Question about Solar Electrical Supplies
I have one of your Thunderbolt Solar fence chargers. I have it hooked up just like you would if you was using a electric fence charger but I cannot get it to work.
  • 161 Answers
SOURCE: trickle charger for storing electric cushman golf cart
contact manufacturer, and seek there advice
Posted on Nov 27, 2008
aparsons89
  • 40 Answers
SOURCE: Does the S600 and a Missle FS schwinn scooters use same charger?
Hi you can use the charger if the Specifications match up. Output volts, Amps, Charger size, The most important is it 24 volt or 36 volt charger. Check your scooter to see what volt it runs at. Must be equal to your scooter!
Posted on May 10, 2009
  • 76 Answers
SOURCE: I just bought a Parmak 6 volt solar electric fence
I WOULD THINK SO BUT THE BLACK MAT BE THE POS. AND YOU MAY BURN UP THE CHARGER IF HOOKED UP WRONG BUT OTHER THEN THAT YOU HAVE GOT I THINK
Posted on Jun 24, 2009
protek480
  • 1714 Answers
SOURCE: we have 2.2 miles of fence,the charger is good for
You have got to make sure there are no weeds or brush at all touching the hot wire. Nothing can touch it or it pulls the voltage level way down. Do a full inspection of line.
Posted on Oct 02, 2009
  • 268 Answers
SOURCE: Installed the new solar charger
I have see this happen before and its usually do to most moisture/rain getting in. ie use multi meter to varify solar charger putting out current/voltage. Odds are its not anymore. Rechargable batteries are notorius for not lasting but not in 2 months.
Posted on Oct 07, 2010
How long does it take to charge battery in solar fence charger?
    1. A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.
      About Fence Chargers - Zareba Systems
      www.zarebasystems.com/learning-center/all-about/fence-chargers
    Feedback
  1. About Fence Chargers - Zareba Systems
    A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.‎What can I do to prevent ... - ‎What factors should I consider ...
    [PDF]Fence Controller Installation - Zareba Systems
Jan 01, 2016 | Cars & Trucks
I just received my Thunderbolt Magnum Charger that I had ordered from Harbor Freight Tools. I plugged it into my 2012 Nissan Rogue to try it out and it turned on my car's radio. I assumed this was not a...
This charger is a maintenance charger and will not have enough power to charge a dead battery. It is used to trickle charge a battery to keep it charged and to off set any parasitic drain.
Feb 17, 2014 | harbor freight tools THUNDERBOLT MAGNUM...
C lightening hit my mark 7 fence charger is it worth repairing
If lightning hit the unit itself then it more then likely destroyed any electrical components inside the unit. I would say get a new one and dont even bother repairing it.
Apr 16, 2011 | Parmak Solar Fence Charger
Why do my horses keep going through the fence in the winter? We have the 12v solar unit! It seems as though there is a delay with the shock!
Trim your horses whiskers (on the muzzle) and they won't be able to tell if the wire is hot or not. Horses test electric fencing with whiskers. I would suspect because days are shorter and more cloud cover your charger is not producing enough power.
Dec 29, 2010 | Parmak Solar Fence Charger
Installed the new solar charger in July. ZThe hot wires and ground wires are properly connected, snd the fence is properly grounded. It worked great until approximately two week s ago (end of Sept). The...
Oct 07, 2010 | Parmak Solar Fence Charger
Installing instructions
You can download and print your PARMAK manual here:
http://www.agfence.com/fence/Assets/documentation/parmak/InstallationManual.pdf
Dec 19, 2009 | Parmak Solar Fence Charger
No shock from charger
did you make sure the fence isn't grounded or an insulator hasn't melted
Apr 12, 2009 | Parmak Solar Fence Charger
Electrical Supplies Logo
94 people viewed this question
Top Solar Electrical Supplies Experts
Steve
Lawrence Oravetz
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
