Question about The Watches
I purchased a Howard Miller grandfather clock and its keeping time but the pendulum is barely moving. What vould be the problem?
  • The Master
  • 3,178 Answers
If the clock has a real clockspring mechanism ( with dozens of visible gears), then the problem is likely it needs to be cleaned.and adjusted.
Posted on Dec 06, 2016
I have a Dakota Daniels grandfather clock. The chimes work, the pendulum works, but the clock hands don't move.
Change the batteries. The weight makes the pendulum and chimes work, but the clock in this thing is battery operated :>)
Accurate hourly Westminster chime movement tolls the hour - Automatic night shut off
  • Cathedral pediment, blue moon metal dial with raised roman numerals
  • Pendulum, weights and chains are made out of metal - Real tempered glass
  • Sturdy construction - Made of MDF & solid wood - Batteries (3-AA & 2-C) not included
  • Dakota Daniels grandfather clock Google Search
    Dec 12, 2016 | Dakota Watches
    I purchased a Howard Miller grandfather clock and the clock is keeping time but pendulum is barely moving. What's the problem?
    Hi Pam,
    I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick.
    Howard Miller Grandfather Clock
    Dec 06, 2016 | The Watches
    Just bought a Howard Miller 620-160 wall clock. The pendulum is not swinging! What is wrong?
    First thing to check is for locks that are put in when shipping so that it wont be damaged. If it is battery powered, check the battery.
    Apr 02, 2016 | Watches
    Re: Galleria / Metro Grandfather Clocck. W/ pendulum on lower hanger clock runs slow. W/ pendulum on upper hanger clock runs fast. How can I adjust so it will keep correct time, or should I take it to a...
    Most grandfather/grandmother clocks have an adjustable screw on the weight to slightly extend it or shorten it to satisfy the equation of pendulum swing. the shorter the swing (arc distance) the faster the clock, the longer the swing the longer the time. Check to see if you can adjust the weight up or down on the hanger.
    Jan 01, 2011 | Watches
    Coaster model 900723 grandfather clock doesn't keep time
    Everybody should know that the coaster clocks discussed here run on batteries. The timing mechanisms, the chimes as well as the pendulum all are powered by a battery. Changing the speed of the pendulum is impossible because there is no adjustment. Besides, it wouldn't matter anyway. The pendulum has now affect on the clock's ability to keep accurate time. It is purely aesthetic. This is a pretty cool looking clock and even has weights, but those are also purely aesthetic and do not move the way a classic grandfather clock weight would move. The moments with these clocks are not designed to be worked on. These clocks are relatively inexpensive (approximately $300) but do add a nice look to your home. Grandfather clocks snobs would say though; this is not a true timepiece. They're right... Sorry._1513.jpg
    Nov 20, 2010 | Watches
    How do you determine what side of the chain that the weight goes on to affect which way the clock turns - at this time the chain is completely off the wheel - clock was recently packed and moved cross...
    We would like to talk you through this problem.
    If you want to call, My number is on my profile.
    I am available afternoon Feb 25 you are welcome to call.
    R/
    David
    http://antiqueclock.clockstop.com/
    Feb 25, 2010 | Watches
    What ports wind what?
    On mine, the center one (@the 6 position) is the one that keeps the pendulum swinging. It is the one that lengthens the most during the week and if I forget to wind it, that pendulum is all the way down when the clock stops.
    May 02, 2009 | Watches
    I inherited a grandfather clock which runs slow
    You have to adjust the bob on pendulum. If the clock is slow, the bob on the rod must be pushed up. If the clock is fast, the bob must be pushed down. Do adjustments bit by bit, day by day till the clock is keeping time. If all this does not work, you may need to replace suspension spring (if there is any). If there are no suspension spring, the clock may need proffessional attention.
    Mar 23, 2009 | Watches
    Watches Logo
    82 people viewed this question
    Top The Watches Experts
    D. E. Hev
    John mullen
    vince
    Are you a The Watch Expert? Answer questions, earn points and help others
