Question about Saws
How to change blade on a FlorCraft wet tile saw mod 709-3917
  • 10865 Answers
SOURCE: crooked cuts
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Posted on Jan 28, 2009
  • 31 Answers
SOURCE: how to change blade
remove the blade guard, should be a big nut holding on blade remove that nut install new blade, make sure the rotation arrow on your new blade is going same direction as old blade reinstall the big nut and washer , put guard back on you should be set! good luck
Posted on Mar 24, 2009
  • 29 Answers
SOURCE: Tile Saw
i know blades on tile saws don't have to be super tight, i'm not familar with that kind of saw, i put a wrench on the nut and hold on to the blade with my hand and hit the wrench with a rubber mallet, and of course have the unit unplugged
Posted on Mar 26, 2009
woobie dog
  • 1273 Answers
SOURCE: I have a small ceramic tile saw. I have
Look for a button that you can press to lock the shaft in position. When you depress the button, you may still have to revolve the blade and shaft until the lock engages the shaft. Then unscrew the bolt from the shaft. Some others have an Allen wrench well in the end of the shaft, and you can insert the allen wrench to hold the shaft while operatiln the wrench to loosen the blade. Some others have a slot in the shaft end for inserting a slotted standard screwdriver for holding the shaft while the wrench is used to loosen the blade.
One of these methods will be available to you!
Best regards,
--W/D--
Posted on Nov 10, 2009
al_kupchella
  • 843 Answers
SOURCE: Looking for shaft lock to change the blade on MK 170 wet saw
Just use a rag and grab the blade. Unless the threads are messed up you don't have to hold the arbor still, just the blade.
Posted on Apr 27, 2010
Wet saw is not cutting square, blade is new but once it hits the tile is shimmies.
Make sure you have the correct blade. There are different blades for different tile. ie ceramic blade for ceramic tile.
Dec 31, 2016 | Blade Saws
Looking for the blade guard arm.
Search Results
    7" Job Site Tile Saw with Laser - RIDGID Professional Tools
    https://www.ridgid.com/us/en/7-inch-wet-tile-saw-with-laser
    Ridgid7" Job Site Tile Saw with Laser. ... Heavy Duty Arm - prevents flexing while keeping the blade aligned; Guard Baffle - reduces air turbulence to help keep water ...
    [PDF]7" BRIDGE TILE SAW
    manuals.harborfreight.com/manuals/97000-97999/97360.pdf
    7" BRIDGE. TILE SAW. WITH STAND. Owner's Manual & Safety Instructions. Save This Manual .... that has an outlet that looks like the one illustrated above ... Use saw-blade guard and spreader for every .... arms and shoulders. To reduce the.
    [PDF]10" INDUSTRIAL TILE/BRICK SAW Owner's Manual ...
    manuals.harborfreight.com/manuals/69000-69999/69275.pdf
    parts. Nonslip footwear is recommended. Wear protective hair covering to contain long hair. 11. ALWAYS USE ... an outlet that looks like the one illustrated above in Figure A:... For Your Own Safety Read Instruction Manual Before Operating Saw. 1. Wear eye ..... Connect the clear water Hose from under the arm of the Motor ...
    SKIL 7" Wet Tile Saw 3540
Dec 16, 2015 | Blade Saws
Can a FlorCraft 7' wet saw cut tile and paver brick (2.5" x 8' x 3.5")
My advise would be to read the user manual and determine the maximum cutting capacity of the saw and which materials it can cut. Pavers are usually precast concrete and a diamond blade should handle this easily. NB, The depth and width of cut are the crucial points. Read the manual and check the specification. Download a replacement if you have lost the original.
Jul 23, 2015 | Saws
Rigid tile saw. Can I use a wood blade?
Tile saws are designed to use a diamond blade, and to keep it wet. That's not something you want with a wood blade, nor with wood. The speed of a tile saw is much slower than a good wood saw. I wouldn't try it.
May 27, 2015 | Blade Saws
The nut that holds the saw blade on is flat like a washer. I can't find a tool to remove it. i want to change the saw blade.
Some of those nuts had 2 holes in them and there is a special tool that fits in the holes and you turn the tool to unloosen it.
Mar 16, 2011 | Wet International Q.E.P 4 inch Portable...
Apr 27, 2010 | Mk Diamond MK - 170 Wet Cutting Tile Saw
How to change blade
Mar 24, 2009 | Dewalt D24000S Wet Saw With Stand
Crooked cuts
Jan 04, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
Tile Saw
Aug 31, 2008 | Saws
Saws Logo
188 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
