Question about Proscan Televison & Video
I have a GE24922 universal remote and have been trying to program my proscan tv. None of the codes work & and have tried the code search nothing seems to be working.
    Top Expert:
  • Proscan Master
  • 77,932 Answers
Have you tried 047? That is the only code listed for a Proscan TV.
Posted on Dec 06, 2016
SOURCE: moxi remote control
The "universal code" 9910 is just the first step in doing a program search. Hold down the MOXI and OK buttons simultaneously until you get the double blink. Then enter 9910 and it will blink twice again. Then begin alternately pushing MUTE and the up arrow (above the OK button). Pushing the up button effectively cycles through the codes and pushing MUTE tests the current code that it is on. Do not go too fast because when you finally push MUTE and it actually mutes (or unmutes) your TV, you must push the OK button to store that code. I just performed this procedure and my first positive code that I stored only affected the mute and volume settings on my TV and would not turn the power on or off. If this happens to you as well, repeat the above process and just skip over the first positive you get until it mutes (or unmutes) your TV again.
Posted on Nov 15, 2008
SOURCE: lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Posted on Mar 17, 2009
  • 110 Answers
SOURCE: can't program direct tv remote control to the tv
Try here:
Posted on May 23, 2009
SOURCE: need a remote control code
hi,i had the same problem and found out that the samsung remote codes worked,try that.
Posted on May 30, 2009
SOURCE: Universal Remote Codes
I just programmed my comcast remote today and the codes in the manual work fine. I was lucky, the first one as the one I needed. Good luck.
11454, 10054, 10030, 10706, 10187, 10386,10802,11198,11254,11963,11990.
Posted on Jun 06, 2009
What is the code to program an iview universal remote 2600 hd to a proscan 32 inch LCD TV model no. 32LB30Q
You can use code search to find something the handles some or all functions. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Mar 13, 2017 | Proscan Televison & Video
I need the code for a universal remote to work with my Proscan tv
Your universal remote has a code search feature you can use to search for an appropriate code for your Proscan TV. If a thorough search through all codes stored in the remote fails, you may have to try another universal remote.
Mar 07, 2015 | Proscan 42LA45H 42 in. LCD TV
Proscan tv codes
I found this on ChaCha.
The most popular code to program a remote control to a ProScan TV is 10047 (Others: 10466, 11347, 11447). ! - See more at:
I hope this helps!
Jan 04, 2014 | Televison & Video
I bought my 19" Proscan LCD (19LA25Q) used from a
The Proscan 19LA25Q came with a remote originally. Unless the IR receiver has failed, it should work with a universal remote. (Note: if the TV is newer than the remote (or released less than 6 months before the remote was programmed), the remote codes for your TV may not be included.) Since the code lists on universal remotes do vary depending on the age and model, please give more information than just the brand. GE remotes usually have a version code label in the battery compartment. This version code is needed to look up the correct code lists. Some GE universal remote built by Jasco codes are here:
The Proscan 19LA25Q was probably built in 2007, since there are reviews from 2007. That was also the year when this size TV had to have an ATSC tuner. So if your remotes were programmed before July 2007, they may not be compatible. Some of the current Proscan TVs probably use the same parts as some Sylvania, RCA and Curtis TVs.The 19LA25Q was warranted by On Corporation which has control of the RCA brand now. However, I don't know when they bought the label.
Amazon lists a few direct replacement remotes for the 19LA25Q. See and . also has a replacement remote: .
I hope this helps.
Apr 21, 2017 | Proscan 19LA25Q 19 in. LCD Television
None of the Proscan TV codes I have work In My COX universal remote
Than the COX universal remote dose not work with the Proscan tv.Try website like to buy the same exact to the original Proscan tv remote.
Oct 18, 2010 | Proscan 32LA30Q Television
Can't get universal remote or cable remote to work with my tv.
I need programming instructions for proscan universal remote control. I have code.
Feb 20, 2009 | Proscan 32LA25Q 32 in. LCD TV
Lcd 32" proscan need code for universal remote
Oct 19, 2007 | Proscan 32LA30Q Television
Televison & Video Logo
35 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
