Question about Samsung SCH-u340 Cellular Phone
Saved sounds it will say the name of the song then no sound?: and then ill click save sound and ill go to the melody gallerey and it wont be there.! HELPPPP!
How do i get back the auto load folder nd everytime i save a song track nd time save but no sound wen i play it bak ??? jst started happining every song i save is like a waste ???plzz help!!!!! thnx D
your player is not compatible on file you save..or maybe you did not ininstall a cd for sound drive.. you can download soud drive online seach in yahoo or google.
Jan 31, 2013 | Akai MPC-5000 Beat Production Sampler...
My nokia screen not working
Enter the following code:
*#8999*8378#
(You'll be shown menu, then ...)
then go to:
"H/W test"
then go to:
"Audio Settings"
then go to:
"Melody Gain"
There will you see a number.
there are five (5) Melody Levels" of it.
(and currently, you are at level 1 and after
pressing the "save" button, you will move to
level 2 and so on .........................)
you have to change the values of all the levels.
and as the resultant, it will give increase the
melody sound!, your tones will more louder,
even more louder then the max. ringing volume.
the level wise numbers are: (as its my setting :-) )
Melody Level 1: 13
Melody Level 2: 17
Melody Level 3: 18
Melody Level 4: 25
Melody Level 5: 31
you even can make your own combinations of level wise
sounding numbers that can change the sound level!.
if your combination cause more louder sound level,
then mine,
then do share it with the group! ... :-)
meanwhile, try my figured-out combination!
************ CAUTION ************
if anything goes wrong,
then you can apply the master reset code,
that will NOT delete anything, ANYTHING from your
cell fone, but set each and eveything to its
default/standard setting ...
(likes, factory settings :-) )
the master reset code is:
#*7728#
Feb 14, 2012 | Nokia C601 Cell Phone
How can i set message tone in samsung champ?
Its quite simple. Just follow some steps:
Go to settings>Sound Profiles>If you have selected "Normal Profile" the open it>
Now last second option is "Message Alert Tone"> select it, then a menu will be displayed>
Now either you can select "Default Melodies" or "Sound" menu.
Default Melodies----It is for default sms tones provided by Samsung
Sounds----It will show you the menu which contains all the melodies saved by you in mobile.
now select the melody which you want.
I hope this much information is enough for your query.
PLEASE RATE MY ANSWER
Jun 20, 2011 | Computers & Internet
How do i download music on my mp3 player?
How to Put Songs on Disney Mix Max
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable
* Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu.
Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
Mar 11, 2011 | Disney Mix Max Digital Media Player
My radio stations wont save i click the cd song changer button to find a station and hold m1 or m2 or whatever to save it beeps saves but when i turn the car of it doesnt save
Sounds like your clock wire is not connected to the battery. Usually this is a yellow wire used for clock and keeping power going to the radio when the car is turned off.
Mar 30, 2010 | Albatron L17AS 17" Flat Panel LCD Monitor
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
• Melody: the phone rings using the ring melody selected in the Ring
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
simultaneously.
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
desire (range is 1-7).
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
My phone has a very low sound that i cannot even hear it when it is in my pocket.It does not even vibrate in such a way that i can detect it.
you can increase the sound level,
the sound level for tones, speaker fone, etc,
can be increase even then if it is at max (level 4)
you still can do it,
just follows the instructions!
**************** HERE WE GO **************
*#8999*8378#
then go to:
"H/W test"
then go to:
"Audio Settings"
then go to:
"Melody Gain"
Melody Level 1: 13
Melody Level 2: 17
Melody Level 3: 18
Melody Level 4: 25
Melody Level 5: 31
then mine,
IF U R SATISFIED PLS VOTE ME
Jan 21, 2010 | Samsung SGH-E370 Cellular Phone
I want the keytone to be silent - how do I set it to silent?
You have to do the following:
Sound Profile
You can customize various sound profiles for your phone by
changing the sound settings.
1. In Idle mode, press the Menu soft key and select Settings
➔ Sound Profile.
2. Highlight one of the following sound profiles:
• Normal
• Silent
• Driving
• Outdoor
3. Press the Edit soft key to access the sound settings.
4. Press the Change soft key to change the "phone" option.
• To move between the various tabs, use the Left and Right Navigation
keys.
• To highlight individual options, use the Up and Down Navigation keys.
• To change the setting for a highlighted option, press Change ( ).
There you have these options:
– Keypad Tone: allows you to choose between Beep, Xylophone, and
Mute (no tone) for keystrokes on the phone.
– Power On Type: allows you to select the way in which the selected alert
is played when the phone is powered on.
• Melody: the phone sounds the selected melody.
• Vibration: the phone vibrates.
• Vibration & Melody: the phone vibrates and also plays the
melody.
• Mute: the phone neither vibrates nor plays a ringtone. The only
indication of a message is an alert on the display.
5. Press the Save soft key when you are finished.
Normal Profile
To access the available options for this sound profile, press the
Edit soft key.
keys.
• To save your changes, press the Save soft key.
This should do it.
If you still have some problems please download following manual and go to page 69 where you find all related info.
Propel Manual
.pdf
Hope it helped.
Nov 20, 2009 | Samsung Propel A767 Cell Phone
Sound Not Saving
you first need to record your sound/voice and then save it along with the songs,. then you'll find your recorded voice in the list. use it
Jul 31, 2009 | Samsung SCH-u340 Cellular Phone
Samsung SCH-u340 Cellular Phone Logo
99 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
