Cars & Trucks Logo
D
Danny Fennelly Posted on Dec 06, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can i source this belt?
Its on a woodchipper that is over 40yrs old
Marvin
Level 3:
Top Expert:
  • Cars & Trucks Master 85,242 Answers
  • Posted on Dec 06, 2016
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29025378
Points
266281
Measure the old belt and go to an auto parts store like NAPA and they should be able to either match it or order it for you, if you don't have the belt then measure the belt run (pulley to pulley groove) with a piece of string.
Testimonial: "Perfect thanks sorted now"
When should the timing belt be changed on 2011 vw crafter auto
Follow th emanufactors maintenance gulde that came with the car or:
It\'s easy to check the belt for signs of premature wear -- just locate it in the engine bay (usually under a plastic or metal shield that should be easy to remove) and check it for drying, fraying and discoloration.
The belt itself is inexpensive, probably costing less than $20 at an auto parts store. Your mechanic will probably charge several hundred dollars (or more) for a belt replacement service, though. Those hours spent dismantling and reassembling the engine bay add up quickly.
You can replace the timing belt yourself if you have access to the necessary equipment. In some cars, it\'s a straightforward procedure -- remove the engine covers and shrouds, line up the camshaft and crankshaft, slip off the old belt, and slip on the new one. Sometimes, though, it\'s a lot more complicated. For example, the timing belt might loop through a motor mount, in which case the mount would need to be removed to access the belt. You\'d need an engine hoist or stand to safely remove and replace the mount [source:Juran].
Keep in mind that an error in this job, such as improperly turning the engine by hand or failing to coordinate the shafts, will cause the same damage as a snapped belt. Make sure you understand the procedure before getting started.
source:
http://auto.howstuffworks.com/under-the-hood/car-part-longevity/timing-belt-last.htm
Changing timing belt 1990 geo storm
old post
answer is :
same as Isuzu Impulse
4XE1
my guess would be for 90. the single cam version
the best source of data is alldata.com
or on the storm forums.
some links here.
http://www.fixkick.com/storm.html
old post but, rare cars. i help on rare.
1helpful
03 eclipse making noises in cold weather
First you need to find the source that is causing noise. On cold weather is very normal engine belts or belts idle pulley bearings or belt tension-er to make noise, especially when they are old. Also power steering pump too especially if the oil is very old.
1helpful
New battery is correct size, but rear side holddown does not reach from its lower retainer to top of battery.??
No some of these toyotsa batteries are a funny shape compared to the standard aftermarket ones so when i get this sort of problem i scavange my scrap/junk pile and make one depending on what type i need ,a few bits orf metal rod with something welded on works wonders .Just like the old days 40yrs ago on fleet truck repairs with bedford TK and ford traders or the old scalmmels
When I start up landcruiser, the belts squeals for a moment then it stops. but you can still here the belts movments. Is there anyway to fix the squeal and belt noise. Is there a way to calm down engine...
either tighten or change the belt if it looks damaged. a burnt bearing could be at fault, with the old belt on, mix some liquid soap with water, keep your face away or wear goggles, and pour the mix onto the belt at the pulleys like the alternator one, and you will find out that it stops squealing and you have found the source of the sound. fix whatever is broken and you won't have to raise you radio as much when you drive.
Enjoy !
Torque setting for '97 Range Rover 4.0 oil pan
pull wrist tight on a 38th drive rachet ,thats about right or 20nm according to my fancy autodata book ,never used a torque wrench on anything in 40yrs of being a fitter ,i must be a cowboy then musnt i
Ford transit 2001 -bulb of the glow plugs, always stay lit
internal fault in the heater relay timer box ,nice motor though a transit ,used to work on the assembly line 40yrs ago .
2006 nissan sentra drive belt install i can not figer out how to install both belts and what the tq is for the two bolts
keep trying and it will come ,as for the torque then just tight with a 3/8 drive socket set will suffice ,been fixing motors for 40yrs and never use a torque wrench,have one in case a customer is around ------
2answers
1993 Volvo 940-T, the horn does not work, I have removed the horns and they work when connected directly to 12 volt source. When connected to the car leads they do not work in spite of getting voltage at...
power to the connectors ?? then you have a dirty earth connection ,.Says i running around room screaming like a demented demon ,RELAYS RELAYS why do the americans shout relay all the time ,apart from the odd flasher relay i have never had a problem with a relay in 40yrs of fixing cars and trucks .Unless they are made in china i suppose
1/2 of the lights on my instament clust is out
what is an instament clust?????this is a new technical term i think as after 40yrs in motor trade i must be getting old and senile
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
