Question about Refrigerators
The lights are on but the fridge and freezer are out. Lighted up of OF. Model is RF4287HARS/XAA
  • yadayada
    yadayada Dec 06, 2016
    The lights are on but the fridge and freezer are out?? what does that mean
  • 35 Answers
SOURCE: We have a bottom freezer top refridge LG unit. It
the man board is the problem.
replace it with new one..
Posted on Apr 07, 2010
  • 343 Answers
SOURCE: samsung frig model rf4287hars xaa not making enough ice
I would check the water inlet solenoid to see that it is properly functioning. It could be in need of repair or replacement.
Posted on Apr 02, 2012
radco855
  • 126 Answers
SOURCE: Samsung RF4287HARS not cooling and I cannot feel
One possible senerio that could cause this is the coils are frozen up. If coils are frozen, no air can blow through the coils into either the freezer or refer section. This is caused bya failure of the defrost timer. (Don't know where it's located on yours but on an old one I owned, it was under the unit (accessible by removing a front cover) at the front. If the timer (or defrost coils) are not working, frost continues to build until te coil is frozen solid. This would oresent itself as a slow failure to cool, that is, each day (over 3-4 days) the refer section will get warmer.
Posted on Apr 14, 2014
yutianyunren
  • 848 Answers
SOURCE: Samsung refrigerator Model # RF4287HARS/XAA--I bought the part DA97-08519A, just need to know how to replace this part
Samsung refrigerator Model # RF4287HARS/XAA--I bought the part DA97-08519A, just need to know how to replace this part? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
IP 45130A Samsung BN44 00127F Power Supply Backlight Inverter
Posted on Feb 02, 2015
Sea Breeze
  • 4654 Answers
SOURCE: samsung RM255LABP/XAA freezer only gets to 27 degrees, won't harvest ice. Fridge and lower freezer work fine.
Ice cannot be produced at that temperature you're going to have to find out by taking the drawer out removal of the rear wall of the freezer and see if the evaporator is freezing over or is the condensate drain opening is blocked. Your model has dual evaporators and we need to see if your evaporator in the freezer is defrosting properly or if for some reason the defrost drain is blocked causing moisture to cover the fan causing a cooling problem.
Appliance 911 Sea Breeze
Posted on Sep 01, 2016
Ice buildup in bottom of freezer compartment
Here's a link to a great website that will help you understand what might be causing your freezer to have that ice build up. I could explain it here, but if you look at this link, they've already done a wonderful job.
http://www.appliance411.com/faq/defrostproblem.shtml
Jun 08, 2016 | Samsung RF4287HARS French Door...
Freezer freezes food, but why is ice cream melting?
Hi
It would be helpful for the model as some samsung models are single cooling and some twin cooling,please supply the model and i will be able to help.
Bryan
Dec 29, 2015 | Samsung French Door Refrigerator Right...
No it's a whole assembly the plastic clip is broken. Give me a model number I'll track down the part for you.
Oct 05, 2015 | Samsung French Door Refrigerator Right...
Samsung rf217acpn/xaa fridge not staying cold and ice build up.
Be sure the drain is clear these are well known for drain blockage. the area behind the shelves is where you would find the evaporator and drain hole.
"Always disconnect power before trying to repair any appliance."
Jul 11, 2017 | Samsung 19.7 Cu. Ft. French Door...
Samsung Refrigerator Model# RF4287HARS/XAA Serial# 102043CB303152 J Refrigerator is cold, the freezer is 63 degrees warm.
This could be caused by several different reasons so I need you to check a few things. If you want to know right off what is causing the temperature symptoms you will need to answer my questions. Can you tell me how hot the top of compressor feels? Too hot to keep your hand there? The fan motors are they working strong without obstruction? Can you feel the copper lines/pipe that exit the compressor for one line being hot and the other cold? As for the temperature ohms reading you get when testing the thermistor you will first need use the=> RF4287HARS Fast Track Tech Sheet page 2 Answer my questions and I will assist you in finding the cause of the problem. I am here waiting for your response,Sea Breeze
RF4287HARS Parts
Dec 08, 2013 | Samsung Refrigerators
Error code OF OF
Try lighting and freezer for 3 seconds, or until you hear a beep. (The 2 left on my model) This worked both times I had the issue.
Jan 28, 2013 | Samsung RF4287HARS French Door...
Samsung frig model rf4287hars xaa not making enough ice
Apr 02, 2012 | Refrigerators
Model RS267LBSH/XAA - freezer working but refridgerator side warm (54 degrees). Heard sound like fan blade hitting, then no longer hear fan at all. What could it be
Have same model rs267lbsh/XAA and fix refrigerator. What I did was take off cover where evaporator is there a wire called defrost temperature sensor that goes bad I changed that sensor and my fridge is now working .if u need to ask me question please email me at jwilliams1957@sbcglobal.net
Apr 12, 2011 | Samsung Refrigerators
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
