LC XB40N aim remote greenish light comes on. Now, no light. could not get it to cut off using the remote.... new remote, still not go off. red power light on the projector not come on. 252 227 1111
Benimur
  • 6966 Answers
SOURCE: won't power up
Hi, The owners manual says that if the red light is flashing, it is an indicator that it is ready to be turned on (use remote or onboard on button); flashing red & green - too high temperature inside, the unit is overheated. Check and clean the air filters; If the red light is steady, abnormal condition and you have to call for service. A copy of your manual is available at http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_xb25_20_sb20.pdf Hope this be of some help. Pls post again how things turn up. good luck and kind regards.
Posted on Jul 31, 2007
marsrover
  • 682 Answers
SOURCE: Projector turns off after about 30 minutes. What's wrong?
your projector status means the protection circuit is working or the lamp is in an abnormal condition.
--wait until status indicator goes out and press power button.
---if the above solution is not working change the lamp.
Posted on Mar 18, 2008
SOURCE: Projector shuts off after about 45 minutes
Just a long shot, but...
I have an epson 9000i that did the same thing. Turns out that unit has a small fan (I think 60mm) right next to the power supply to keep it cool, in addition to the large fan that exhausts past the lamp. The fan runs non-stop as long as the unit is powered-up for two reasons I can think of - keep the power supply a little cooler, and the lamp a little warmer so there's not such a temp difference when it powers-up. Long story short, that fan had died. I replaced it with an aftermarket 60mm fan and it's been working fine ever since. Hope this helps.
Bob
Posted on Oct 07, 2008
joeshea123
  • 65 Answers
SOURCE: The projector suddenly shuts off.
have you check the filter?
Posted on Mar 27, 2009
projdoc
  • 2237 Answers
SOURCE: Eiki LC-XG110 lamp going off
the lamp may be at the end of it's life.
Posted on Nov 18, 2009
Remote doesn't work straight on
If your remote was dropped it may have re-aimed the IR light. There is a lens at the front of the remote that aims the light out like a flashlight (even though we can't see Infra Red light.) If the remote works good by aiming it down at a 45 degree angle, I would live with it. The alternatives would be to buy another remote or take your remote apart and try to re-aim the lens.
Jan 18, 2014 | Vizio New Original E370VT Remote Control
Seiki lc-32b56 will not power on
Bad power supply is usually the cause of this anomaly. Check the PS board for blown fuse, burnt resistors, bulging capacitors.
Jan 31, 2012 | Televison & Video
Trying to find out how tostart automatic code seach for tv so I can set the code and use the remote for my old daewoo tv
Try Aim tOn the remote control, press TV once. Press and hold SET until the LED (red light) blinks twice, then release SET. Enter 9 - 9 - 1.
Aim the remote control at the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off (after pressing POWER).
Feb 19, 2011 | One For All URC4220 Remote Control
Red fault light comes on after about 10 mins and
Had a similar problem with the same inverter BUT to include a failing cooling fan.
NOTE:
Take it back and get your money back as soon as possible.
Replaced it with a pure sine inverter 1500 watt that is kicking **** 24 seven days a week on my solar / wind power system.
RECOMENDATIONS:
UPGRADE.
Hope this tip helps.
R/
David
Dec 24, 2009 | Inverter AIMS 1000 Pure Sine Wave Power ...
I have a Viewpia LC-32IE21H which does not want to switch on.
For a three years old set, first place to look is the main power supply capacitors, at least the 5vdc standby circuit is working, the problem can be as bad as the main controller board, but look at the power supply first.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 06, 2009 | Televison & Video
Flashing red light
Same problem with my Sony. Unplugging for 36 hours solved the problem
Oct 05, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Wii
check the sensor bar is plugged in and aimed correctly.
Jan 28, 2008 | Nintendo Wii Console
Won't power up
Jul 31, 2007 | Eiki LC-SB20 Projector Multimedia...
63 people viewed this question
k24674
jasbo
jasbo
