An absolute value equation that the final answers include only positive numbers
    Top Expert:
  • Office Equip... Master
  • 8,204 Answers
How to solve 2.93+19j=-j-5.82-11.25
A long, fairly thorough way that shows the thinking behind it (usually considerably shorthanded in practice):
1) Rewrite the (negative-signed) elements of the equation so that their signs are clearly attached to them and cannot be confused with operations [you could also add the + in front of the positive-signed elements as well] -->
2.93 + 19j = -j + -5.82 + -11.25
2) Add j to both sides to consolidate all the j's on the same side of the equation [adding the same thing to both sides doesn't change the balance/value of the equation] --> 2.93 + 19j +j = +j +-j + -5.82 + -11.25 --> 2.93 + 20j = -5.82 + -11.25
3) Subtract 2.93 from both sides so that the j's are all by themselves on one side of the equation --> 2.93 + -2.93 + 20j = -5.82 + -11.25 + -2.93 --> 20j = -5.82 + -11.25 + -2.93
4) Add up the numbers on the right and rewrite the equation --> 20j = -20
5) Solve for j by dividing both sides by 20 [j's coefficient] --> j = -1
6) Test the answer in the left side of the equation --> 2.93 + 19(-1) --> 2.93 + -19 --> -16.07
7) Test the answer in the right side of the equation --> -(-1) + -5.82 + -11.25 --> 1 + -5.82 + -11.25 --> -16.07
8) Compare and validate: -16.07 = -16.07
Nov 21, 2017 | Math
How do i solve equations involving absolute value
You must consider two cases.
1st case: What is inside the absolute value symbols is supposed positive. Remove the absolute value symbols and proceed to solve.
2nd case: What is inside the absolute value symbols is supposed negative. Enclose the contents of the absolute value within parentheses, put a negative sign in front the left parenthesis, and proceed to solve.
Gather the solutions obtained in the two cases. Use a Union symbol for the solution set.
Oct 08, 2014 | Office Equipment & Supplies
Complex matrix
Is it complex or matrix? You can have only one mode at a time.What kind of equations? The solve function uses real-valued equations.
Complex numbers: You can add, subtract, multiply and divide. You can convert a number from rectangular to polar forms and vice-versa; you can calculate the absolute value of a complex number, or a conjugate.
All the operations are done in the Mode CMPLX.
Feb 04, 2014 | Casio FX991MS Scientific Calculator
What are the equations and its kinds?
A mathematical statement used to evaluate a value. An equation can use any combination of mathematical operations, including addition, subtraction, division, or multiplication. An equation can be already established due to the properties of numbers (2 + 2 = 4), or can be filled solely with variables which can be replaced with numerical values to get a resulting value. For example, the equation to calculate return on sales is: Net income ÷ Sales revenue = Return on Sales. When the values for net income and sales revenue are plugged into the equation, you are able to calculate the value of return on sales.
There are many types of mathematical equations.
1. Linear Equations y= mx + b (standard form of linear equation)
2. Quadratic Equations y= ax^2+bx+c
3. Exponential Equations y= ab^x
4. Cubic Equations y=ax^3+ bx^2+cx+d
5. Quartic Equations y= ax^4+ bx^3+ cx^2+ dx+ e
6. Equation of a circle (x-h)^2+(y-k)^2= r^2
7. Constant equation y= 9 (basically y has to equal a number for it to be a constant equation).
8. Proportional equations y=kx; y= k/x, etc.
Jun 14, 2011 | Computers & Internet
First thing to do, before you enter the value of the equation to your calculator multiply the first term((1/3x+5) from the second term(1/3x+5) to make your answer simplified.Then after that you will observed that your answer look like in this pattern AX2 +BX+C it means that the equation is in general form of quadratic equation. So, in your problem,we are looking for a value of X1 and X2,when you used your calculator in solving this problem, First On you calculator then look for the mode then press it after that look for the equation(EQN).Then from the side of the word EQN there is a corresponding number to press,from my calculator it is number 5..Then press it.After you press it, there is a equations choices,look for the equation AX2 +BX+C then press it(given number to press). Now,enter the value of A, B and C from your simplified answer. After pressing the value of A press = sign from your calculator same as B and C.After you enter all the value of A,B and C continuously press = sign from your calculator till you get the answer, the value of X1 and X2.
Jun 14, 2011 | Texas Instruments TI-30 XIIS Calculator
Input in standard form the equation of the given line. The line that passes through (1,5) and (-2,3)
You are looking for a line (y=m*x+b) and have two points. From this information you can generate two equations with two unknowns (m and b are unknown).
First plug in the first point (1,5) to the general form:
5(the y value of the point) = m*1(the x-value at this point)+b
Do the same for the second point you're given.
From here solve the first equation for m in terms of b.
Plug this value of 'm' into the second equation so you will end up with something like:
3=(something in terms of b)*(-2)+b
This final equation can be solved for b (try factoring)
You now have a value for the y-intercept. Plug that into y=m*x+b
Choose either of the two points, plug into the equation on the last line with the value of b known
You then know y, x, and b and have m as the remaining 1 unknown. Solve for that and put it all together for your final answer.
Apr 23, 2011 | Texas Instruments TI-83 Plus Calculator
How do you determine absolute value on a TI30XA calculator?
If you are looking for a key, there is none. However, you can still determine the absolute value easily.
  1. If you have a single number and its positive, the absolute value is the number itself.
  2. If you have a single number and it is negative, just drop the leading minus sign or negate it by pressing the change sign key (+ -).
  3. If you are handling a complicated expression just calculate it. When you obtain the final result (a number) use rule 1 or 2 above.
Aug 23, 2010 | Texas Instruments TI-30XA Calculator
27 people viewed this question
