Question about OFFI Natural Ply CR10 Crib
One of the sides won't lock on our nature's purest playyard
There is a mechanism in the middle of the bottom of the pen. However, doesn't seem to help sides locking or unlocking.
3 Suggested Answers
SOURCE: I need an assembly instruction
I found the instructions for you. Here is the link, I hope that it helps
http://www.summerinfant.com/images/upload/64050.64053%20Natures%20Purest%20Soothing%20Comfort%20Playard%202L.pdf
Posted on Jan 24, 2009
How to assemble safari nature purest bassinet
sorry we didn't receive a copy .
Jul 28, 2015 | Baby Gear
Natures purest swing won't swing
I have the same problem. Works fine then next time I go to use it it won't work.
Feb 21, 2013 | Summer Infant 66010 Nature s Purest...
Pen won't write though plenty of ink
There are a couple reasons a pen refill won't start writing right away. The first thing to check is the tip--often there is a bit of glue or plastic over it in order to prevent leaking.
If that doesn't work, then try one (or both) of the following two methods:
1) Place the refill (but not the tip) in some warm water. Heat will allow the liquid in the gel pen to become thinner and flow more naturally.
2) Hook a rubber band around the middle of the pen, using tape to ensure safety, and wind the pen while holding the rubber band on either side of the pen. Make sure the cap is on the pen. When the rubber band is tight, when you pull straight out on the rubber band from both sides of the pen, it should spin very quickly. The centripetal force will cause the liquid in the pen (at least half of it) to move toward the tip.
Make sure you fasten the rubber band to the pen with tape or something similar; otherwise the pen may go flying off at someone nearby. Also, again, make sure the cap is on to prevent any ink spraying out--this is unlikely in a gel pen, but it could happen.
Jun 13, 2011 | Sanford UniBall Gel Impact Rt Retractable...
Manual for carter's playard to fold up
All playyards require you to have the bottom of the playyard pulled upward.
There should be a pull on the floor of the playyard/ Lift it up and then and ONLY then
can you lower OR raise the sides. This is a safety feature.
Mar 09, 2011 | Summer Infant Carters Bumble Comfort n...
I have a pack and play that will not lock at the bottom and i was wondering if there was any way someone could help me
the center of the pen must be up the do the sides while the middle is up then push the center down.
Jan 26, 2011 | Graco Pack 'n Play
Don't have manual for fisher price ocean wonders deluxe playyard? How do you keep the sides up?
All pack and play play yards require the bottom floor to lifted like a little volcano in the middle before the side will go up or down. Some have a twist lock others just pull upward. Lift the middle handle up about 6" to 12" and then raise the sides. Once all the sides are up, press the floor flat. Done. Nothing goes up or down until the middle safety is up like a volcano.
Apr 25, 2010 | Fisher Price Deluxe Perfect Support Baby...
I need to uninstall natures purest sleepy safari playard, HELP!
follow the sides of the changing table, underneath the cover towards the bottom are push in nails/pins. Everything on the crib is push in nails to take apart. First remove the obvious parts like the diaper holder and the sun shade..Hope this helps. I lost the directions to and just put is back together, now I;m taking it apart.
Jul 03, 2009 | OFFI Natural Ply CR10 Crib
1998 Chevy Cavalier trunk release issue PLEASE HELP
when it locks around the pen and you pull up on the pen does it unlatch,wd-40 the latch,if it keeps popping up lube the cable thats attatched
Jul 07, 2008 | 1998 Chevrolet Cavalier
OFFI Natural Ply CR10 Crib Logo
95 people viewed this question
Top OFFI Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you an OFFI Baby Gear Expert? Answer questions, earn points and help others
