Question about Samsung WF330ANB Washer
Samsung wf330 front loader washer, the small black "drain" tube in the lower right front fell off into my hand when I was opening it to drain it. How do I reattach it?
It's the small black tube that you are supposed to check about once a month to drain any excess water that the pump didn't remove. Usually it's not much water. This time when I was turning the white plug that goes into the black hose, the black hose pulled all the way out. I took the inside plastic piece off but can't see or feel any place for this small black tube to fit, or how to reattach it.
  • yadayada
    yadayada Dec 07, 2016
    Hi Suzanne Wedman, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Master:
  • 252 Answers
I hate to say it, but unless you can pull it all the way out and flip it up on it's face by yourself, you'll have to get a repair man. I assume you did this procedure: http://www.samsung.com/ae/support/skp/faq/1061987 and the black tube came off UP inside/behind the plastic wall. It would probably be a 2 person task to lift the washer carefully and try to get up in in there. There will probably be 2 screws holding in the plastic back plate, or it may just pop out with a screw driver from the side (with plastic pins behind, be careful) to allow you better access to the point where the hose attaches to the washer. Here's a guy who has taken apart the whole washer, hopefully you don't have to do this, but if you do, here's the procedure.
Posted on Dec 07, 2016
Cleaning filter on Samsung front loader
Hi! First I'm not a Samsung tech. But I am an equipment tech (retired) but more important I (sorry) WE, have a Samsung front loader too! I was wondering the same question. Where is the filter? We have 5 dogs and 2 cats so I'm pulling a lot of hair from the lower part of the door rubber (there is a small drain hole where stuff collects) But your question prompted me to really look for this filter. The following is from the manual:
* user manual WF45K6500A / WF45K6200A Page 53 (English)
1. Turn off washer, and then unplug power cord.
2. Drain the remaining water inside the drum. See the "Emergency drain" section on page 49
3. Gently press the top area of the filter cover to open (it's located at the lower left front of washer. ukeboy57) C
4. Turn the pump filter knob (A) to the left and drain off remaining water.
5.Clean the pump filter using a soft brush. Make sure the drain pump propeller inside the filter is unclogged.
6. Reinsert the pump filter, and then turn the filter knob to the right.
7. Close the filter cover.
Note; If the pump filter is clogged, the "5C" information code appears on the washer display screen.
* Final; I haven't done this yet though we had this machine for a month now and I suspect it's filthy. Warning though, the emergency draining looks messy so have the pan and towels ready. (and I just got finished tiling the laundry room floor too!)
Aloha, ukeboy57
Jan 04, 2018 | Miscellaneous
I need to force my lg tromm to drain
My LG Tromm washer has a small door on the bottom left hand side on the front of the washer. Open the door and you will find the drain filter and a stoppered, small rubber tube. Position something to capture the washer water under the small rubber tube and pull the plug.. This will drain all the water from the washer.
Aug 01, 2014 | LG WM1814CW Front Load Washer
Where is the pump filter on an lg washer?
The PRIMARY filter for discharged water in most front loaders is located under the opening of the washer behind a small 'door'. There is usually a small tube which you will need to pull the plug from and drain about 2 cups of water into a bucket BEFORE you remove the filter to clean it.
After you unscrew the filter which is mounted from front-to-back and clean it out, replace both filter piece and plug and replace the small drain tube.
Close the access door and operate your machine.
* Clean this filter every month or especially after washing heavy lint-producing materials.
Jul 21, 2014 | LG WM-2277HW Front Load Washer
I have a Samsung Front loader . I'm getting a nd error . The door is locked and the so I cannot drain the wash to get the clothes out . What do I do ?
nd = No Drain the pump is not working.open the door on the bottom right on the front of the machine. you will find a small black hose with a plastic plug in the end of it. it will pull out about 6in depending on you situation you take a length of garden hose and drain it outside or you can use a pan, obviously the garden hose will have to drain to a lower point than the hose coming out of the washer. You will drain about 3Gal of water,once the water is below the water sensor level you will be able to power it on and the door will unlock. The other twist lock to the left of the small drain hose is the filter for trapping items that may clog the pump.Ultimatley the front off the washer will have to be removed to clean or replace the pump. I have actually run our washer by hooking up a primer bulb and hose for an outboard motor.and pumped the water into a laundry tube between cycles. You can find that hose an bulb in the sporting goods dept at Walmart
Jun 12, 2010 | Samsung WF218ANW 4.0 cu. ft. High...
My Whirlpool Duet washer was out of balance and almost fell over during the spin cycle. The washer was shaking and the front door came open during the spin cycle. Now the front door will not latch and stay...
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The washer leaves water remaining in drum after the entire wash cycle, it becomes stale and makes my clothes that I was smell. My father's front loader, GE, does not leave any water in the drum
Hello
Check the drain tube,it needs to be 30 inches above the floor.
Also if the drain tube from the washer is too far into the drain the washer will not drain completly.The drain tube should be 1 inch into the wall drain.
Also check for kinks or obstructions in the washer drain tube.
May 13, 2010 | Samsung WF203ANW Front Load Washer
Will not drain
Is this a TOP LOADER? Or, a FRONT LOADER?
If this is the TOP LOADER, check your lid switch. This is the most common cause of the problem you are experiencing. Symptoms include, filling and stopping on the intial fill cycle, wash tub will not drain and/or the washer will still agitate in some cases, but will stop right after the wash cycle and fail to advance to rinse or spin cycles.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
If this is a FRONT LOADER, check your drain pump reservoir. The access screws are on the bottom front edge of the lower toe panel directly below the door. You may need to prop up the two front feet of the washer to access them (a 2x4 works well for this). The following link explains:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices differ between sites so shop and compare.
If you have questions, or need additional assistance, please post back with your MODEL NUMBER (located on a nameplate along the wash tub rim under the washer lid - top loader, along the door opening - front loader) and let me know. These are very simple repairs that you can perform yourself. I hope this helps you.
Mar 02, 2010 | Washing Machines
My Whirlpool Washer lets the water in but it will not engage in the mechanical cycle, I've tried all 4 cylces but start the wash cycle. I'm in Costa Rica & it is difficult to find a proper service man,...
WATER NOT PUMPED OUT .. LOWER RIGHT HAND SIDE YOU SHOULD HAVE FILTER UNIT ...UNDO FRONT COVER.. PUT BOWL IN FRONT AS WATER WILL COME OUT... WHEN EMPTY REMOVE FILTER..AND CLEAN IF BLOCKED UP.. IF OK HAVE YOUR PUMP TESTED WITH A VOLT METER TO SEE IF FIELDS ARE IN CURCUIT.... HOPE THIS HELPS.
Jan 04, 2010 | Washing Machines
Front loader door not opening
Mar 31, 2009 | Washing Machines
My front load Tromm LG washer flashes OE message, won't drain or finish wash. Door does open
oe is an error code for pump problem disconnect power cord open small door on lower front of cabinet pull little tube out and plug from tube and drain water in to bucket after water is drained unscrew cap of pump to clear out any obstructions reinstall the cap and plug and give a test run
Dec 20, 2008 | LG WM-2277HW Front Load Washer
Samsung WF330ANB Washer Logo
37 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
