Question about Vacuums
Bypass on/off switch
How do I bypass the switch 2 speed on a goblin 1000 wet/dry cleaner
  • 11,896 Answers
Cut the wires, strip them about 1/4 inch on ends and twist them together if you are just going to plug in and turn on
Posted on Jul 20, 2009
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Switch bad on shop vac how do i bypass it
Remove the switch (with unit unplugged) remove wires from switch and solider the two together
Nov 08, 2013 | Craftsman 17765 Canister Wet/Dry Vacuum
Can not get the Smartmix rotary switch to line up
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fsd5
May 24, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
WONT TURN ON
is there a manual to show how to remove the switch? How do I bypass it?
What do I have to do to be sure the switch issn't the problem?
Jan 21, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Wet dry vacuums and shampooing rugs
they do ok, but a dedicated wet/steam cleaner does better
Sep 02, 2009 | Dirt Devil CE6000 Featherlite Wet/Dry...
I have a Kerrick lava flow wet/dry vacuum cleaner
Dear Sir, I also have a Kerrick Lava Press cleaner that came not with very good instructions and I have never used it. Where could I get instructions?
Christa Unnasch
2 Torrens Lane
Mawson Lakes
S.A. 5095
Australia
Pinscher@bigpond.com.au
Aug 19, 2009 | Vacuums
Possable broken/Disconected wire
hope you have checked the obvious first ..the plug are all the conections tight including the fuse? if so check the vac's switch for loose conections .lets face it the mains feeds the switch the switch feeds the motor unless you have a speed switch. sounds like a fault that could be cured with a bit of investigation good luck farr64
Apr 30, 2009 | Rainbow E series Canister Wet/Dry Vacuum
I can't find the cleaner?
The Lysol/Hoover Floormate is no longer available. Substitute Hoover floor to floor cleaner.
Apr 01, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
DeWalt DC500 wet/dry vacuum
I had the same problem and traced it down to the on/off switch. I sprayed some electical contact cleaner down inside the switch and now it works normal. Hope this helps.
Oct 23, 2008 | Dewalt DC500 Canister Wet/Dry Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
