Question about Health & Beauty
I have a Tan america tanning bed 2800 where can I find a trouble shooting guide or wiring diagram for this model?
Out of 14 bulbs on bottom 4 of them are out.ones in the center are out. bulbs and starters are good no burnt lamp connectors
SOURCE: Are there any medications that you should not take if you are using a tanning bed? I want to get a tan but I take a lot of medications and am worried about having a bad reaction.
If you are taking photosensitizing medications you should be carefully about tanning both outdoors and indoors. There is quite a long list, so you should check with your doctor before you start any tanning sessions.
Posted on Feb 18, 2013
  • 60 Answers
SOURCE: Is tanning on a tanning bed just like tanning outside in the sun?
No - it's very different as outside, various objects block the direct rays of the sun and allow you to be outside in the sun for a lot longer. Tanning beds are very instense. You should not be on the bed for longer than 10-12 minutes for your first sessions and be very careful about adding extra time.
  • 43 Answers
SOURCE: Do I need to worry about how often salons change the bulbs in their tanning beds?
Yes - even though in theory tanning bulbs can last up to 1,000 hours, if they are not changed very regularly, they can seriously affect the quality of your tan. Bulbs should be replaced after 500 - 600 hours use.
  • 47607 Answers
SOURCE: Tan america 3200 vip bed. Could you show me a diagram for wiring
consider this ---tan beds are the major source of melanoma cancers after sun burn
melanoma cancers are the highest cause of deaths as they are not found until too late
consider this--- is fixing this machine worth killing yourself for a tan
if you don't care then go google to the manufacturer and download the diagram if it is available.
Posted on Jun 25, 2015
gosamg23psal
SOURCE: need to get to balist on home does bottom of bed open home tanning bed 1985 sunbrella aruba 10 sontegra 12165
Have you checked to see if the very end cap of the bed qill come off accessing you to the underside of the bulbs? I would look at that and see.
Posted on Mar 07, 2016
Testimonial: "the sides come off yes i have got to bulbs and starters"
Color code radio wires for a 2013 chevy express
Audio Item Wire Color Polarity Wire Location Radio 12V red/white + radio, black 14 pin plug, pin 1 Radio Ground black/white - radio, black 14 pin plug, pin 8 Radio Ignition (low speed GMLAN) Radio Illumination yellow (dimmer) + radio, black 14 pin plug, pin 7 Left Front Speaker (+/-) dk. blue - lt. blue +,- radio, black 14 pin plug, pins 2 - 9 Right Front Speaker (+/-) orange - dk. green +,- radio, black 14 pin plug, pins 3 - 10 Left Rear Speaker (+/-) tan - white +,- radio, purple 16 pin plug, pins 5 - 13 Right Rear Speaker (+/-) tan - orange +,- radio, purple 16 pin plug, pins 6 - 14 Satellite Radio 12 Volts red/white + Digital Radio under driv dash, 16 pin plug, pin 16 Satellite Radio Ground black/white - Digital Radio under driv dash, 16 pin plug, pin 9 Satellite Radio Ignition (low speed GMLAN) Satellite Radio Antenna (coaxial cable) Satellite Audio Left (+/-) brown/white - tan/white +,- Digital Radio, 16 pin plug, pins 2 and 1 Satellite Audio Right (+/-) dk. green/white - gray +,- Digital Radio, 16 pin plug, pins 3 and 4 2016 Chevrolet Express Van Wiring
Feb 16, 2017 | Chevrolet Express Cars & Trucks
Jun 25, 2015 | Cars & Trucks
How to replace bulbs in tanning bed
Without the specifics of your bed, I can give you some general info.
  • The first thing you need to do is remove the acrylic. Depending what type of bed you have, this may require a screw driver to remove the metal retaining strip on the outside edge of the acrylic.
  • Set the acrylic aside, & remove the burnt out bulb(s).
  • Depending on the type of bulbs you are using, you may need to place adapters on each end (these can be removed & reused from your old burnt out bulbs).
  • Regardless of bed type, most have one thing in common when it comes to bulb terminals. One end of the bed will have a stationary terminal, & one end will have a springy one.
  • Place one bulb end in the spring side first, press in, & guide the other end into the stationary side.
  • Turn bed on for a test to make sure everything is working properly.
  • Replace acrylic (and retaining strip if necessary), and you're ready to tan :)
Jan 06, 2015 | Health & Beauty
Feb 18, 2013 | Health & Beauty
Wire diagram to change a royal sun tan bed model # 46/6 vhr*turbo 1100 from 1 phase to 3 phase
send me your email address and I will give you what I have. We have a 2004 model 46/6 turbo. Wiring diagram is in the manual. I have this.
Jul 26, 2012 | Cars & Trucks
I bought a replacement Dayton electric condenser fan motor. The original GE had 3 wires. L1 L2 & the fan capacitor wire. The Dayton replacement model 4MB21 has 4 wires, L1 L2 and 2 capacitor wires tan...
The tan/white wire can be insulated/capped and not used. Use and ohmmeter to take a resistance reading between the tan/white wire and L1 & L2. There will be no resistance between the tan/white wire and one of the others. This will be the common wire. Connect it to one side of the contactor. Connect the tan wire to the fan terminal on the contactor and the other wire to the common terminal on the capacitor (that is if you have a 3 terminal capacitor, if you have a 2 terminal capacitor connect tan to one side and the other wire to the other). Then connect the other side of the contactor to the common terminal on the capacitor (on a 2 terminal capacitor connect the contactor to the side that doesn't have the tan wire on it).
Aug 16, 2010 | GE Heating & Cooling
2002 Astro van. Will not start. Getting fuel, distributor changed. Had a little accident while removing the thermostat housing. A ground snapped. Two wires. Black/white and Tan/white. I know the...
its a temperature sensor thats connected to a pop off valve its usually in the main wiring harness 16 to 14 guage wire should be sufficient for the repair and make sure u have splice connectors black tape corrodes quickly and could lead to other costly repairs the starting problem sounds like a crank position sensor located on the bottom of the motor
Jul 14, 2009 | 2002 Chevrolet Astro
Health & Beauty Logo
26 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
