwacker
Your Craftsman Trimmer/weedwacker:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=358795591+&pathTaken=partSearch
Best Poulan Engine Match (probably real manufacturer):
http://www.ordertree.com/modelinfo/PWE/BC2400-Gas-Trimmer-Type-6/75.BC2400-Gas-Trimmer-Type-6.1.59.1.html
My decisions are being driven by my experience with Poulan chainsaws. Small hose in tank (long enough to reach all corners), filter on bottom, connects to lowest connection on carburetor. Small hose on upper carburetor connection to small fitting on primer. Large hose from large connection on primer through largest tank hole, roughly mid tank long. nothing on bottom. I suggest you leave the 2 connections on the carburetor long enough they can be swapped (just in case) then try it. if no go swap them.
Typical fuel system and a suggestion or two:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
This is how I would configure it if a chainsaw, doubtful they would do something completely different. In defense of Jerry, he knows how it should be done, clarity of instruction could use some help. Good Luck. HTH
Lou
Feb 24, 2010 | Craftsman 25cc Gas Line Trimmer
My craftsman 32 cc 2 cycle line trimmer doesn't
Check the line head and cable, there may be grass or something like twine twisted between the shaft and housing. If nothing is found there take the spark plug out and see if it will turn over, possibly liquid gasoline has gotten into the cylinder somehow.
Jul 05, 2009 | Craftsman 25cc Gas Line Trimmer
The weedwacker dies when I squeeze the throttle trigger
You need to clean the carburetor. Remove and disassemble carb. Use a den Tek Brush, (used to clean between teeth), to clean the small portals in carb. Use a carb. cleaner while cleaning. Make sure the small screen in carb. is free of debris. The smallest of paticles can cause the carb. not to run right. Reassemble the carb. and try starting. If there is no change, then you will need to buy a carb. kit for your trimmer. Replace all appropriateparts: gaskets, diaphragm, needle valve, and the small screen.
Jim
May 30, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer Logo
1,023 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
