Question about Nokia 5800 XpressMusic Smartphone
Nokia 5800 won't turn on
I have tried all the methods s decribed in this forum, hard resetting, putting in new battery, closing in the connectors etc, all to no avail. Took this phone into a dealer when it happened, got charged a fiver and the bloke told me it has water damage. I know for a fact it hasn't got water damage, as it hasn't been anywhere to get wet.
Are there any other options i can try?
How open code security factory setting Nokia 5800 Xmusic, Restore all original phone
HARD RESET in Nokia 5800 XpressMusic Smartphone
Please Note:
The result of this process will wipes the entire phone memory and settings fresh to how it was (or should be) when you bought it.You are advise to make a back up of your device and you need to understand that what you are doing this is at your own risk. We will not be held liable for any type of loss that may occur during the reset process.
For Hard Reset;
-Turn the Phone Off
-Press and Hold ANSWER + REJECT + CAMERA keys simultaneously.
- Turn ON the phone by pressing the Power Button
- Wait for the handshake / Nokia logo appears.
FOR SOFT RESET
For Soft Reset;- back to factory settings: This should maintain your data (contacts/messages/calendar/notes etc), just returning your Nokia X6, 5800 XpressMusic back to all previous settings
From menu:
Settings>Phone>>Phone Management>>>Factory Settings
Feb 17, 2011 | Nokia 5800 XpressMusic Smartphone
My phone - nokia 5800 In Opera mobile - system fail ,memory full, close your applications and try again . In Qin Mobile Quard i see 12 M Ram free from 120 Thanks
( for Nokia 5800XM - use the following buttons to do a hard reset, GREEN/RED/CAMERA keys pressed all at once on power up. try reset it.dant foget thanx
Feb 12, 2011 | Nokia 5800 XpressMusic Smartphone
I have a Nokia 5800 XpressMusic phone, I am having problems is the delivery of my sms's it goes directly to my outbox. Can anyone assist
Nokia 5800 XpressMusic Soft Reset
Using the dialing keypad type in *#7370# and then inter your lock code (default is 12345).
OR
Nokia 5800 XpressMusic Hard Reset
In order to perform a hard reset on your Nokia 5800XM, enter the following key combination
Ensure your handset is turned off then,
Press and hold the, Green key, Red key + Camera Key and press the On button.
The device will then resert in it’s default factory settings with all handset data removed.
Jun 02, 2010 | Nokia 5800 XpressMusic Smartphone
My phone is showing only the startup NOKIA screen, tried removing battery several times.
try to do a hard reset on your phone,
remove your sim and memory card, but please be aware that this will erase your user settings once a successful hard reset had taken place.
try doing this trick if it will work on your phone.
1. turn off your 5800 phone
2. press these keys, green key, red key and camera keys and turn on your phone without removing your fingers from the keys.
3. keep pressing until you see the nokia sharing hands logo.
regards.
Mar 06, 2010 | Nokia 5800 XpressMusic Smartphone
I am using the 5800 xpress .Setting and some other icon missing in my phone.How can i get it back?
well u can restore your cell try this way
5800 Hard Reset
WANNA HARD RESET YOUR NOKIA 5800 XM?
JUST PUT *#7370# AND THEN PUT LOCK CODE(I.E 12345) BACK UP YOUR PHONE MEMORY BEFORE DOING THIS
NEW LOCK CODE METHOD FOR NOKIA 5800XM
PRESS GREEN KEY + RED KEY + CAMERA KEY WHILE BOOTING YOUR 5800 JUST PRESS IT UNTIL YOUR DEVICE RESTARTS
Mar 02, 2010 | Nokia 5800 XpressMusic Smartphone
My nokia 5800 has started to flick between main screen and as if its tryin to open an app have turned off removed battery etc but as soon as turn on it continues
right first thing you need to do is enter *#7370#, back up your phone beforehand, this code is for hard reset, e-g force it back to factory standards, settings aswell, it solves allsorts of problems like yours.
Jan 17, 2010 | Nokia 5800 XpressMusic Smartphone
Nokia 5800 xpress music wont unlock and is flashing
after long search the forum and crafts on the phone all I even managed to repair the problem the phone to lock automatically when startup bug which he and impossible to unlock with unlocking the switch that unlocks the screen and keys, so here is what I do to reset it:
1-your smart phone with another and you must lock your chip with the PIN for your nokia you to save the PIN at startup
2-when the phone asks you to put the PIN code emergency call that is "112" to issue an appeal, you will find the digital bottom right of the screen when you click over the frame screen appears but impossible to put the code * # 7370 # for hard reset not panic please leave the call and put the PIN code 0000 or your own code if you change;
3-when you put the code the phone starts normally but the home screen something changes in the key to the vanishing locking and screen and keys shall be free;
4-so you can do the hard reset and the phone takes its original form
dw: I tested yesterday on my nokia 5530xm and is the only solution,
Dec 28, 2009 | Nokia 5800 XpressMusic Smartphone
Hi forgot my nokia 5800 lock code
i forgot my nokia 5800 lock code, any solutions?
Jul 02, 2009 | Nokia 5800 XpressMusic Smartphone
My Nokia 5800 will not turn on. It only vibrates.
  1. With your 5800 turned off,
  2. Press and hold [Green] + [Red] + [Camera] Keys
  3. Turn phone ON, and keep pressing it until you see the Nokia Shaking Hands Logo.
The phone will be factory reset. If asked, default code is 12345. My phone did not ask- only the normal SIM PIN.
Jun 10, 2009 | Nokia 5800 XpressMusic Smartphone
Nokia 5800 XpressMusic Smartphone Logo
408 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
