Question about Xerox Office Equipment & Supplies
How to solve xerox workcentre 5645 error 10-530
  • Malik Basha
    Malik Basha Jan 12, 2017
    How to solve xerox workcentre 5755
    error 10-530
  • 1362 Answers
SOURCE: Xerox Workcentre Pro 123 error code 016-719
this is not a mechanical error but a software error.
It either doesn't recognise the format or program
as for the driver don't thinkit's the problem the HP can use PCL6
Posted on Sep 08, 2008
Hi Dear
I am facing LSU Error on my Xerox workstation PE 220
I am not able to do anything, please let me wat to do
i have lot of work penindg
Posted on Oct 13, 2008
  • 2072 Answers
SOURCE: workcentre c2424 is showing system error 39,003.40:117010
That is a document feed or scanner fault. Often times it is simply that molex connector working loose. It is the connector mounted vertically next to the main power cord on the right rear side of the machine. That bottom screw can be dificult to tighten. What I would try first is to shut the machine off, unscrew and disconnect that conntecot totally then firmly slide it in and get both the top and bottom screwss tight. Like I said, the bottom thumb screw can be hard to tighten even with a screw driver because it is a pretty soft rubber the tighteners are made out of.
If that doesnt work. go to the back and disconnect the document feed to scanner cables and reconnect. Other than that, you pretty much have to replace the feeder/scaner assembly since very very few parts are spared for that .
Posted on Oct 23, 2008
  • 2072 Answers
SOURCE: What is error 010-333?
That is a fuser over heat code. You will most likely have to replace the fuser module. Or have service do that for you.
Posted on Jan 05, 2009
SOURCE: Is there a Mac workaround driver for the Xerox WorkCentre PE16
Recently I had to configure a 17" Aluminum PowerBook and a Xerox Workcentre PE 16. That multifunction laser monochrome printer is not supported by MacOS X, but I tried all the same.... and no glue for that, until I went on the Samsung webpage and noticed their SCX-4216F printer. This machine is the same as the PE 16.
So I downloaded the lastest drivers from Samsung's download centre (drivers for Tiger too), installed the drivers on the PowerBook (running 10.3.4), connected the printer and when I selected the printer ... tada! It automatically selected the Samsung driver, so I clicked on OK and started printing. Everything was OK!
But it doesn't end here: even the Lexmark X215 MPF has the same chassis as the Xerox and Samsung. Yet, on Lexmark's website there are no Mac OS X drivers, but Samsung's drivers work just the same. I hope this hint will help others...
Posted on Jan 26, 2009
How can fix error u4 code in xerox photocopier machine
Unsure what model Xerox is displaying error u4.
To pursue your question further, please provide Model name and number that is on the equipment in question.
My Xerox Workcentre 5020 machine showing U4 error How can solve this...
Feb 19, 2018 | Xerox Office Equipment & Supplies
Workcentre 5655. How do I complete the install phase?
[PDF]Xerox® WorkCentre® 5632 / 5638 / 5645 / 5655 ...
Xerox5632 / 5638 / 5645 / 5655. Multifunction System. Inspired redesign. WorkCentre®. 5632 / 5638 / 5645 / 5655. Tabloid-size. Black-and-white. Multifunction System ...
Oct 07, 2015 | Xerox Office Equipment & Supplies
Error 016-311 xerox workcentre M128
This error code means the Scanner is not installed. The reason for this code could be a bad or diconnected interface cable, or corrupt system software. Check the cables for connectivity. If the problem persists, it will probably require a call to Xerox service. 800-821-2797
Nov 08, 2009 | Xerox WorkCentre M128 Copier
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
I have Xerox workcentre pro 128 copier machine. can you solve my problem? when i copy before appear this Error code 123-396.
That is a software related error, You most likely need to reload the firmware, or replace the hard drive.
You can try disconnecting all the document feed and scanner cables then reseating them. Other than that, your looking at a software issue.
Jan 28, 2009 | Xerox WorkCentre PRO 128 Copier
Xerox Workcentre XD125f problem
Does it keep showing that after you replaced the toner cartridge?
Aug 17, 2007 | Xerox WorkCentre XD125F All-In-One Laser...
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
