Question about Whirlpool GH5184XPQ Microwave Oven
How to replace cracked plastic door frame on Whirlpool microwave?
The plastic frame on the door of our Whirlpool MH1150XMT0 microwave has a stress crack under the handle and running from the middle screw hole on the side of the door to the glass front. I have a new frame and glass (part # 8185285). After removing the screws on the side of the door under the handle, I can't find a way to dismount the frame. What are the next steps ?
  • Whirlpool Master
  • 9,047 Answers
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jul 20, 2009
How to replace the door handle on a whirlpool MH2155XPQ micro wave
The screws that hold on the handle are inside the door assembly. Here is the way its done but its not for the average person. On the inside of the door is a plastic frame all the way around the door. It is held in place by plastic tabs. You have to gently pry off that frame with something like a putty knife or small screw driver. If you are not careful you end up breaking off some of the tabs. Once that frame is off you should have access to the 2 screws holding on the handle. Remove screws---replace handle---and push plastic frame back on.
Jun 26, 2015 | Whirlpool MH1150XM Convection/Microwave...
Trying to replace handle on door,removed three screws on side of door unable to remove inside panel
Most microwave doors are just clipped together with plastic tabs.To remove the inner door panel you need to carefully pry the plastic frame off the inside with something like a small screwdriver or putty knife. Even being careful you may end up breaking the tabs or frame. Once the inner frame is removed you should be able to get to the handle screws. I'll try to attach a picture of the door breakdown.
May 09, 2015 | Whirlpool MH7140XF Microwave Oven
Can I replace the door locking mechanism on a GE JVM1650 microwave oven?
If you are talking about the 2 hooks that stick out of the door, in most cases yes they are replaceable. also the switches behind the holes the hooks go into are also replaceable. Door hooks can be accessed by carefully prying off the plastic inner door frame around the hooks. You have to be gentle or the frame will crack. Take your time and go slowly all the way around the door.
Feb 25, 2015 | GE SpaceMaker Microwave Ovens
The outside panel of my whirlpool model MH1160XSD0 model is crack can this be replaced?
Yes, the door panel comes off easy (3 screws on the side). Mine was cracked so I ordered a new one. Not the vent above it is cracked. Cheap plastic!
Mar 12, 2014 | Whirlpool MH1150XMQ Microwave Oven
Whirlpool microwave hood combination has code f2 on touch panel. Model number: MH-1150xm
The F2 error means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
On these models, usually the membrane keypad is not available separately, so you would have to order and replace the control panel frame which comes with a new keypad (sometimes called "panl-cntrl").
The part availability and cost will depend on the full model number from the tag on the unit, and it will be one of these:
MH1150XMB0
MH1150XMB1
MH1150XMB2
MH1150XMB3
MH1150XMB4
MH1150XMQ0
MH1150XMQ1
MH1150XMQ2
MH1150XMQ3
MH1150XMQ4
MH1150XMS0
MH1150XMS1
MH1150XMS2
MH1150XMS3
MH1150XMS4
MH1150XMT0
MH1150XMT1
MH1150XMT2
MH1150XMT3
MH1150XMT4
You can order the part and find helpful exploded view diagrams here.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Jul 08, 2010 | Whirlpool MH1150XM Convection/Microwave...
There is a whirlpool Microwave (model:MH1150XMB4) in our apartment. Unfortunately, there is a crack in the door. Although the crack is only in the plastic frame of the door, the landlord asked us to...
Got the same problem. Still inquiring but I might have found a solution here : http://midwestapplianceparts.com/microwave-parts-537/whirlpool-microwave-parts-648/microwave-door-panel-663/whirlpool-microwave-door-panel-w-glass-4212.html
$79 for the panel only
Jul 01, 2010 | Whirlpool MH1150XMQ Microwave Oven
How do I remove the old door frame and handle on the whirlpool microwave
To remove the handle yo need to pull off the inner plastic spacer (choke). The outer frame comes off by removing the screws on the edges.
Eric
Oct 04, 2009 | Whirlpool MH1150XMQ Microwave Oven
Light won't go out when closing the door
The door switches are out of alignment or one has failed. Eric
Sep 05, 2009 | Microwave Ovens
How to remove the outter door frame on the GE Microwave
You need to use the entire correct model number at their site, but you can find a helpful exploded view PDF diagram by searching for "Repair Part" at the GE parts site: http://www.geappliances.com/shop/prts/ Normally you can separate the door panels without removing the door. I've included a diagram from a Sharp model that might help. If you do have to remove the door, you have to be sure you reinstall it exactly where and how it was, or you may get microwave leakage. You should definititely mark the locations of all the hardware before disassembly.
Nov 06, 2006 | GE JVM1650 1000 Watts Microwave Oven
Whirlpool GH5184XPQ Microwave Oven Logo
2,054 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
