Question about Dryers
I need the Model B2423-30-SP light bulb. However I would like to have brighter light. It's used in an enclosed ceiling fixture. Is there a brighter bulb I can use?
  • Loretha Phillips
    Loretha Phillips Dec 06, 2016
    The fixture takes two of these bulbs.
    Top Expert:
  • Dryers Master
  • 41,867 Answers
Replacement with higher wattage lamps may cause the enclosed fixture to overheat.
Posted on Dec 07, 2016
What type of light bulb do I need for a minkaAire ceiling fan. It is about 7 years old
It all depends on which light kit was installed on your fan. As you described the fixture as requiring a "light bulb" meaning a singular bulb, Minka Aire usually uses several different types.
The most common is either a 40-watt or 60-watt Candelabra Bulbs.
(The designation "Candelabra" refers to its screw base. You can buy these in clear or frosted, torpedo or globe with a straight tip or curved. Etc.
Here's an example of a torpedo globe:
Sunlite 60 Watt Torpedo Tip Chandelier Candelabra Base Frost 48 Pack
And here's an example of a Candelabra globe:
Sunlite 60 Watt G16 5 Globe Candelabra Base Clear 48 Pack
Some of their fixtures use a 50-watt Mini-Can Xenon Bulb.
Satco S1914 50W MINI CAN FROSTED 120V
And other use a 3w CFL Medium Base Bulb.
3W CFL Deco 2700K Medium Base
When installing a CFL, Halogen or Xenon bulb, I recommend cleaning the glass with an alcohol wipe to remove any oil from fingerprints. Due to the very high temperatures these lamps operate at, the oil from your fingers will cause a hot-spot on the glass and can shorten the life of the bulb dramatically.
If none of the references I offered match the bulb in your actual fixture, you might be able to more closely match the fixture from one on the following page. The recommended bulb for each fixture is listed in the description of the fixture.
https://www.ceilingfan.com/Minka-Aire-Fan-Lights-s/2082.htm
And as always, NEVER over-lamp a fixture with a bulb rated at a higher wattage than what's shown on the base of the fixture. That is, never use a 60-watt bulb in a fixture rated at 40-watts. The additional heat of the bulb may harden the insulation of the wiring in the fixture creating, causing the insulation to fail and create a fire hazard. Also for fixtures located tight to the ceiling, higher temperatures can dry out the gypsum ceiling material, causing it to crack and deteriorate.
Feb 09, 2018 | Dryers
Tip
Why Light Bulbs Burn Out So Quickly
The bulb package should have an average life expectancy printed on it. The typical light bulb is good for roughly 900 hours. At 10 hours a day that's three months. At 24 hours a day it's a little more than a month. If you have 25 bulbs in your house burning an average of three hours each day, a bulb will burn out every twelve days, on average. If you compute the average life of your bulbs and discover it's clearly less than the manufacturer's rated life, then you may have: 1-You may have over-voltage in your house. Occasionally this causes more serious problems. You can get a cheap multimeter at Radio Shack. If the voltage is 125V or higher, talk to the power company about it. 7 or 8 extra volts on a 120V line will cut the bulb life expectancy in half. If it's a slight over-voltage, you can buy special 125V or 130V bulbs, though sometimes they're hard to find.
2-Too high a wattage bulb in too small an enclosed fixture (such as a globe), the heat can't get out--the bulb burns too hot, leading to short bulb life.
3-Recessed lighting fixtures often get covered by attic insulation. This blocks the intended ventilation method--heat can build up around the bulb, causing short bulb life.
4-A vibration problem. Such as, bulbs under a heavily used stairway, on or near an out of balance bathroom or ceiling fan, or near a door that gets slammed, or kids upstairs jumping, etc. You can buy special shock resistant, also called "rough service" bulbs, for this situation, or try one of the new compact screw-in fluorescent bulbs.
Flickering. Intermittent electrical contact can cause flickering. It's like turning the light on-and-off constantly, and will reduce bulb life. It can be caused by a bad light socket, or a poor electrical connection somewhere in the wires leading to the light (most likely right at the fixture). Flickering can cause the bad connection to get hot and possibly start a fire. If you don't locate the cause of the flickering and it affects all or many lights, you could have a bad neutral connection -- a dangerous situation. Another indication of a neutral problem; as larger appliances (washing machines/dish washers) cycle, lights will get quite noticeably brighter or dimmer (minor changes in intensity are normal). If you suspect this problem have either the electric company or an electrician check it out.
on Dec 18, 2009 | Kitchen Appliances - Others
I am trying to install a ceiling fan and from the ceiling I have a copper white and black wire. Now from the fan itself there is a black blue and white wire. Not sure where to connect the copper wire.
Good question, proper wiring is a crucial virtue that needs to be one hundred percent accurate.
Three wires showing from the ceiling lamp fixture harness, positive, negative, and ground.
The negative wire is the white wire,
The Hot wire (positive) is the wire of brighter color than known negative,
220V AC (alternating current) home wiring to(" duplex outlet switch, GFI switch, single/dual pole light switch, lamp fixtures,") the Hot wire or lead, is normally Black, the lighter color, or White is neutral or neggative,
Neutral wire (completes circuit) allows current flow to continue through to other parts of house, Alternating current.
The Ground wire is usually wrapped in green color, or unmarked copper.
The copper wire from the ceiling will need to be grounded to the metal bracket on the new light fixture, a gold or silver screw, sometimes tagged with green, is the proper grounding location, Any place on Metal not attached to ceiling bracket, Ground should be attached to metal on fan,
White wire from Fan is neutral, Negative.
Black wire from Fan is Hot Wire, Positive,
If Blue wire from Fan is Not Manufacture spliced, Meaning no Copper is exposed, Wire is not used, Blue wire is NOT ground,
If Fan has a light, Voltage from Hot Black wire will supply both light and fan functions,
Safety First.
flip off breaker switch to the room fan is being installed.
Doubble Check
Black^Black wire connection is secure.
White^White neutral wire connection is secure.
Ground is fastened securely to metal or wrapped under a screw.
Using splice caps is recomended, The plastic shell encloses the wire connection ensuring No stray copper is exposed, limits possibility of cross wiring.
Google the brand of fan being installed, and Check wire color code, and wiring diagram, Info good to have, and checking twice will only guarantee Lamp Fixture Install Well Done.
(Blue wire may be there for installing multiple ceiling fixtures in a loop circuit, so all controlled by same light switch.)
Enjoy Your New Fan,
Jos
Thoughts&Comments, encouraged jtobias1020@gmail.com
Mar 26, 2017 | Dryers
What light bulb does the morse zig zag 4300 sewing machine take?
The Morse 4300 typically uses a standard 15 watt screw in style sewing bulb. Just like the one shown in the enclosed link. However, due to the age of this machine, it is possible that the light fixture has been changed at some point. If you have a burned out bulb, and it has a screw style base, this one will be right. There is also a push in style used on many aftermarket fixtures. Both styles of bulb are fairly universal though. So it will be one or the other.
Light Bulb 15 Watt Screw In 7SCW
Nov 02, 2015 | Sewing Machines
We have Lithonia 2 bulb fixtures in a recessed ceiling. We currently have 2 (25) watt bulbs in them. What wattage can I upgrade to ??
The ballast inside the fixture is rated to operate 2 25w bulbs. You can't put higher wattage bulbs in this fixture, unless you change the ballast. Sorry.
Sep 22, 2014 | Lithonia Lighting Fluorescent Flush Mount...
Hello. I need help with my fan, please. I have hampton bay ac-527 nn sku# 360-424 . Trying To remove light To replace burned out bulb light but having trouble removing. HELP ME PLEASE. Mike
You got me wondering about a fan I have with an enclosed bowl-like light fixture (I don't know how closely this resembles your model, but bulb access is not immediately obvious on it either). I looked on top of the light section and found a #2 Phillips screw on the top plate of the light fixture near the rim. It seems likely that loosening or removing it will let the bowl come out at the bottom of the fixture so you can get at the bulb. You will probably need a short-handled screwdriver to get in under the motor housing. There are also three #2 Phillips screws going into the side of the cylindrical section below the fan blades at the bottom; this section has the fan and light chain-operated switches attached to it. Those probably attach the entire light fixture to the rest of the fan.
Jun 25, 2014 | Dryers
Replace GE 50W Halogen bulb in ceiling fixture
if fixture is as shown, remove the nut in the middle of the fixture, remove the lamp, and replace it, note donot touch the lamp with your fingers, this causes lamp to fail, use a cloth to install then replace in reverse as you took it apart
Sep 27, 2011 | Universal Lighting and Decor White 11"...
LED light too dim, is there a brigher LED kit?
You need these parts:
- Low profile GU24 socket (Maxlite MLGSIIB)
- GU24 CFL bulb (Progress Lighting MLS13GUSWW6)
- Threaded pipe fitting, nut, washer
- 2 wire nuts
Here is how to fix it for a few bucks. You need a low-profile GU24 socket (Maxlite MLGSIIB), which is readily available in large mail order channels. You also need a GU24 compact fluorescent bulb (Progress Lighting MLS13GUSWW6) that is available through Home Depot mail order or other internet retailers. To my knowledge, these are the only parts that fit into the low-profile glass.
You'll also need a threaded pipe fitting and a proper size nut for attaching the GU24 base to the holder, both readily available at the ceiling fan section in HD. You'll also need a washer underneath the nut to hold the socket in place. Put your MacGyver skills to work.
To change the parts, uninstall the light fixture by unscrewing the glass, then removing three screws that hold the LED plate in place. Disconnect the LED wire connection and a larger white connection behind it. Then remove three more screws that holds the rest of the light fixture up and remove it from the fan.
Once on the desk, remove the back plate wire cover (3 screws) so you have access to the wires. Unscrew and remove the rectangular box (120v-12v converter), you won't be needing it any longer. Cut the black and white wires close to the module - you'll be attaching the GU24 socket wires to those wires.
Remove the LED circuit board from the plate by pinching the plastic standoffs and then pulling them out. Install the GU socket to the larger hole at the center of the plate using a pipe fitting, washer and a nut. Notice that it fits perfectly - it was probably originally designed to use this socket! You may need a washer that is the appropriate size to hold the socket in place. I also used a piece of bent paperclip underneath the washer to hold everything tight.
Remove the white thermal sleeve from the LED module wiring and insert it over the GU24 socket wires just like it was with the LED wire. This is to prevent heat damage to the wires when they touch the metal edges. Using smaller wire nuts, connect the black and white wires to the wires you cut off earlier when removing the 12v module.
Put everything back together, install the light bulb, and enjoy a much brighter light from this beautiful ceiling fan.
Jul 11, 2009 | Hampton Bay Dryers
Hampton Bay Ceiling Fan Plastic Burning Smell
I think you have already figured out what the problem most likely is; 60 watt bulbs. Down-size the wattage or install 'energy saver' bulbs if they will fit the application. Instead of counting on these units for extra lighting, perhaps think about Track lighting to fill in those ares that need more but subtle light.
Good luck. :)
Apr 09, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Ceilng Fan light fixture-metal clasps have broken off
For Hampton Bay ceiling fan replacement parts!!!
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
Nov 25, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Dryers Logo
288 people viewed this question
Top Dryers Experts
