Question about Olympus FE-110 Digital Camera
I have a Olympus FE-110/X-705 camera, when the menu button is pressed the menu doesn't open
4 Suggested Answers
  • 919 Answers
SOURCE: We have an Olympus FE-230. When the camera is
It's possible this is a repair issue with the LCD screen of the camera especially if you are able to review previous images but cannot take any new images. You may want to call Customer Service to discuss repair options. Their telephone number is 800-622-6372 option 2 and then option 3.
Posted on Mar 09, 2009
amor1964
SOURCE: Olympus FE-310 camera doesn;t hold
you are damn right it gives my pocket cash diarhea on battery buying
Posted on Jan 03, 2010
  • 3 Answers
SOURCE: i can't find the camera menu in my digital camera even in menu button option..its olympus fe-270.
Do you have kid?? ask them to look at it
Posted on Dec 28, 2011
Need correct day and time on Olympus FE 170 digital camera
How do I set the date and time on the FE-170?
To access the clock controls, turn the mode dial to any shooting mode except [GUIDE] and then press the [MENU] button. Next, press the Right arrow on the arrow pad to select the [Setup] icon. Using the Up or Down arrow, navigate to the menu item depicting a clock. Press the [OK] button to access the clock settings feature.
Set the year, month, day, hour, minutes and date format using the following procedure: Use the Up and Down arrows to select values, and press the Right arrow to advance to the next item. (The FE-170 uses a 24-hour clock.) When all information has been entered, press the [OK] button to set the values. Press [MENU] twice to exit the menu.
To set the time precisely, with the cursor on either "minutes" or "date format," press the [OK] button as the time signal strikes 0 seconds.
The date and time settings will be returned to the factory defaults if the camera is left without batteries for approximately three days. Custom settings may be canceled more quickly if the batteries were only loaded into the camera for a short time before being removed. Before taking important shots, check that the date and time are correct.
Oct 22, 2012 | Olympus Fe-170 6.0 Mp 3x Optical Zoom...
I have an olympus fe camera and the language was accidentally changed to japanese or chinese but anyways I don't know how to switch it back to english.
Press the MENU button. Use the cursor buttons to select Setup (crossed wrench and hammer). Press the OK/FUNC button. Use the cursor buttons to select the third line (speech bubble) and press OK/FUNC. Use the cursor buttons to select "ENGLISH" and press OK/FUNC. Press MENU to exit.
Jun 08, 2011 | Olympus FE-5020 Digital Camera
Card cover open fe 280
You can fix it with a small piece of tape inside the unit where the memory card goes. Just look inside for a sensor or a small button, and try pressing it down yourself. If that works, then maybe a slip of tape over that spot would fool the camera into thinking the cover is closed. If this is not fixing your problem take your camera to Olympus as this problem involves some built in mechanism troubleshooting.
Thank you !!
Jun 18, 2010 | Olympus FE-280 Digital Camera
How do i change resolution to 640 x 480
Press the camera icon button to get into the shooting mode if you're not already there. Press the MENU button to get into the shooting mode menu. Select "Image Quality" and then "VGA 640x480".
Mar 18, 2010 | Olympus FE-310 Digital Camera
Olympus FE-310
The reset option is located when you hit the Menu button when in shooting mode - it is on the left hand side of the screen. You would click Reset and press Ok. It will show Reset Yes or No. Select Yes and press Ok. The camera will now be in factory default settings.
Jan 15, 2009 | Olympus FE-310 Digital Camera
Olympus FE-140 ok except that flash does not work
Make sure you try and reset the camera to the factory default settings. There may be a setting that you are using that has disabled the flash functionality. To reset the camera - have the camera in shooting mode - press the menu button - left arrow to reset and press ok - you will see reset yes or no - highlight yes and press ok - camera will be back in factory settings - see if flash is able to work now.
Dec 28, 2008 | Olympus FE-140 Digital Camera
Cant take picture
The lens assembly and or microprocessor has failed.
Contact Olympus
Good luck, Paul
Jun 06, 2008 | Olympus FE-230 Digital Camera
Help
Yes and in several methods as below listed. Since your posting refers to a generic problem for all digital cameras and not only an Olympus FE-230, some of the settings may have a different nomenclature or button name.
1. When you download pictures to you PC, rather than copy, select move; or
2. If you want to erase one picture at a time from the camera - press on the power button, then menu button, once menu is displayed, arrow down/up, you will be asked to erase the picture displayed, select yes/no by up/down, then press OK (menu button); or
3. If you want to erase all contents of the memory card of the camera - press on the power button, then menu button, once menu is displayed, arrow right, down to select card, right to select card setup, right to enter card setup, arrow down to select format or erase all, OK. Erase all just erases the files, format erases all and re-initialize the memory card; or
4. Remove memory card from camera and insert into a memory card reader attached to USB of your PC. The memory from the camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
5. Connect the camera via the supplied cable to any USB port of your PC. The camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
Specifically for an Olympus FE-230:
1. Press the < or > buttons to display the picture you want to erase;
2. Press the trash can button (bottom right);
3. Press the UP button to select [YES], press OK;
or
To erase all:
1. Press the MENU button to display the top menu in playback mode;
2. Select [ERASE], [ALL ERASE], and press OK;
3. Select [YES], and press OK
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 08, 2007 | Cameras
Olympus FE-110 Digital Camera Logo
48 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
