  • 4,134 Answers
There is no capability to use a fire stick on a laptop. Even those with HDMI ports won' support it since laptop HDMI ports are output only.
Anything you can access with the fire stick you can already access online, so you really don't need the stick. Here is a forum discussion thread on the issue. Hope it helps!
Posted on Dec 06, 2016
Can i use a firestick with my sony wega kdf-e42a10
Fire TV Stick connections....
1 Connect USB cable into fireTV stick, and plug in power adapter. ...
2 Amazon fireTV stick and power adapter. ...
Connect fireTV stick to HDMI port via HDMI extender.
3 Amazon fireTV stick connected via HDMI EXTENDER CABLE TO Monitor HDMI port. ...
4 Turn on TV and select HDMI port
Feb 04, 2018 | Sony Televison & Video
Setting up fireTV stick. It's plugged in to TV and power.ts Tried all inputs on TV. None worked. What am I doing wrong???
not sure if this link will help you out.
1. The easy way (5 mins)
  1. Plug your Amazon Fire TV Stick into your TV and plug the USB power cable into a spare USB port or use the power adapter.
  2. Go to Settings. ...
  3. Go back to the homescreen and install an app called Downloader - this will be listed under the Popular Fire TV apps section.
More items...
How to install Kodi on the Amazon Fire TV Stick: 3 BEST ways to ...
how to set fireTV stick Google Search
Oct 28, 2017 | Televison & Video
Connecting fire stick to tv. i am a prime member with amazon
Setting up Amazon Fire TV Stick hardware
  1. Plug the micro-USB power cable into your Fire TV Stick and the other end into the plug adapter and into the wall.
  2. Plug your Fire TV Stick into an HDMI port on your TV (a cable is included to extend the HDMI reach if you've got a particularly tricky TV).
  3. Next, turn on your TV and switch the input to the right HDMI port
  4. You won't be able to interact with Fire TV Stick until you pair a remote. Thankfully, by just inserting the batteries into the included remote, it should pair automatically. If this fails, you can download and use the Amazon Fire TV remote app on your phone.
  5. Now it's time to set up your wireless network. Fire TV Stick should automatically detect your Wi-Fi. Select your network and enter any passwords.
  6. Your Fire TV Stick will then check for updates and download anything it doesn't have before letting you continue. Depending on how new your Stick is and the strength of your connection, this could take some time.
  7. If you bought your Fire TV Stick from Amazon, it will have arrived already logged in and set up with your account, which is handy. If not, don't worry, it's very easy to set up a new account on Fire TV, requiring nothing more than your Amazon login details.
  8. Once done, you'll be treated to an unskippable introduction to your Fire TV Stick, taking you through the basics of what the system can do and how to make the most of its features.
  9. From here, you can set up parental control settings before you start using your Fire TV Stick as intended.
Now you've set your Fire TV Stick up, here's how to install Kodi on it.
How to set up your Amazon Fire TV Stick
Dec 23, 2016 | Televison & Video
Can i install a amazon fire tv stick the u s b will not plug in Customer Reviews: Amazon Fire TV Stick, Inc.It doesn't even play all the games that can run on the Fire TV box. Also note ... Q: CanI use my TV's USB port to power the Fire TV Stick? ... A USB port on your TV or other equipment probably will not work. ..... You can plug the Fire Stick's USB cable into theUSB port on your TV and it should work (depending on your TV ). Customer Discussions: Fire stick and Samsung TV issues, Inc.Getting a brand new replacement from Amazon did not help, seems to be some other HW or SW issue. Anyone else run into similar issues? ... I also have a Samsung TV and the Fire Stick is not recognized through HDMI or USB connections. .... Can youplug the HDMI extender cable into your TV and will the Fire TV stick fix
Dec 25, 2015 | Sanyo DP42849 42 in. HDTV
How do I watch Netflix on a non-smart Vizio TV?
Here are several answers--but keep in mind, they all involve attaching a device of some sort--whether it's a computer, a laptop, a tablet, a phone, or a device like Google's Chromecast, Amazon's Fire Stick or FireTV, or other devices similar to those I just mentioned from Google and Amazon.
You will usually need an HDMI cable to attach your device to the TV (whether it needs an HDMI cable or not depends on whether the device plugs directly into your TV's port or whether it needs a separate cable--of which there are standard HDMI, mini HDMI, and micro HDMI).
The simplest, easiest, and least expensive types of equipment to enable your non-"Smart TV" to view Netflix are the "key-fob" type devices like the Chromecast and Amazon Fire Stick (there are others, but these are the most common, most popular, and well-supported devices.)
You would simply plug the device into your TV's HDMI port, attach the power cable (these devices may be able to draw power from your TV's HDMI port, but often require a separate power adapter to be plugged into them) log onto your Google Play account or Amazon account, download and install Netflix, and log onto Netflix. Usually (but not always) the Chromecast and Fire Stick have Netflix installed, but you may need to update or download and install/reinstall the Netflix app.
Oct 04, 2014 | Vizio Televison & Video
Dell Latitude E6410 does not connect to wireless printer
connect it by cable to your pc first to install it then remove the cable
Feb 11, 2012 | Dell Latitude E6410 Laptop
I have a del latitude E6410 laptop and would like to know how to connect it to a pansonic 42 flatscreen hdtv to use it as a moniter
Dell Latitude E6410 does not offer HDMI or DV. Only VGA Port is available. Therefore in order to connect the laptop with the TV, you can use VGA cable.
But if the VGA input is not available on the TV, you need to get VGA-to-DVI or VGA-to-HDMI Adapter, depending upon the type of port available on the TV.
Hope it helps! Good Luck! Thanks for using Fixya!
Aug 18, 2011 | Panasonic Computers & Internet
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
